Old 07-04-2014, 09:07 AM   #15
CruiseZen
CruiseZen's Avatar
Drives: 2014 Ultramarine 6MT FR-S Monogram
That's one weird problem. Sounds like it's time to go to the dealer for some warranty work.
Borla axleback exhaust * mud guards * Michelin Pilot Super Sport tires * Opti-Coat * BRZ trunk lid liner * Rexpeed Wide Mirrors (heated)
CruiseZen is offline   Reply With Quote
Old 07-04-2014, 10:11 AM   #16
Pish
#teamswagoi
Pish's Avatar
Drives: 2014 Raven FR-S Monogram
You didn't happen to leave your spare fob in your car did you ?
Pish is offline   Reply With Quote
Old 07-04-2014, 10:33 AM   #17
TONYpepperon1
TONYpepperon1's Avatar
Drives: 2013 CBS BRZ
Yea I think I might have to. Gotta find time though.
No its in my house.
TONYpepperon1 is offline   Reply With Quote
Old 01-05-2018, 03:05 PM   #18
Pwolf
Pwolf's Avatar
Drives: 2013 GBS BRZ Limited
This just started happening to me a few days ago, any update on what the problem was?
Pwolf is offline   Reply With Quote
Old 01-05-2018, 03:21 PM   #19
DandoX
Senior gif poster
DandoX's Avatar
Drives: 2013 Asphalt FRS
Originally Posted by TONYpepperon1 View Post
Bump
That is odd. If your sitting inside the car and the car is off and open the door to get out does do the same thing? Now if it does, next question is if it does it when you hit the fob to unlock vs unlocking the door manually from the switch? Final question does it act this way of you have your window down and then lock it and open it from the outside?
It may fix it if you try re setting your windows position, I forget the steps to do this. It's something like holding down the window button and turning the key to power on. It is listed in the manual.
Also double check the window trim all around where the window meets the rubber incase something is preventing the window from reaching the full up position.
DandoX is offline   Reply With Quote
Old 01-05-2018, 07:52 PM   #20
D-rek07
I have had a similar issue. I made a thread on it. See below for my original post. I never got any help on it.
I'm having trouble with the drivers door lock on my 2013 BRZ limited.
Here are the symptoms
When using the keyless entry on the drivers door: The car double beeps five times, unlocks the passenger door but doesn't unlock the drivers door.
When using the keyless entry on the passenger door: The passenger door unlocks but the drivers door doesn't. The car still does the double five beep.
When using the keyfob to lock/unlock the car: Only the passenger door locks/unlocks.
When using the door lock/unlock button on the inside door trim: Only the passenger door locks/unlocks.
The drivers door only locks using the manual lock on the door trim or the key hole and unlocks when doing the same.
I have done the 12v reset. Unhooking the battery. No change. I have tried both keyfobs with new batteries. I have checked all the fuses under the hood and under the dash.
D-rek07 is offline   Reply With Quote
Old 01-05-2018, 08:06 PM   #21
asdf
Loading...████████] 99%
asdf's Avatar
Drives: #0517
ran a random google search, seems like other toyota folks have run into this as well. couldn't find a solid answer, but some say it was due to a lock mechanism on one of the doors or trunk failing/sticking/some other issue when trying to lock/unlock.
nobody has taken the car to the dealer for further inquiry? curious about solution.
R1 3 5
. 2 4 6
asdf is offline   Reply With Quote
Driver door alignment issue--fixed kingping Issues | Warranty | Recalls / TSB 14 03-26-2019 10:46 AM
Small window door issue (rubber seal) Subforever Issues | Warranty | Recalls / TSB 7 05-20-2013 06:32 AM
Automatic Door Lock/Unlock - Do we have the option? RYU Electronics | Audio | NAV | Infotainment 17 10-04-2012 02:15 AM
Door Rattle Issue DriftEightSix AUSTRALIA 4 06-28-2012 02:11 AM
