Old 04-20-2014, 12:43 AM   #1
dvsidboy
Drives: 2013 Subaru BRZ
DVSIDBOY - NWMotiv Project BRZ Track Build (Vortech / 2500lbs)
Figured it was time that I created one of these threads and tracked the progress of the car with you all (those that arent on the FB Group).
Purchased the car in June of 2012 and it has gone through quite a transformation in the two years of owning the car. The BRZ started out as a Autocross focus build but has quickly put it eyes on to the track versus cones, although it will still chase cones.
The car also hits shows and is on display at the various NWMotiv events held in the NW, so it is out and about quiet a bit. :zipsflamesuit: Yes, it is a AT but on the track/autocross at speed that makes really difference. (For now its an Auto I should say)
Performance Mods
-- Vortech S/C Kit w/Perrin EcuTek Tune
-- OEM A/C Delete Kit
-- Perrin Oil Cooler
-- Perrin Oil Cap
-- Perrin 2.5" Overpipe Pipe
-- Perrin 3" Exhaust
-- Gutted OEM Header
-- Perrin Motor Mounts
-- Perrin Transmission Mounts
Suspension / Handling Mods
-- AMR Engineering Coilovers
-- Swift Racing Springs
-- WhiteLine Front/Rear Control Arm Bushings
-- WhiteLine Rear Sway Brace
-- WhiteLine Front Strut Bar
-- Perrin Front 19mm Sway Bar
-- Perrin Rear 16mm Sway Bar
-- Perrin Front / Rear Endlinks
-- Perrin Positive Steering Response System
-- Perrin Steering Rack Lockdown
-- Perrin Front Control Arm Brace
-- H&R Front Camber Bolts
-- RacerX Fabrication Rear Control Arms
Interior / Exterior
-- Yellow Tinted Headlights / Fog Lights
-- C/F Wrapped Roof
-- HT Autos Front Lip
-- Perrin Front Plate Relocate Kit
-- Perrin Shift Knob
-- Recaro PROFI Racing Seats
-- BuddlyClub Seat Rails w/Sliders
-- G-Force 5 Point Racing Harnesses
-- C/F Push Button / Traction Control Mount Plate
-- Full Weld in Cage
-- Works Bell Hub (Short)
-- NRG Quick Release
-- NRG Wheel
Wheels / Tires
-- Forgestar F14 Wheels 18x9 (+38F/+32R)
-- Toyo R888 235/45/18
Removed Items
-- A/C System
-- Heater Core
-- Stereo
-- 90% of interior
-- Airbags
-- Unused Wires
-- Passenger Windows
WEIGHT
2570lbs (w/cage / 1 Seat)
Current Photos:
1
2
3
4
5
6
7
8
9
10
Race Videos:
[ame="http://www.youtube.com/watch?v=W3hN1lm9qvc"]NWMotiv Project BRZ - Oregon PCA Event 1&2 - YouTube[/ame]
dvsidboy is offline   Reply With Quote
The Following 3 Users Say Thank You to dvsidboy For This Useful Post:
Lonewolf (04-20-2014), new2subaru (09-10-2016), PEWPEW (04-20-2014)
Old 04-20-2014, 12:43 AM   #2
dvsidboy
Reserved for Progress.
Old 04-20-2014, 02:00 AM   #3
Tye300
Tye300's Avatar
Drives: Toyota 86 TRD Version AT
Nothing wrong with tracking an AT!
Great build!
Tye300 is offline   Reply With Quote
Old 07-14-2014, 03:14 PM   #4
dvsidboy
Competed last weekend at the SCCA Packwood ProTour, it was a blast to be out on a more open area for an autocross. Couldnt really keep heat in the R888s, so those will be getting switched out to a Hoosier for future events. Overall in the XP Class (yeah, XP its super awesome) I finished 9th in the class, but again it was a blast just to be out racing.
