Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > FT86CLUB Shared Forum > Regional Forums > CANADA > Canada Classifieds
Old 07-05-2014, 11:16 AM   #1
FRSToyota86
FRSToyota86's Avatar
Drives: 2013 Scion FRS
Limited Slip diff oil Motul GEAR 300 LS 75W-90
I have 3 liters of Motul GEAR 300 LS 75W-90 limited slip differential oil. Picked them up in US. Not avaible in Canada other wise.
Local pick up in Ottawa. Paid $90 then I had to drive down to pick them up. asking $90 for the 3lt.
The diff capacity is 1.2 lt. This will be good for two fluid change.
Thank you.
Vortech V3 Supercharger| 12 PSI|E85 MotoEast Flexfuel kit|Crawford AOS| Mishimoto Oil Cooler|3"Perrin Resonated CBE| 3" JDL Front/Over Pipe|OpenFlash Performance Headers|Exedy Stage 2 Ceramic Clutch |Yonaka Coilovers|17x9 O.Z. Wheels| 245/40r/17|TRD Brake Pads|Perrin Master Cylinder Brace |ChaseBay SSBrake Lines|CF Side Fins|OEM Shark Fin Athena|Yospeed Console Plaque|R/T Shift Knob|Fog Lights|Backup Camera|Navigation| |TRD Quickshifter|Motul Gear Oil|
FRSToyota86 is offline   Reply With Quote
Old 07-05-2014, 08:15 PM   #2
PMPB
Drives: BRZ Sport-tech
That's not the right stuff for our diff's. We don't need LS (which has a friction modifier) which is for clutch type diff's.
PMPB is offline   Reply With Quote
The Following 2 Users Say Thank You to PMPB For This Useful Post:
FRSToyota86 (07-07-2014), Reaper (07-05-2014)
Old 07-05-2014, 08:17 PM   #3
Reaper
in orbe terrum non visi
Reaper's Avatar
Drives: violent
Yup
Old 07-06-2014, 10:28 PM   #4
that_guy
Dances with Cones
that_guy's Avatar
Drives: 2013 Scion FR-S Raven
^Actually the stock fluid has a friction modifier. Either can be run but the LS is preferred.
http://www.motul.com/fr/en/products/recommendation
I run the LS in mine and compared to the non-LS which I ran in my last FR-S, the rear end is much smoother and a lot less chatter.
Hate to say it though, but you can get this in Canada. The main distribution center is in Vaughan.
2013 Scion FR-S - Raven
2011 Scion tC - Cement - SOLD
that_guy is offline   Reply With Quote
The Following User Says Thank You to that_guy For This Useful Post:
Old 07-07-2014, 12:49 PM   #5
FRSToyota86
its the right fluid.
Old 07-07-2014, 12:51 PM   #6
FRSToyota86
Thank you sir.
You can not get this in Canada as per distributors of Motul and contacts provided by Motul. Please feel free to contact Motul and their distributors.
Old 07-07-2014, 02:28 PM   #7
that_guy
Dances with Cones
that_guy's Avatar
Call Performance Improvements. They can get it. Just got 3L myself a few months back.
They order through a US distributor, though, which could be how they get around it.
Old 07-07-2014, 02:43 PM   #8
sluflyer06
Drives: 2014 BRZ Ltd - DGM
This has been beaten to death across more than this forum. Torsens do not require friction modifiers, there are no benefits to having that additive package in our differential.
Straight out of the shop manual:
Rear differential gear oil Differential gear oil LX or GL-5 standard
(note LX is Toyota's branded rear diff oil)
2014 BRZ Ltd. - DGM
E30 318is trackday funday car
E46 323ci vert
sluflyer06 is offline   Reply With Quote
The Following 2 Users Say Thank You to sluflyer06 For This Useful Post:
DieselDog (09-07-2014), PMPB (07-07-2014)
Old 07-07-2014, 10:26 PM   #9
that_guy
Dances with Cones
that_guy's Avatar
Your right, it has been beaten to death. But telling the guy selling that he's wrong based on a bunch of forum banter is not helping.
If you read about Toyota fluids, LT is for non-LSD and LX is for LSD equipped vehicles. Since this car is sold with and without (depending on where it is sold in the world), the specifications call for LT on non and LX on those with LSD's. Don't you think Toyota would do that for a reason? If the viscosity is the same, then there must be something else in it! That folks is called a friction modifier, which by design is to minimize or eliminate chatter, noise, vibration, and harshness (that's right out of the Toyota fluids guide ) produced from vehicles equipped with an LSD. You don't need clutches to get chatter. That will come naturally when the car attempts to "limit slip" between both drive wheels. LSD's are not buttery smooth. They are gears at the end of the day and will bind, hence the chatter.
GL-5 is just a general standard for gear lubes (GL stands for Gear Lubricant). It just defines that an oil may contain up to a specific amount of anti scuffing (read: anti wear) contents as required for severe applications. This is generally why all performance fluids for drivetrain are GL-5. Even engine oils have this. Differentials are rated at GL-5 or above because of the shock loads they take, therefore classing them as more severe applications.
Now, again, will it hurt? Probably not. But the friction modifier is recommended for a reason and having personally driven this car with both installed, I can honestly tell you that the rear end is significantly smoother and more consistent with the Gear 300 LS than without.
I don't want to turn this into a pissing match, though, I just want to advise some people here who are providing false advise and potentially limiting this person's ability to sell what he's posted. At the end of the day, put rocks in your rear end for all I care. But for those that want to do it right, the Motul Gear 300 LS is a great choice.
The Following 4 Users Say Thank You to that_guy For This Useful Post:
Bonburner (10-09-2018), Bristecom (03-10-2018), FRSToyota86 (07-08-2014), microSDHC (12-30-2018)
Old 07-08-2014, 07:41 AM   #10
Ferrari
Ferrari's Avatar
Drives: Taking the bus
that_guy, thanks for the great explanation.
FRSToyota86, I'll be in Ottawa next weekend, I'll PM you then as I might want those bottles.
Ferrari is offline   Reply With Quote
The Following User Says Thank You to Ferrari For This Useful Post:
Old 07-21-2014, 12:35 PM   #11
FRSToyota86
Its still available. new price $80
Old 07-27-2014, 07:09 PM   #12
Ferrari
Ferrari's Avatar
You have PM
Old 08-22-2014, 01:47 PM   #13
FRSToyota86
$80 obo
Its good for two fluid flushes
Trans/diff fluid recommendations: Motul Gear 300, Extra-S, or.. B-R-Z Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 1 07-03-2014 09:06 PM
Where to get Motul Gear 300 in the GTA? automatic CANADA 5 04-09-2014 05:48 PM
No Motul Gear 300?? markmatley Hawaii 14 04-17-2013 09:59 PM
Explain the benefits of limited slip diff? veuxx Engine, Exhaust, Transmission 11 03-22-2013 09:48 PM
Is it really a Limited Slip Diff ?? 000 Racing AUSTRALIA 24 11-28-2012 06:56 PM
