Old 07-08-2014, 06:12 PM   #43
protpibe
protpibe's Avatar
Drives: 4-Runner Sport - 13' BRZ SportTech
Have your issues been diagnosed yet?
Seems like you're swatting a fly with a nuke bomb right now.
Top Tier Imports - Check out my build journal HERE
protpibe is offline   Reply With Quote
Old 07-08-2014, 06:14 PM   #44
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
Originally Posted by Pure Automotive View Post
That weight is with the transmission in it already, its a finished running car.
I know, I'm taking about those who want to do an LS swap, they think it will be only a few lbs heavier than stock, but are forgetting the transmission that needs to go along with it too.
Old 07-08-2014, 06:14 PM   #45
Cross
It's the Mad Cow
Cross's Avatar
No further updates besides the dealer agreeing the cams malfunctioning caused the issue and my car is drinking coolant.
Old 07-08-2014, 06:57 PM   #46
boarder1995
Drives: 2013 Subie BRZ Limited, black, 6MT
Really upsets the balance......
This is my full interior, 17x9.5 275/40/17 Drag Radial equipped, Full bodied with lip kits and all FRS with a 6.6Liter LS2 T56 swap in it. Look at that cross weight.
44/56 isn't bad at all. And 2919# total isn't but ~150-200#more than stock. A turbo kit, oil cooler, etc. will quickly add up to that weight, plus it's usually way out front.
boarder1995 is offline   Reply With Quote
The Following 3 Users Say Thank You to boarder1995 For This Useful Post:
civicdrivr (07-08-2014), Pure Automotive (07-09-2014), RedAlert (07-09-2014)
Old 07-08-2014, 07:26 PM   #47
civicdrivr
civicdrivr's Avatar
Drives: 2018 Golf R
But, but, but....FA20...
Parting out HERE
civicdrivr is offline   Reply With Quote
Old 07-08-2014, 07:51 PM   #48
C130NAV
C130NAV's Avatar
Drives: Whiteout 6Sp FR-S
I'm in the same position as you except half of my rod and some of the piston landings are sitting in my oil pan. Now I'm stuck thinking if I should shell out the $18k for WGP to do an LS swap or drop some money into getting a bulletproof FA20 Crawford also has short block options.
C130NAV is offline   Reply With Quote
Old 07-08-2014, 11:59 PM   #49
boarder1995
I've got a fully functional stock, non-FI FA20 motor currently and am even running the cost numbers on various upgrade paths.
FA20 basis:
Turbo, ~$6k, 100+# weight
Supporting mods (clutch, driveshaft, oil cooler, fans, etc) $2k?, +50-100# weight?
Exhaust, $1k (already bought this)
Built motor once stock one is windowed, ~$6k, additional weight?
Max peak power = 700hp?, very peaky, not broad power. But, it's still a boxer FA20 motor!
LSx basis:
LS2 motor, $6k?, +100#?
LSx adapter kit, trans, $8k, +100#?
It's not a FA20 boxer motor, in a BRZ/FRS it's odd sounding, perhaps even kind of boring, but it's got easily 400-700+hp, with a broad power band with gobs of torque all over the place.
The Following User Says Thank You to boarder1995 For This Useful Post:
shiro (07-22-2014)
Old 07-09-2014, 01:27 AM   #50
evo4g63
evo4g63's Avatar
Drives: 2016 Subaru WRX
These OCV issues have me on edge. I wanna see this LSX swap and how it all comes out. I was thinking about that before I went turbo. I bought a used LS2 and had it sitting at the shop for a few months. Decided to sell it off after seeing what plenty of people had done power wise on a stock FA20. Best of luck man.
-2016 Subaru WRX
-2013 Scion FR-S: Wastegated Vortech V3'd, E85 SOLD
evo4g63 is offline   Reply With Quote
Old 07-09-2014, 10:11 AM   #51
Pure Automotive
Pure Automotive's Avatar
Drives: 2013 FRS Whiteout
I'll be the first guy to tell you that we're still working out bugs on the LS setup. There's a lot of smoke and mirrors out there about other LS swaps that are taking place and no one really tells you about the MASSIVE amount of small issues that ends up nickel and diming you to death. I will not stop until I get this LS swap as close to stock as possible with all functioning gauges, A/C, power steering, ABS, and maybe even eventually traction control. But I own a shop, we have unlimited resources and free labor. For the average guy, this swap is NOT plug and play, and is NOT bolt in and go, no matter what anyone tells you.
Pure Automotive is offline   Reply With Quote
The Following 3 Users Say Thank You to Pure Automotive For This Useful Post:
protpibe (07-09-2014), RedAlert (07-09-2014), shiro (07-22-2014)
Old 07-09-2014, 11:51 AM   #52
Cross
It's the Mad Cow
Cross's Avatar
Oh believe me, I wont expect it to be but I'm lucky enough to have a few resources to help me go through it as I am the same way. All the gauges and Ac will work as they did from the factory. We will find a way.
What year pcm did you use?
Old 07-09-2014, 12:10 PM   #53
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
You mean a 2JZ or LS swap isn't all rainbows and unicorns.
raven1231 (07-23-2014)
Old 07-09-2014, 01:52 PM   #54
Pure Automotive
Exactly, despite popular belief lol
Old 07-09-2014, 01:52 PM   #55
Pure Automotive
I have an 07 CTS-V ECU
Old 07-09-2014, 03:53 PM   #56
andrew20195
Drives: 2013 Subaru BRZ
Originally Posted by s2d4 View Post
Don't have first hand experience but I think Zdan was saying it LS1 was 200lbs more apparently due to being a full iron block.
Should be fun either ways.
He was referring to the LSX Bowtie block (most people just call it LSX), an "aftermarket" block available from GM Performance Parts. A lot of people like it for extreme builds in the GM world, and it's quite a bit cheaper than a billet aluminum block from Dart or something along those lines.
andrew20195 is offline   Reply With Quote
'Sloane' - Cali first time build Re~Mix Member's Car Journals 6 06-24-2015 09:22 PM
The time attack build by Rob SavingManuals Member's Car Journals 8 04-27-2014 09:01 PM
Adventure Time! (E.Ts BRZ/86 Build) E.T Member's Car Journals 4 01-20-2014 02:02 AM
Frs300 Fa20club built motor and turbo build Frs300 Member's Car Journals 32 01-18-2014 06:27 AM
New FRS owner.. time for a build? sero901 Forced Induction 5 10-24-2013 10:40 PM