This event also was our first run with the rear camber getting dialed in thanks to RacerX Fabrication Rear Control Arms, these are awesome, you can see my DYI on these here: http://www.ft86club.com/forums/showthread.php?t=68983
Here is the videos from both Saturday and Sunday:
[ame="https://www.youtube.com/watch?v=ZK-munDj-Hs"]NWMotiv Project BRZ - SCCA National Tour Packwood, WA Event - YouTube[/ame]
And the car in the grid:
Old 07-14-2014, 03:50 PM   #5
Lonewolf
Lonewolf's Avatar
Drives: Moped
How does the auto handle the heat generated from tracking? Any plans to add an upgraded tranny cooler or bigger radiator?
Old 07-14-2014, 04:32 PM   #6
chiefshayan
chiefshayan's Avatar
Drives: 2013 AT Firestorm FRS
Awesome build. A few questions, why is it an auto "for now"? Do you plan to swap trans? Since you replaced the steering wheel, I'm guessing you threw out the flappy paddles.. Ever think of bringing them back on the aftermarket wheel?
chiefshayan is offline   Reply With Quote
Old 07-14-2014, 04:50 PM   #7
dvsidboy
So far I have not seen any problems with the AT, however this was the only event so far that had high temps, but long cool down periods. I do plan on a tranny cooler for the car. On the bigger radiator, I again didn't see temps climb to high, but I also dont have a A/C compressor in front of the radiator any more. I am going to run a switch for the fans to help with cooling after runs, that will be some time this week.
I am looking over the winter as the car goes into the next phase, but not high on the list of items.
The paddles are currently removed, but I am working to have a bracket created to bring them back as the plug is still on the hub. Once that is completed I will get some photos up because some AT guys might want to switch wheels and keep the paddles.
The Following 2 Users Say Thank You to dvsidboy For This Useful Post:
Lonewolf (07-14-2014), rs999 (08-06-2014)
Old 07-17-2014, 12:27 PM   #8
dvsidboy
Picture of the progress on the bracket. Still have some work on it, like painting black.
Old 07-25-2014, 05:33 PM   #9
dvsidboy
InstaGram Fresh photo of the rear, better photos coming. The plumber tape is just temp, going to get welded holders in place. Also going to be blacking out the rear section.
This will be more for the track/autocross setup. Going to run a black muffler during any street driving (minimal).
Old 07-29-2014, 01:43 AM   #10
dvsidboy
Better shots of the rear end with the new straight pipe.
1
2
3
Old 08-05-2014, 05:54 PM   #11
dvsidboy
Started to do some trimming on the car.
First part was the doors, to get ready for the next phase of the cage: (Still have a little more trimming to do)
Next are the DIY vents for the fenders, really happy with the way this looks: (There is a flashlight behind the fender to help show the opening from the engine bay)
frsvr4 (08-05-2014), Jmonty (08-05-2014)
Old 08-05-2014, 06:08 PM   #12
Jmonty
Realtor/ Principal Broker
Drives: JRSC BRZ GBS LTD 2010 LTD Outback
Those vents look and came out great
Jmonty is offline   Reply With Quote
Old 08-05-2014, 06:46 PM   #13
PERRIN_Mladen
PERRIN_Mladen's Avatar
Drives: '11 535i
Those came out really good!
PERRIN_Mladen is offline   Reply With Quote
Old 08-05-2014, 06:55 PM   #14
chiefshayan
Sequential 6-speed in the future?
The Following User Says Thank You to chiefshayan For This Useful Post:
PERRIN_Mladen (08-05-2014)
AJR Project BRZ ! AJ PwR Member's Car Journals 8 10-25-2014 01:13 PM
New project car kjdd787 Other Vehicles & General Automotive Discussions 20 01-06-2014 09:03 PM
TWM Project trish07 Scion FR-S / Toyota 86 GT86 General Forum 26 03-11-2013 12:27 PM
Project Mu yomchi1989 AUSTRALIA 18 12-06-2012 07:36 AM
86-X project phenom86 Scion FR-S / Toyota 86 GT86 General Forum 1 07-11-2012 03:57 PM
