#29 | |
Drives: 2018 Golf R
Most of the weight is from the T56, which is towards the center of the car anyway if you place it right.
Parting out HERE
#30 | |
It's the Mad Cow
Decided to let the dealer puck it up after talking to the service manager I know and being up front. Because there is a tsb for the codes I have we shall see what happens. As for LS1 vs LS3 the LS Series are all Aluminium. There are the LQ Series which are normally Iron but I do believe they can be found in Aluminium occasionally (Escalades) the 5.3 comes in both but that's not an LS1. They are all VERY similar and share/swap parts but I would be using the smaller 5.7L LS1 and it is all aluminium. Looks like I might just put some serious thought into selling my turbo kit and doing this...
05 GTO 408 Stroker \ 13 FRS 210 Twin Screw Supercharger on E85 \ 14 F-150 5.0L Last edited by Cross; 07-07-2014 at 01:16 PM. |
#31 |
in orbe terrum non visi
Drives: violent
When the time comes ill be high comp. Even if I have to refine my own fuel.
I have E85 where there isn't E85, that's my secret.
http://www.ft86club.com/forums/showt...t=reaper+build |
| The Following 3 Users Say Thank You to Reaper For This Useful Post: |
#32 |
Drives: Scion FRS
I think ill go in the 10-11.5 range, I have easy access to e85 so I dont have to go to low
#33 |
Drives: 2016 Subaru WRX
LS swap time @Cross. Keep us all posted to your findings.
-2016 Subaru WRX
-2013 Scion FR-S: Wastegated Vortech V3'd, E85 SOLD |
#34 |
Drives: '13 Whiteout FRS
@FullBlown do you guys have another bearing option other than new OEM bearings?
Pretty much everyone I see doing builds always have OEM bearings still and you would think this far in there would be something as simple as bearings... Sorry to thread jack OP, but in my opinion, the LS1 will still have a relatively low center of gravity, being that it's push rod. Weight is just about where the FA20 + turbo kit would be. Like mentioned, most of the weight will be from the trans, which would be closer to center. I'll take a few more lbs in the center for a trans that can take a thrashing and not pop.
Previous:
'01 Accord-daily '93 Rx7-fire breathing track monster 545hp 397tq 2300lb. '06 Mazdaspeed6 one helluva love-hate relationship |
#35 |
Drives: 2013 Subie BRZ Limited, black, 6MT
Don't know if this has been posted here, but these guys have done LSx swaps...
http://frsbrzperformance.com/tag/brz-engine-swap/ |
#36 | |
That's the Weapons Grade car/kit which is fairly well known at this point. A couple others have done them as well, there is a shop in Atlanta here who just built a supercharged LS2? drift car. Vorschlag is also making a LSx swap kit, but they aren't that far into development so it will be awhile. I guess your options may change depending on what the damage actually was, the block could be fine for all you know at this point. |
#37 |
Drives: 2013 FRS Whiteout
| The Following 10 Users Say Thank You to Pure Automotive For This Useful Post: | B L U E S L A T E (07-28-2014), civicdrivr (07-08-2014), Cross (07-08-2014), Manji (07-21-2014), Reaper (07-08-2014), shiro (07-22-2014), slicktop (07-08-2014), Sportsguy83 (07-08-2014), Tye300 (07-08-2014), xxBrun0xx (07-29-2014) |
#38 |
Junior
Drives: a car
I don't think most people take into account the added weight of the transmission that you'll need too. Unless it'll be a highway puller or drag car, I'd rather stick with the FA20
#39 |
Drives: violent
500 ft pounds of torque at 1500rpm is pretty nice though. I don't think any fa20 has hit 500tq period.
#40 | |
Junior
Drives: a car
#41 |
It's the Mad Cow
Alright LS1 Swap it is, time to sell everything off and get the remaining pieces aka Transmission and figure out how the hell the wiring is going to work.
05 GTO 408 Stroker \ 13 FRS 210 Twin Screw Supercharger on E85 \ 14 F-150 5.0L |
#42 |
| The Following 3 Users Say Thank You to Pure Automotive For This Useful Post: |
| 'Sloane' - Cali first time build | Re~Mix | Member's Car Journals | 6 | 06-24-2015 09:22 PM |
| The time attack build by Rob | SavingManuals | Member's Car Journals | 8 | 04-27-2014 09:01 PM |
| Adventure Time! (E.Ts BRZ/86 Build) | E.T | Member's Car Journals | 4 | 01-20-2014 02:02 AM |
| Frs300 Fa20club built motor and turbo build | Frs300 | Member's Car Journals | 32 | 01-18-2014 06:27 AM |
| New FRS owner.. time for a build? | sero901 | Forced Induction | 5 | 10-24-2013 10:40 PM |
