Old 05-13-2014, 01:37 PM   #1
dejxx
dejxx's Avatar
Drives: FT-86
weird issue at high speeds after OFT tune
Before i start, i don't think this is a problem... and im 100% happy with OFT... but its something.
Lets get to the issue. I live in Argentina, some highways here don't really have a speed limit... and they are freaking deserted in some places. So i was traveling, and decided to do a top speed test, since ive never done one after i did my OFT flash.
I was in 6th gear, and just started to go, as easy as possible... when i hit 180km/h at around 4ishk rpm, the car kinda stopped accelerating... like for an entire second. This didnt happened before the tune... (i did a top speed test before the tune, some months ago).
Tried to reproduce this a couple of times... all the times it happened. Tried it in 5th gear, nothing happend.
Any opinions on what could be the source of this?
Before anyone gets mad at me for the speed... its a veryyyyyy long straight, with lots of space, and not a freaking soul... otherwise i don't go this fast... =)
dejxx is offline   Reply With Quote
Old 05-13-2014, 02:17 PM   #2
phrosty
Could you have lost traction? This has happened to me before.
phrosty is offline   Reply With Quote
Old 05-13-2014, 02:17 PM   #3
wparsons
wparsons's Avatar
Try logging what is happening when you experience this, especially since it's repeatable.
flickr
Old 05-13-2014, 02:20 PM   #4
Garrett@Openflash
Garrett@Openflash's Avatar
Drives: S2K AP2
+1, also are there any codes associated with this issue? you can send your logs to sales@vishnutuning for feedback.
Garrett@Openflash is offline   Reply With Quote
Old 05-14-2014, 03:49 AM   #5
brn12345
brn12345's Avatar
Since not many people take their cars up to top speed the experiences are far and between. Here is what I have experienced in top speed runs.
1. In some cases when I was running pump gas (I didn't have the logger on during the times it happened) the car while accelerating from anywhere between 150km/h and 240km/h would like you mentioned hit a wall but in my case it is brief (1-2 seconds) and then the car continues to accelerate. Having said this, I have not had this issue occur again since moving to 100octane fuel.
2. The stock mapping has a top speed limiter that kicks in at 221 km/h and I had posted about this before (see link below)
http://www.ft86club.com/forums/showthread.php?t=58835
3. Friends of mine with ECUtek have had issues with top speed that are a bit different. In their case the car hits a wall at 210 km/h every time without fail.
2013 Lightning Red - 6MT
Perrin Inlet Hose ~ TRD Panel Air Filter ~ OEM Modified Snorkel ~ Revolution 4-2-1 EL Header ~ HKS Resonated Front Pipe ~ BRZedit self tune ~ KW Clubsport Coilovers ~ AP Racing Big Brake 4 Piston ~ Whiteline Front Endlinks ~ Perrin Rear Endlinks ~ WedsSport TC105N 17x8 42+ ~Dunlop Direzza II Star Spec 225/45/17 ~ STI Trunk Lid Spoiler
brn12345 is offline   Reply With Quote
Old 05-14-2014, 12:21 PM   #6
dejxx
dejxx's Avatar
Drives: FT-86
mmmm thanks all for the answers... Ill try to take a log of the issue and post it here as soon as possible.
Old 07-14-2014, 07:00 PM   #7
MstrSHAKE
MstrSHAKE's Avatar
Drives: 2014 SWP BRZ
Dont mean to bump an old thread, but I just ran into this issue as well on my stage 1 flash. was at 6th Gear 99mph and then just hit a wall like fuel cut? Odd. Would not happen in 5th or 4th gear like the OP.
MstrSHAKE is offline   Reply With Quote
Old 07-14-2014, 07:42 PM   #8
Malt
Drives: 2015 WRX
Automatic or manual transmission?
Malt is offline   Reply With Quote
Old 07-14-2014, 07:45 PM   #9
steve99
Drives: FT86
Plug in your OFT and log the issue
AFR
IAM
LOAD
THROTTLE position
SPEED
LTFT
MAF V
etc
Check for any stored DTC/CEL codes
Old 07-14-2014, 07:58 PM   #10
MstrSHAKE
MstrSHAKE's Avatar
MT
Old 07-14-2014, 07:58 PM   #11
MstrSHAKE
MstrSHAKE's Avatar
AFR
IAM
LOAD
THROTTLE position
SPEED
LTFT
MAF V
etc
Will do when I get the chance!
Old 07-14-2014, 10:16 PM   #12
Chimera
Drives: FRS
interesting.. I'm running stg1 on B01c, I haven't had many opportunities to drive over 100mph, however my car sails right past to about 110 with ease, 110 seems to be its comfortable speed right around 4k rpm in 6th. tbh I have never tried to go above 110.
Old 07-21-2014, 03:50 PM   #13
slofrs
slofrs's Avatar
Drives: Hot Lava FR-S
it's pulling timing out in that little spot for some reason, i've seen it drop like 20* of timing in that spot.
slofrs is offline   Reply With Quote
Old 07-22-2014, 12:39 AM   #14
troek
troek's Avatar
Drives: 2012 Toyota 86
i would check all the speed limit tables in the tune in rom raider, just to be sure.
troek is offline   Reply With Quote
CEL issue after dyno tune reyruiz191 Software Tuning 10 07-29-2016 08:50 PM
Hood lift at high speeds Basti Suspension | Chassis | Brakes -- Sponsored by 949 Racing 97 02-15-2016 03:50 PM
Koni Rear Ride Height Too High; Install Issue rene0023 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 4 01-06-2014 05:01 PM
High pitch sound at freeway speeds l0aded Issues | Warranty | Recalls / TSB 7 06-14-2013 05:25 AM
High RPM Shifting Issue? Rinzler Issues | Warranty | Recalls / TSB 5 05-17-2013 12:30 AM
