#29 | |
Drives: FT86
see if the ltft are less than 10% and that the commanded AFR and measured AFR follow each other under load. If your ltft is over 10% under load and the commanded AFR and measured afr are way off then something is wrong. If maf scaling has been done correctly ltft should be less than 5% or possibly less than 3% under load. did the cel come back after ecu reset check for air leaks on intake and that maf sensor seated correctly and is clean, especially if you run an oiled filter Do you have ecutek map switching ? are you on correct map, you did not switch back to stock map or something ? |
#30 | |
Sent from my Nexus 5 using Tapatalk |
#31 |
@steve99 what can you gather from this ECUTek log? Looks fucked to me, but wanted to get another opinion...
https://www.sendspace.com/file/xosw4a EDIT: Is it possible to allow us to attach CSV files to posts? |
#32 | |
#33 |
#34 |
Your fuel trims are pretty bad....
Who is your tuner?
#35 |
Graham from FT86 SF. Its an etune that was still being worked on. Thats the 3rd or 4th revision.
#36 |
on what fuel?
#38 |
Can you also upload the previous logs you sent to him?
I am not quite sure what he is doing if this is the result of 3-4 revisions and your setup hasn't changed and haven't had any hardware issues.
#40 | |
Drives: FT86
might be worth pulling maf sensor and cleaning just in case |
#41 |
Now I am curious...
I have uploaded the first 3 logs (I only uploaded normal driving logs. I also have 2nd gear pulls if needed) http://datazap.me/u/jonbonazza/logs1-normal-driving http://datazap.me/u/jonbonazza/logs2-normal-driving http://datazap.me/u/jonbonazza/logs3...?log=0&data=10 |
#42 |
How long ago did you receive your last update? Considering you were not done with your etune is there a reason you didn't ask your tuner about this CEL? You also have a fair bit of knock correction going on throughout that log. I honestly can't remember how well that intake functions with tuning. Do you have the AEM module plugged in or are you bypassing it and just using the straight maf sensor?
When I grow up, I wanna be God. My flickr - Canibeat Local magazine scout Old Setup: Vortech Supercharged 360WHP/262WTQ @ 11.5psi My build thread - WTF happened to nelsmar's car thread |
| lean at idle only | woode | Forced Induction | 5 | 05-03-2014 04:48 PM |
| PO171 SYSTEM TOO LEAN BANK 1 | rmdrag0n | Engine, Exhaust, Transmission | 23 | 03-02-2014 12:50 AM |
| Recommendation for lightweight wheels without breaking the bank | ayau | Tracking / Autocross / HPDE / Drifting | 6 | 11-08-2012 02:23 PM |
| Bank Robbers Throw Money In Police Chase | travace | Off-Topic Lounge [WARNING: NO POLITICS] | 5 | 09-13-2012 01:00 PM |
| Scion FR-S FIRST DRIVE Tour in Baltimore at M & T Bank Stadium | ft86Fan | Scion FR-S / Toyota 86 GT86 General Forum | 3 | 04-29-2012 07:43 PM |
