Old 07-04-2014, 01:35 PM   #15
Khyron686
Drives: 2011 Outlander XLS, 2013 FR-S Blue
Originally Posted by shiv@vishnu View Post
As always, after your flash your ecu, start the engine and let it idle for a minute before touching the throttle or driving off. If not you may run into a no-VVT mode which feels sluggish.
Ok I'm flashed (haven't taken it out of the garage as the kids are home) - and I've requested dyno time.
If I do a base run or two with the ESC turned off, any issues running the new map (aside from probably a bit rich)? I'd rather not flash back to the OFH stage2 map if I don't need to.
Thx again Shiv!!
Khyron686 is offline   Reply With Quote
The Following User Says Thank You to Khyron686 For This Useful Post:
Shiv@Openflash (07-05-2014)
Old 07-04-2014, 01:36 PM   #16
jflogerzi
jflogerzi's Avatar
Shiv is the man even on the 4th!
The Following 3 Users Say Thank You to jflogerzi For This Useful Post:
DC2R (07-05-2014), raven1231 (07-04-2014), Shiv@Openflash (07-04-2014)
Old 07-04-2014, 02:21 PM   #17
raven1231
Thx again Shiv!!
I would imagine accuracy as far as comparison goes would be an issue but as far as problems running it I'm not sure.
Old 07-04-2014, 05:20 PM   #18
nlowell
nlowell's Avatar
Drives: 2013 Scion FRS
Wow Shiv, these are some smooth tunes! The AFR spike under 4k is gone. I loaded the 91 tune and let the car run for a good 10-15 minutes before driving off. I don't see any knock so I bet I could go 93 if I added some Torco (not running any currently).
DataZap Log Link
2nd Gear Pull:
AFR:
Boost:
3rd Gear Pull:
AFR:
Boost:
nlowell is offline   Reply With Quote
The Following 5 Users Say Thank You to nlowell For This Useful Post:
Boofneenee (07-04-2014), DAEMANO (07-04-2014), Khyron686 (07-04-2014), Shiv@Openflash (07-04-2014), WRB5titch (07-04-2014)
Old 07-04-2014, 06:17 PM   #19
Boofneenee
Go-Kart Enthusiast
Boofneenee's Avatar
Drives: Toyota Scion FRS
Wih this new tune and the openflash headers would the car run lean? If i understand it this tune is for stock headers?
FRS
Current mods: K&N air filter, OFT, OFH, berk high flow cat front pipe, Q300 exhaust, lighter wheels
Boofneenee is offline   Reply With Quote
Old 07-04-2014, 06:28 PM   #20
fenton
No it is for openflash header users. If you have a stock headers you just don't get some of the benefits the header adds to the powerband. It still works with stock headers.
There is tuning to take advantage of the header...
fenton is offline   Reply With Quote
The Following 2 Users Say Thank You to fenton For This Useful Post:
Boofneenee (07-04-2014), skye67 (07-19-2014)
Old 07-04-2014, 07:15 PM   #21
DAEMANO
Time Traveller
@shiv@vishnu
First log - 2nd gear to 3rd gear WOT - Apx 94-96 Octane on Torco Acellerator
Oh also 90 degrees F in So Cal with 50% humidity at about 400ft above sea level.
http://datazap.me/u/daemano/daes-frs...&data=1-2-8-12
AFR
BOOST
Last edited by DAEMANO; 07-04-2014 at 07:36 PM. Reason: Added screenshots + weather data
Old 07-04-2014, 07:25 PM   #22
Shiv@Openflash
Shiv@Openflash's Avatar
Drives: 2013 FRS
Originally Posted by DAEMANO View Post
@shiv@vishnu
Looks fantastic quite frankly.
Shiv@Openflash is offline   Reply With Quote
The Following User Says Thank You to Shiv@Openflash For This Useful Post:
Old 07-04-2014, 07:33 PM   #23
DAEMANO
Time Traveller
Due to your hard work! AND of course Robs.
This is why I go to bat for you here and in the Miata forums. Keep the hits coming man!
The Following 2 Users Say Thank You to DAEMANO For This Useful Post:
Old 07-04-2014, 07:34 PM   #24
jflogerzi
jflogerzi's Avatar
@nlowell Your holding 2LBs PSI till redline. Thats not bad at all
The Following User Says Thank You to jflogerzi For This Useful Post:
Old 07-04-2014, 08:03 PM   #25
raven1231
I'm loving the tune as well thanks as always shiv!
Here is my 3rd gear pull on 93 octane
http://datazap.me/u/raven1231/jeffs-...og=0&data=1-12
Old 07-04-2014, 08:06 PM   #26
Sojhinn
Lightning McQueen Driver
Sojhinn's Avatar
Drives: Limited Red 6MT BRZ
You guys are making me jealous. I'm in Disneyland and can't play with my car. But then again I'm at Disneyland!
Installed Mods:
The Following 2 Users Say Thank You to Sojhinn For This Useful Post:
DAEMANO (07-04-2014), raven1231 (07-04-2014)
Old 07-04-2014, 08:14 PM   #27
Khyron686
Here's my first datalog ever, 3 3rd gear pulls with a 2nd gear at the end.
I didn't know you had to do something on the OFT to add boost - will do that next time.
http://datazap.me/u/khyron/2014-07-0...9&mark=347-252
The fact that it goes flat at AFR 11.02 makes me think the logging isn't catching lower - should I be concerned?
Old 07-04-2014, 08:15 PM   #28
raven1231
Yeah I was at work all day anticipating flashing the car lol
The Following 2 Users Say Thank You to raven1231 For This Useful Post:
DAEMANO (07-04-2014), Sojhinn (07-04-2014)
Phantom TQ250 Dyno FBO (Dual Battery Pack) Shiv@Openflash Forced Induction 23 04-29-2014 02:40 AM
Clutch dump at 5000 RPM? fasteddy BRZ First-Gen (2012+) — General Topics 20 08-22-2013 01:55 PM
External dump and under tray? mrk1 Forced Induction 5 07-30-2013 09:43 AM
Photo dump. CanibeatNoel FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 11 07-17-2013 02:47 AM
Ricepuddin Picture Dump Ricepuddin FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 15 12-03-2012 12:18 AM
