Old 07-08-2014, 06:32 AM   #1
djmm
djmm's Avatar
Drives: toyota
Auto Transmission Driver: what driving mode ?
My automatic transmission 86 just recently passed the 1000 miles mark and I've started to experiment with driving with Sports mode.
Is it just me or when you put the car in sports mode, the gas pedal becomes more sensitive- ie. Gives you more power when you slowly press the pedal?
also from my understanding Sports mode doesn't affect traction control but my car's rear slided the first time ever unintentionally and it was when under sports mode. If it does affect traction, I'll need to be extra careful at narrow bends so I won't scratch other cars.
djmm is offline   Reply With Quote
Old 07-08-2014, 08:43 AM   #2
JG
JG's Avatar
Drives: Whiteout FRS
I'm not sure about the gas pedal being more sensitive when in sports mode but I haven't read anything about the gas pedal changing sensitivity when switched. I have read that when you put it into sports mode it delays the affect of traction control without fully turning it off. There's a video floating around on the forums showing all three modes and how it affects your vehicle. Might be on youtube also. Hope this helps.
JG is offline   Reply With Quote
The Following User Says Thank You to JG For This Useful Post:
Karigan (07-08-2014)
Old 07-08-2014, 08:44 AM   #3
Demandred7
Demandred7's Avatar
Drives: 2018 Camry XSE V6
Unless you are talking about VSC Sport mode, "Sport" mode essentially keeps engine revving higher and staying in a lower gear longer to stay in the power band and will kick down a gear sooner than normal mode. If you are talking about VSC Sport mode, then the car will allow a little more slip (oversteer).
Personally, I started with both Sport mode and VSC Sport mode on in the beginning. Now, short of doing the pedal dance, I drive with Traction Control and Stability Control off and shift almost exclusively with the paddles or the shifter. I felt that the car would intervene too early and too much. The only time I switch back is during really horrible weather.
Demandred7 is offline   Reply With Quote
The Following User Says Thank You to Demandred7 For This Useful Post:
MVJ1975 (07-08-2014)
Old 07-08-2014, 12:05 PM   #4
LLYNCES
LLYNCES's Avatar
Drives: 13 Firestorm/UltramarineRIP/15 Halo
VSC sports mode lets you slip a bit more.
Sports mode just lets you rev higher while in auto. Seems pointless if you're shifting yourself.
LLYNCES is offline   Reply With Quote
Old 07-08-2014, 12:11 PM   #5
Jyn
Noob
Jyn's Avatar
Drives: FR-S Mammogram
Sport mode: Wanna have a little fun with higher revs/etc. without using the pedal shifter.
VSC Sport mode: Allows a little more slippage in the rear before TCS kicks in. Still pretty relaxed.
I think a lot of people will just drive in Sport mode if they don't wanna use the paddle shifters, then switch VSC Sport on if they're in paddle shifter mode for max fun, yo.
Jyn is offline   Reply With Quote
Old 07-08-2014, 12:35 PM   #6
fitcious
i don't have the owner's manual with me right now, but i don't think you can turn on VSC Sport without having TSC turned off? If that's the case, will TCS still kick in?
fitcious is offline   Reply With Quote
Old 07-08-2014, 01:51 PM   #7
Jyn
Noob
Jyn's Avatar
Pressing VSC Sport will light the TCS light, but it will still kick in - just after a little more slippage. It is there to indicate that "hey, TCS is not operating at full capabilities." If you'd like proof, find a parking lot and turn the wheel all the way to the left or right and hit the gas with VSC Sport on. Then stop and hold the traction control until it turns the stuff off and do the same thing. You should be spinning a lot more now
Old 07-08-2014, 01:51 PM   #8
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
Putting it in Sport mode and then putting it in manual equates to faster shift speeds.
Old 07-09-2014, 03:26 AM   #9
F1fletch
F1fletch's Avatar
Drives: 13 FR-S AT
That's what I had understood but this thread seems to contradict that.
http://www.ft86club.com/forums/showthread.php?t=69279
F1fletch is offline   Reply With Quote
Old 07-09-2014, 01:42 PM   #10
finch1750
finch1750's Avatar
Interesting. I will have to read that a bit more in depth and see for myself. To me its felt crisper but I have never done them back to back to back with all the variations.
Down side to driving in sport mode 90% of the time? BRZlimited BRZ First-Gen (2012+) — General Topics 18 05-24-2014 08:32 PM
Winter/Dirty mode / daily driver randoms Rayme FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 1 01-03-2014 11:45 AM
is it possible to rejigger the auto manual mode shifter to flip gear up/down? chickdigger802 BRZ First-Gen (2012+) — General Topics 14 10-18-2013 09:17 PM
Keeping it in Sport Mode (auto tranny) Burrcold Engine, Exhaust, Transmission 49 07-25-2013 04:40 PM
Best Manual transmission driving techniques? rawbz Other Vehicles & General Automotive Discussions 24 05-23-2012 01:15 PM
