#43 | |
The CEL just came on when i posted this thread and i didnt know the tune was at fault (really, i still dont). I have had 2 track daus on this tune and probably 1000 miles of normal driving with no cel. Edit: im bypassing the aem module as instructed by the tuner. Sent from my Nexus 5 using Tapatalk |
#44 | |
It is not uncommon for 5-10 revisions to be required to dial in a tune.
When I grow up, I wanna be God. My flickr - Canibeat Local magazine scout Old Setup: Vortech Supercharged 360WHP/262WTQ @ 11.5psi My build thread - WTF happened to nelsmar's car thread |
#45 | |
#46 |
Its hard to tell if you are actually running lean in WOT without seeing a log. WOT and partial throttle are going to have different voltages from the maf so the calibration may just be off on the low end, and not the high end. You have to also realize your car will run in closed loop where it targets a specific afr (should be around 14.5-15AFR) using the oem o2 sensor until the ecu decides it needs to run open loop where it stops using the o2 sensor and just uses its actual maps to calculate how much fuel to add. So the 15 AFR you are seeing during partial throttle can be completely normal until the throttle goes all the way down.
#47 |
Driving Enthusiast
Drives: 2013 BRZ Limited
I got the same code but too rich on bank one any my only mod was AEM intake. Seems to be some problems here.
“This isn’t a supercar, it’s a sports car. It sacrifices rear seats yes but it just feels alive. Pure, direct, immediate. The other two are going to get all the admiring looks yes, that’s my point. I’m not driving around in this for other people’s benefit. I’m driving around in this BECAUSE I LOVE DRIVING IT. END!”
-Richard Hammond, Top Gear, USA Supercar Road Trip, 2011 Porsche GT3 RS.My BRZ |
#48 |
Here are my latest set of 2nd gear pulls. Things actually look much better here:
http://datazap.me/u/jonbonazza/logs3...0&data=9-10-25 EDIT: Still a lot of knock correction, though. |
#49 |
#50 | |
| The Following User Says Thank You to nelsmar For This Useful Post: | jonbonazza (07-04-2014) |
#51 | |
-10min of normal driving - 2x second gear pulls Here is the link: http://datazap.me/u/jonbonazza/r4-logs?log=0&data=5 |
#52 | |
#53 |
So i have done two driving sessions since reflashing the ecu and still no code. I have no idea whats going on lol. At any rate, i sent the new logs to the tuner, so hopefully things will be okay
#54 | |
Drives: FT86
#55 | |
Drives: FT86
however if you want to know/understand what he is up to , or even do it yourself see here www.ft86club.com/forums/showthread.php?t=64790 use the vgi utility if you decide to do it makes it quite easy |
| The Following User Says Thank You to steve99 For This Useful Post: | jonbonazza (07-04-2014) |
#56 | |
Drives: FT86
That last log does not look to bad at all AFR at higher rpm looks a bit on the rich side at 11.2 at 5000rpm for an NA car. The maf scaling looks ok except for around idle 700-800 rpm it 30% which is max allowed from memory You have a bit of the dreaded throttle tip in knock pulling about -2 degrees 2000-3000 when you get on the gas. tuner should sort that next round hopefully. tip in enrichment, transient retard and or pull some base timing in that load rpm range. It pretty hard to eliminate but should be able to get it down to -0.6 or so. |
| The Following User Says Thank You to steve99 For This Useful Post: | jonbonazza (07-05-2014) |
| lean at idle only | woode | Forced Induction | 5 | 05-03-2014 05:48 PM |
| PO171 SYSTEM TOO LEAN BANK 1 | rmdrag0n | Engine, Exhaust, Transmission | 23 | 03-02-2014 01:50 AM |
| Recommendation for lightweight wheels without breaking the bank | ayau | Tracking / Autocross / HPDE / Drifting | 6 | 11-08-2012 03:23 PM |
| Bank Robbers Throw Money In Police Chase | travace | Off-Topic Lounge [WARNING: NO POLITICS] | 5 | 09-13-2012 02:00 PM |
| Scion FR-S FIRST DRIVE Tour in Baltimore at M & T Bank Stadium | ft86Fan | Scion FR-S / Toyota 86 GT86 General Forum | 3 | 04-29-2012 08:43 PM |
