Old 07-05-2014, 06:13 PM   #1387
GT86meMR2
GT86meMR2's Avatar
Drives: MR Spyder/GT86
So i ordered the Openflash Tablet 2 days ago around how long does it usually take to have your payment accepted and receiving a tracker? only got order email which said there were tablets in stock so far. Grtz
GT86meMR2 is offline   Reply With Quote
The Following User Says Thank You to GT86meMR2 For This Useful Post:
Shiv@Openflash (07-05-2014)
Old 07-05-2014, 06:43 PM   #1388
Shiv@Openflash
Shiv@Openflash's Avatar
Drives: 2013 FRS
Shoot an email to sales@vishnutuning.com and they guys can give you an update on Monday. Thank you for your order
Shiv@Openflash is offline   Reply With Quote
The Following User Says Thank You to Shiv@Openflash For This Useful Post:
GT86meMR2 (07-05-2014)
Old 07-05-2014, 11:30 PM   #1389
Wankel Rex
Wankel Rex's Avatar
Drives: Silver Premium Edition BRZ
I installed my OpenFlash header today, and updated to the UEL Stage 2 tune. Is launch control permanently enabled with this tune? It kicks in whether I'm in Neutral or any gear and try to rev - limits me to 5500 RPM.
Wankel Rex is offline   Reply With Quote
Old 07-06-2014, 12:41 AM   #1390
steve99
Drives: FT86
Yes it on by default, delta is set to 2000 so its redline minus 2000 ie about 5600 rpm
it works on vehicle speed once speed over about 6mph you should then get full rpm limit, their is parameter to adjust delta and speed at which launch rpm limit ceases.
If you set them both to 0 its disabled, would probably disable if either one set to 0.
Wankel Rex (07-06-2014)
Old 07-06-2014, 05:29 AM   #1391
Kodename47
Kodename47's Avatar
Drives: UK GT86
Originally Posted by Pistol View Post
i get the " your cat is missing code" constantly
quite annoying actually
and no i don't want to fix it myself, i think it should be sorted with the stage 2 tunes
hopefully 1.6 will address this
Its just a tick box in there map. Find the DTC list in Romraider, find the code that gets thrown, untick box, save map, flash. It would take you 10 minutes.
.: Stealth 86 :.
Kodename 47 DJ:
Old 07-08-2014, 03:07 PM   #1392
continuecrushing
continuecrushing's Avatar
Drives: 2013 Firestorm FRS
This and no lift/wot shifting feature we're the only issues I had...for me it was more annoying because I had my launch set to 4k.
As far as I know, the only way to "disable" it is by disabling the launch control.
Old 07-08-2014, 05:34 PM   #1393
steve99
Drives: FT86
The launch control settings and Flat foot shift (FFS) settings are independent you can disable one or both independently
Under LC you have RPM delta and Disable speed
Launch RPM (Redline-Delta=launch RPM) holds RPM at desired vaule while vehicle is traveling at less than the Speed set in the Disable value. Once speed exceeds this value launch RPM is "disabled"
to disable launch control set Delta to zero.
Under FFS you have a second RPM delta.
For FFS RPM (Redline -Delta) will only be active if the vehicle is in motion over the (LC disable speed)and the clutch is depressed, the RPM will be limited to what you have set. Unfortunately it cannot differentiate between upshifts and downshifts and cannot be set per gear.
If you set the FFS Delta to zero it effectively disable as the car will rev to full rpm limit with clutch depressed while is moving above the LC disable speed. Even if you have a LC RPM limit set.
Old 07-08-2014, 06:29 PM   #1394
continuecrushing
You can disable all of those things, but if launch control is set, it is ALWAYS set at neutral...doesnt matter if you're in gear, clutch in, clutch not in.
So, if you have a 4k launch, you can never rev over 4k when stopped. Normally wouldn't be a big deal, but at my work we sell my exhaust(Ark Grip) and customers want to know how it sounds, but I could never rev over 4k lol.
I normally wouldn't complain/be bothered by it, but all my other platforms could differentiate whether or not to engage LC based on gear/clutch positions.
Plus(not Shiv's fault at all) I dislike how this car handles launch control, by flapping the throttle body open/close.
The Following User Says Thank You to continuecrushing For This Useful Post:
steve99 (07-08-2014)
Old 07-08-2014, 06:36 PM   #1395
steve99
Drives: FT86
Arrrh ????, you could have car moving at over 6mph clutch in and it would rev over 4k with launch set (pain unless your on rollers), yes its a very simple implementation on LC and FFS, personally don't use either found more trouble tan their worth :-) especially FFS.
Old 07-08-2014, 06:55 PM   #1396
Trettiosjuan
Drives: GT86
IMHO gimmicks that detract from the purity of the car...
Trettiosjuan is offline   Reply With Quote
Old 07-08-2014, 07:04 PM   #1397
continuecrushing
true, but I would generally just leave the car in the parking space haha.
And FFS just caused issues for me in the fast corners...IE, I would be wot, then clutch/downshift and get back on the gas again and be treated with a delay-of 1/2 second before having throttle back
The Following 2 Users Say Thank You to continuecrushing For This Useful Post:
steve99 (07-08-2014), Target70 (07-08-2014)
Old 07-08-2014, 07:07 PM   #1398
steve99
Drives: FT86
agree
continuecrushing (07-08-2014)
Old 07-08-2014, 07:56 PM   #1399
Target70
Target70's Avatar
Drives: 2013 Asphalt 6spd
alright. now I guess I have to learn about romraider and how to use it so I can disable this stuff.
Thanks for the info
Target70 is offline   Reply With Quote
Old 07-08-2014, 08:10 PM   #1400
steve99
Drives: FT86
Thanks for the info
Just make sure you download the romRaider definition files from the OFT site as the ones from romraider/github don't have the LC/FFS parameters as the OFT ROM's have a patch to code to insert these extra features.
to disable just set the LC delta to zero "0" and the FFS Delta to "0".
#lolwut, divinecomedy, dopeandcashcabinet, free shiv now, goddamitimissedit, golden cage, i missed the show, looks good, missed the fun, omgbbq, shiv 2016, thefatandthefurriest
Tablet on the dash ! TRD_86 Electronics | Audio | NAV | Infotainment 23 05-16-2015 04:48 AM
Tablet Install ThugNasty Electronics | Audio | NAV | Infotainment 4 04-13-2013 04:15 PM
Blutooth OBD II and a 9.7 tablet.. Scooby South Electronics | Audio | NAV | Infotainment 10 12-16-2012 09:11 PM
7.0 Tablet w/ Torque App Thatruth2001 Northwest 26 11-21-2012 12:53 PM
