#43 |
Drives: 2013 FRS
The highest boost pressure the factory MAP sensor is capable of reading is right around 5psi (depending on atmospheric pressure). So if you see your boost logs flatline somewhere around that, it could very well be higher.
Shiv |
#44 | |
Time Traveller
More TQ250 v. TQ300
Data is here (fascinating): http://datazap.me/sites/default/file...20070514_0.csv Graph is here: http://datazap.me/u/daemano/phantom-...4&mark=28-0-99
| The Following 2 Users Say Thank You to DAEMANO For This Useful Post: | Boofneenee (07-06-2014), raven1231 (07-05-2014) |
#45 |
Does everyone who is running this tune have the OFH?
| The Following User Says Thank You to Urmyson For This Useful Post: | DAEMANO (07-05-2014) |
#46 |
Time Traveller
#47 |
If you you are looking for a header to use with this kit, the JDL EL header is your best option. EL headers provide better top in power. UEL headers were great for NA cars as it provided better TQ in the DIP than EL. I would love to see the 1.5 dump 250 setup with a full Exhaust and no cats with a JDL EL header with E85 could produce.
#48 | |
| The Following User Says Thank You to fenton For This Useful Post: | DAEMANO (07-06-2014) |
#49 |
Time Traveller
#50 | |
#51 |
Drives: 13' FR-S
Will the TQ300 every be available for purchase?
#52 |
Lightning McQueen Driver
Drives: Limited Red 6MT BRZ
The tq300 is still in beta testing but it doesn't make sense for BRZ or frs in its current form. The tq 250 spools up faster and has almost identical boost levels.
Installed Mods: Phantom Electric Super Charger | Open Flash Tune | Perrin OP/ HFC Front pipe | Invidia Q300 catback | ST Suspension | JDL Header | Flex Fuel |
#53 | |
Go-Kart Enthusiast
Drives: Toyota Scion FRS
FRS
Current mods: K&N air filter, OFT, OFH, berk high flow cat front pipe, Q300 exhaust, lighter wheels |
#54 | |
Drives: 2013 FRS
#55 | |
Sent from my SGH-T999 using Tapatalk
2013 Series 10 FRS #553
#56 |
Drives: 2013 Asphalt 6spd
I may just be crazy, but I still want to see 2 phantom compressors hooked up in series on the car.
10 psi witin ~.5 seconds of WOT. We would have to limit boost to ~7psi for stock engine config. Have maybe 4psi over 6k, if the boost scales 1 to 1. This should keep us from needing new clutch,cooling,fuel mods. Fitment would be easy if you ran a CAI, or some slight piping work to use the stock airbox. The alt charger could just be another controller and could control the second compressor. Both could be hooked up to the same throttle switch for activation. All that would leave is the need for a dump 2.0. 1 dump pack for each compressor, or if It will fit; two 1.5's. I realize this is getting really expensive and outside the purpose for the phantom kit, but I can't help but think about the upgrade path of the ESC. I don't know if the OFT could tune for that type of setup, but think about it, double(theoretically) the boost acrost the range for an extra $1600. If you already have a 2.0dump and OFT. ![]() ok bored rant over, commence crushing my dreams. |
| Phantom TQ250 Dyno FBO (Dual Battery Pack) | Shiv@Openflash | Forced Induction | 23 | 04-29-2014 01:40 AM |
| Clutch dump at 5000 RPM? | fasteddy | BRZ First-Gen (2012+) — General Topics | 20 | 08-22-2013 12:55 PM |
| External dump and under tray? | mrk1 | Forced Induction | 5 | 07-30-2013 08:43 AM |
| Photo dump. | CanibeatNoel | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 11 | 07-17-2013 01:47 AM |
| Ricepuddin Picture Dump | Ricepuddin | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 15 | 12-02-2012 11:18 PM |
