#29 |
Drives: 13' SSM BRZ
#30 |
Drives: Scion FRS Ht Lva(AT)
Depends on where you live some places have weird residential curb entries to houses. I cannot back straight out because when the front wheels drop down the sharp ramp, the momentum bounce is enough to bottom the car. I have to back out one front wheel at a time. Then its OK, but another inch in the snow can be useful on streets that don't get plowed, except for the bus routes!
#31 |
sleep, drive, eat, repeat
Drives: '13 BRZ, '12 Outback
Very old thread to resurrect, but I figured this is the most appropriate place for it. I'm also looking for a way to slightly increase my ride height since I live in a not so low car friendly neighborhood. I've done quite a bit of research on height adjustable after market coil overs but all of them seem to be lower than stock at the highest setting.
#32 | |
Drives: Nissan Versa
#33 |
#34 |
Apparently HKS can too by about +20mm
Edit: Oh wait nvm... factory height is HKS factory preset height =_=; Srry... |
#35 |
Drives: Subaru BRZ Sport Tech Satin White
I think the BRZ has a ground clearance of 5.9 inches which is pretty normal for a passenger car. It only looks low, it's actually pretty normal height.
#36 |
Drives: 2012 Toyota 86
haha i got a kick ouf the the guys telling the dude from alaska about winter driving. good stuff. thanks for resurrecting this
#37 | |
![]() I've used a set of these on my wrx in the past with little trouble (to get that little bit of extra height to survive those ruts from weekend rallyx's). Haven't heard of anybody using them here or in other forums. Seems like they just took their wrx and outback kits. Agreed, but in my case, regular passenger cars (like my brother's civic) still scrape. Basically, my driveway dips down to my garage, which is below my house. I slightly high-center/scrape my mid pipe going over the sidewalk on my way down to the garage. |
#38 |
Señor Member
1974 TA22 Celica
2013 86 GT |
#39 |
*****istrator
Drives: 2013 Scion FR-S 10-Series M/T
i personally wouldn't get coilovers since their damper settings are likely to be much stiffer than stock and the ride quality simply goes out the door! for a place like alaska, i'd guess you would want to avoid wheel hop after hitting a bump while keeping as much weight on the tires to maintain maximum traction.
i would look at alternative (taller) springs from other cars that fit the stock shocks/struts to get the added ride height, while keeping the stock dampers. also, those top strut mount spacers are a good idea.
SC10N FR-S #435 of 2500
#40 | ||
#41 | ||
Señor Member
1974 TA22 Celica
2013 86 GT |
#42 |
turbo turtle
Drives: exit GT86 enter STI
Bump! any solution with coilovers with extra height or stock road height?
| RS*R Sports-i Coilover system installed (pics) | R0ME0 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 139 | 02-05-2015 03:38 PM |
| BRZ/FR-S Trunk Height? | ngabdala | Scion FR-S / Toyota 86 GT86 General Forum | 1 | 05-24-2012 01:41 PM |
| Stock ride height or lower? | StevenDavisPhoto | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 156 | 01-31-2012 10:58 AM |
| Lower ride height in NYC? | blur | NY / NJ / CT / PA | 9 | 01-19-2012 06:31 PM |
| quick question about the height.. | VenomRush | Scion FR-S / Toyota 86 GT86 General Forum | 13 | 12-22-2009 10:42 PM |
