Old 07-12-2014, 11:15 PM   #1415
DocWalt
DocWalt's Avatar
Drives: '22 BRZ
Originally Posted by cnk View Post
After flashing the ecu, turn car on but don't start the engine. Fully depress and release the gas pedal 10-20 times. Turn off ignition. Start car normally and you're good to go with no dead pedal feeling.
Sent from my Transformer using Tapatalk
If it doesn't improve I'll try that when the OTS v2.0 maps roll out. I'll be away from my car for a week and a half anyway.
Old 07-13-2014, 12:14 AM   #1416
DocWalt
DocWalt's Avatar
Drives: '22 BRZ
Hmm, takes up to a week... Ok, I'm just impatient. I see no reason for the ECU to take that long to learn the throttle pedal calibration, but I'm assuming it's a safety thing.
http://www.ft86club.com/forums/showthread.php?t=62972
Old 07-13-2014, 12:30 AM   #1417
cnk
Drives: '13 DGM BRZ Limited
I do the procedure I outlined above as well as allow the car to idle until the revs drop after the first start and I don't get any throttle pedal delay. I did this when I had Ecutek and now with OFT and it works. It's been outlined in other threads as well.
Old 07-13-2014, 08:05 AM   #1418
steve99
Drives: FT86
wont take a week :-)
see post below for some tips, the ecu needs to find the throttle zero position after a reset or reflash, if you mess with throttle before its sorted itself out it can take a few drive cycles to sort itself out, same thing can happen with cam actuators, after reflash basicly turn ignition on leave for 20 sec start let idle for a minute at least, see post for details
http://www.ft86club.com/forums/showthread.php?t=68328
DocWalt (07-13-2014)
Old 07-13-2014, 05:38 PM   #1419
R2
I've tried all the tricks and I find it still takes over 3 weeks for mine to sort itself out. The biggest improvement is in the first 4 days/100km or so I find, where it goes from 1/3" of deadband to 1/8". Then it just takes time for that last few mm to sort out. I wonder if my TPS is more out of tolerance than most which is why it takes longer to learn.
R2 is offline   Reply With Quote
Old 07-13-2014, 07:08 PM   #1420
steve99
Drives: FT86
Might be worth having a look at your ltft long term fuel trim arount idle and low rpm and see if it high, if si you might benifit from scaling maf or check for exhaust or intake leaks
Old 07-13-2014, 07:39 PM   #1421
Target70
Target70's Avatar
Drives: 2013 Asphalt 6spd
I have this same issue, I am at about 2 weeks after a reset and I still have that slight amount of dead zone. what should LTFT be at idle? I just ran a log yesterday and mine is -7.81.
http://datazap.me/u/target70/oft-sta...log=0&data=1-9
Target70 is offline   Reply With Quote
Old 07-13-2014, 08:09 PM   #1422
steve99
Drives: FT86
Thats pretty normal for unscaled maf, if it was over 10 you would be looking for leaks or scaling maf.
Does tend to vary at idle due wide variation in iat temps.
Also have a look at your IAM if its way below 1 the reduction in advance can make the car feel sluggish
Does seem strange thet some guys get the throttle dead spot for so long, never been a problem for me since letting car idle after imediatly after flash .
out of ideas now
Old 07-13-2014, 08:29 PM   #1423
Target70
Target70's Avatar
thanks for the help
If IAM is the same thing as ADV multiplier(I haven't been able to figure that out) then It is a solid 1.
The dead zone isn't much of a problem, It just keeps me from wanting to change tunes very often. I have the OFH coming hopefully end of the month, so I am going to wait on v1.6 until I can flash to stg 2 v1.6.
Old 07-13-2014, 09:22 PM   #1424
Turdinator
Señor Member
Turdinator's Avatar
I found the dead throttle dissapeared quicker after my first attempt at MAF scaling. I suspect the throttle pedal takes a little time to learn but the fuel trims being out also account for some of the doughyness we feel after a flash.
1974 TA22 Celica
2013 86 GT
The Following User Says Thank You to Turdinator For This Useful Post:
steve99 (07-13-2014)
Old 07-13-2014, 09:36 PM   #1425
steve99
Drives: FT86
thanks for the help
yes IAM is ignition advance multiplier
Target70 (07-14-2014)
Old 07-13-2014, 11:13 PM   #1426
R2
I'm the same way, I don't want to flash and try new things because of this. It is a royal bitch to drive for a week before the car feels ok, especially in the winter when traction is limited.
I'll look into the LTFT, but I know that looking at the Throttle Pedal position vs. Throttle position in realtime on the tablet, the pedal position stays at 0% for several millimeters of pedal movement. As soon as it goes to 1%, the throttle position increments and the rpms increase.
The Following User Says Thank You to R2 For This Useful Post:
Old 07-14-2014, 04:20 AM   #1427
Kodename47
Kodename47's Avatar
Drives: UK GT86
Then you need to do the accelerator pedal calibration:
- Car on, but not started
- Fully depress and release the pedal 10 times
- Start car
You can do that at any time, not just after a flash. So if you feel like you're still experiencing "lag" then just give that a go. There is, however, always a small area of the pedal that doesn't register and that is normal. It is also true that trims can have a decent impact on feel too.
.: Stealth 86 :.
Kodename 47 DJ:
Shiv@Openflash (07-14-2014)
Old 07-14-2014, 12:56 PM   #1428
Silver Ignition
APEXHNTR
Silver Ignition's Avatar
Drives: 10 Series FR-S #1867
OFT OMG
just got mine so I'm joining the conversation...flashed my basically stock (TRD cat-back) car and within 10 minutes I was like
wooooooo
I like this thing...
2013 Sc10n FR-S 10 Series
#1867 of 2500
in the garage...2001 Toyota 4Runner [Solid Axle Rock Toy], 1987 Pontiac Fiero GT [Shitwagon], 2004 Honda Interceptor VFR800 [daily rider], 1978 Suzuki GS750 [Café Racer]
Silver Ignition is offline   Reply With Quote
The Following User Says Thank You to Silver Ignition For This Useful Post:
#lolwut, divinecomedy, dopeandcashcabinet, free shiv now, goddamitimissedit, golden cage, i missed the show, looks good, missed the fun, omgbbq, shiv 2016, thefatandthefurriest
Tablet on the dash ! TRD_86 Electronics | Audio | NAV | Infotainment 23 05-16-2015 04:48 AM
Tablet Install ThugNasty Electronics | Audio | NAV | Infotainment 4 04-13-2013 04:15 PM
Blutooth OBD II and a 9.7 tablet.. Scooby South Electronics | Audio | NAV | Infotainment 10 12-16-2012 09:11 PM
7.0 Tablet w/ Torque App Thatruth2001 Northwest 26 11-21-2012 12:53 PM
