Old 07-04-2014, 12:51 PM   #43
jonbonazza
Originally Posted by nelsmar View Post
How long ago did you receive your last update? Considering you were not done with your etune is there a reason you didn't ask your tuner about this CEL? You also have a fair bit of knock correction going on throughout that log. I honestly can't remember how well that intake functions with tuning. Do you have the AEM module plugged in or are you bypassing it and just using the straight maf sensor?
I flashed the last tune in may. I just havent had time to do the logging, really, but i figured after 4 revisions it would be pretty much done.
The CEL just came on when i posted this thread and i didnt know the tune was at fault (really, i still dont). I have had 2 track daus on this tune and probably 1000 miles of normal driving with no cel.
Edit: im bypassing the aem module as instructed by the tuner.
jonbonazza is offline   Reply With Quote
Old 07-04-2014, 01:08 PM   #44
nelsmar
I wouldn't assume it was done being tuned until he tuner says it was. Your maf and ignition table needs some tweaking. Your fuel trims are swinging at times and can be triggering that cel. And the knock feedback could be caused by unfinished maf calibration or too aggressive ignition timing. Your power is being reduced currently from the global ignition pullback due to knock being seen at the 2800-3600 range.
It is not uncommon for 5-10 revisions to be required to dial in a tune.
My flickr - Canibeat
Local magazine scout
Old 07-04-2014, 01:10 PM   #45
jonbonazza
Thanks for the info. Ill get some logs and get a hold if the tuner then. Im just worried about doing 2nd gear pulls at WOT with the current tune running lean.
Old 07-04-2014, 01:29 PM   #46
nelsmar
Its hard to tell if you are actually running lean in WOT without seeing a log. WOT and partial throttle are going to have different voltages from the maf so the calibration may just be off on the low end, and not the high end. You have to also realize your car will run in closed loop where it targets a specific afr (should be around 14.5-15AFR) using the oem o2 sensor until the ecu decides it needs to run open loop where it stops using the o2 sensor and just uses its actual maps to calculate how much fuel to add. So the 15 AFR you are seeing during partial throttle can be completely normal until the throttle goes all the way down.
Old 07-04-2014, 01:39 PM   #47
m.wood0213
Driving Enthusiast
m.wood0213's Avatar
Drives: 2013 BRZ Limited
I got the same code but too rich on bank one any my only mod was AEM intake. Seems to be some problems here.
“This isn’t a supercar, it’s a sports car. It sacrifices rear seats yes but it just feels alive. Pure, direct, immediate. The other two are going to get all the admiring looks yes, that’s my point. I’m not driving around in this for other people’s benefit. I’m driving around in this BECAUSE I LOVE DRIVING IT. END!”
-Richard Hammond, Top Gear, USA Supercar Road Trip, 2011 Porsche GT3 RS.
My BRZ
m.wood0213 is offline   Reply With Quote
Old 07-04-2014, 01:51 PM   #48
jonbonazza
Here are my latest set of 2nd gear pulls. Things actually look much better here:
http://datazap.me/u/jonbonazza/logs3...0&data=9-10-25
EDIT: Still a lot of knock correction, though.
Old 07-04-2014, 02:50 PM   #49
jonbonazza
I got the "too rich bank 1" code when i was running the intake w/o a tune.
Old 07-04-2014, 03:14 PM   #50
nelsmar
Your AFR is safe in that log. However you are seeing knock correction in a few spots. But its hard to see how much learned knock there is without knowing the exact targets.
The Following User Says Thank You to nelsmar For This Useful Post:
jonbonazza (07-04-2014)
Old 07-04-2014, 03:49 PM   #51
jonbonazza
Okay, well I just reflashed the latest tune (revision 4) just in case I accidentally flashed the wrong one before and then took logs of:
-10min of normal driving
- 2x second gear pulls
Here is the link:
http://datazap.me/u/jonbonazza/r4-logs?log=0&data=5
Old 07-04-2014, 04:31 PM   #52
nelsmar
Here is the link:
Check your car for vacuum leaks. Verify your MAF o-ring is clean and the maf is secure. Verify that the coupling to the throttle is tight. If you have a catch can verify all fittings are clean and tight and anything else post MAF that has been altered from the factory. If you are still having problems then your maf curve is off by a fair bit.
Old 07-04-2014, 06:42 PM   #53
jonbonazza
So i have done two driving sessions since reflashing the ecu and still no code. I have no idea whats going on lol. At any rate, i sent the new logs to the tuner, so hopefully things will be okay
Old 07-04-2014, 06:55 PM   #54
steve99
Drives: FT86
good advice, his tuner should be helping out too
Old 07-04-2014, 07:20 PM   #55
steve99
Drives: FT86
your tuner should be sorting out the maf scaling for you if you don't have any vacuum leaks ect
however if you want to know/understand what he is up to , or even do it yourself see here
www.ft86club.com/forums/showthread.php?t=64790
use the vgi utility if you decide to do it makes it quite easy
Old 07-05-2014, 02:36 AM   #56
steve99
Drives: FT86
Here is the link:
That last log does not look to bad at all AFR at higher rpm looks a bit on the rich side at 11.2 at 5000rpm for an NA car.
The maf scaling looks ok except for around idle 700-800 rpm it 30% which is max allowed from memory
You have a bit of the dreaded throttle tip in knock pulling about -2 degrees 2000-3000 when you get on the gas.
tuner should sort that next round hopefully. tip in enrichment, transient retard and or pull some base timing in that load rpm range. It pretty hard to eliminate but should be able to get it down to -0.6 or so.
jonbonazza (07-05-2014)
lean at idle only woode Forced Induction 5 05-03-2014 05:48 PM
PO171 SYSTEM TOO LEAN BANK 1 rmdrag0n Engine, Exhaust, Transmission 23 03-02-2014 01:50 AM
Recommendation for lightweight wheels without breaking the bank ayau Tracking / Autocross / HPDE / Drifting 6 11-08-2012 03:23 PM
Bank Robbers Throw Money In Police Chase travace Off-Topic Lounge [WARNING: NO POLITICS] 5 09-13-2012 02:00 PM
Scion FR-S FIRST DRIVE Tour in Baltimore at M & T Bank Stadium ft86Fan Scion FR-S / Toyota 86 GT86 General Forum 3 04-29-2012 08:43 PM
