Old 02-22-2014, 03:49 AM   #239
dradernh
Drives: Used to Drive:Grand-Am GS #54 E36M3
Coilover MCS
Front/Rate N/A*
Rear/Rate N/A*
Part# 1-Way Non-Remotes to 3-Way Remotes
MSRP $2750 to $7400
http://www.motioncontrolsuspension.c...ts/prices.html
* = unless a retailer has chosen spring rates for you (i.e., you're buying a kit), you'll choose your own rates
dradernh is offline   Reply With Quote
Old 02-25-2014, 12:11 PM   #240
scionfr_s
scionfr_s's Avatar
Drives: Scion FR-S
ISC coil???
scionfr_s is offline   Reply With Quote
The Following User Says Thank You to scionfr_s For This Useful Post:
ISC Suspension (04-01-2014)
Old 04-01-2014, 09:39 AM   #241
ISC Suspension
ISC Suspension's Avatar
Drives: ISC Suspension BRZ
Send a message via AIM to ISC Suspension
Originally Posted by WingsofWar View Post
Please post a reply in this topic if you have new information.
I need your help to complete the data in this list!
Need to determine how much your car has lowered?
Distance between hub center and top of fender opening
Front is 14 7/16" and rear is 14 5/8"
Need to convert the metric spring rate to standard?
http://tinyurl.com/kg-to-lb
Want to install your own coilovers or springs?
Strut Replacement/Coil Spring Install DIY
Need to determine your spring rates?
ridetech.com/info/spring-rate-calculator
Want more information on basic suspension tuning?
http://www.rapid-racer.com/suspension-tuning.php
Code:
SPRINGS             Front/Rate     Rear/Rate      Part #        MSRP
OEM Toyota 86       0.0"/2.3k      0.0"/3.3k      TBD           $---
OEM Toyota GT86 (EU)0.0"/2.3k      0.0"/3.3k      TBD           $---
OEM Scion FR-S M/T  0.0"/2.3k      0.0"/3.8k    F:SU003-04144   $83.90
                                                R:SU003-04147   $83.90
OEM Scion FR-S A/T  0.0"/2.3k      0.0"/3.8k    F:SU003-04145   $83.90
OEM Subaru BRZ M/T  0.0"/2.7k      0.0"/3.5k    F:20330CA010    $79.70
                                                R:20380CA010    $79.70
OEM Subaru BRZ A/T  0.0"/2.7k      0.0"/3.5k    F:20330CA020    $79.70
                                                R:20380CA010    $79.70
Code:
Eibach Pro-Kit      1.0"/3.6k      1.0"/4.9k      8210.5.140    $359
Eibach Sportline    1.4"/3.8k      1.4"/5.3k      4.10582       $359
Espelir Active GT   0.5"/3.2k      0.5"/5.0k      4536190109385 $TBD
Hotchkis Sport      1.0"/3.3k      1.0"/4.7K      19445         $221
Intrax              ---            ---            ---           $---
Mach V              0.7"/TBD       1.0"/TBD       TBD           $239
Race Comp Yellow    0.8"/4.5k      0.8"/4.5k      RCE-BRZ       $349
RS-R Down           0.5"/2.8k      0.5"/4.5k      T065D         $TBD
RS-R S/Down         1.0"/3.2k      1.2"/4.5k      T065S         $TBD
RS-R Ti2000 Down    0.5"/2.8k      0.5"/4.5k      T065TD        $TBD
RS-R Ti2000 S/Down  1.0"/3.2k      1.2"/4.5k      T065TS        $TBD
Swift Sport FRS     1.0"/3.0kg     1.0"/4.5kg     4T909         $399
Swift Sport BRZ     1.0"/3.8kg     1.0"/4.5kg     4F912         $399
STi Pink            0.6"/TBD       0.6"/TBD     F:ST20330AS000  $210.97
                                                R:ST20380AS000
Tein H-Tech *NOTE*  0.9"/2.9k      0.7"/4.8k      SKSA0-G1B00   $TBD
Tein S-Tech *NOTE*  1.2"/3.3k      1.0"/5.0k      SKQ54-AUB00   $280
TRD (same set on CO)0.6"/3.5k      0.6"/5.8k      MS260-18001   $548.00
*Red/bold links denote link to review topic on FT86club.com
Code:
COILOVERS           Front/Rate     Rear/Rate      Part #        MSRP_
AirREX Kit Basic    0.0-3.0"/--    0.0-3.0"/--    S-JP09006     $3575
AirREX Kit Digital  0.0-3.0"/--    0.0-3.0"/--    S-JP09006     $5155
Amuse Hi-Tech       TBD-TBD/8K     TBD-TBD/8K     TBD           $TBD$
Apex'i N1          +1.6-2.4"/10k  +0.8-2.0"/8.0k  264CT090      $TBD$
Blitz Damper ZZR    0.0-2.0"/6.0k  0.0-2.0"/4.0k  TBD           $TBD$
BC Racing BR-Type   TBD-TBD/TBD    TBD-TBD/TBD    TBD           $TBD$
BuddyClub D1 Damper     TBD/9k      TBD/7k   BC02-D112ZN6  $1549 **(solid upper mounts)
BuddyClub RSpec Damper    TBD/9k    TBD/7k   BC02-RSD12ZN6 $1799 **(pillow ball, w/ upper camber adjust.)
Cusco Spec-A        0.2-1.4"/4.5k  0.4-2.0"/5.0k  96560JCB      $1707
Cusco Zero-A       +1.0-1.4"/5.0k +1.0-2.0"/5.0k  96560NCN      $2374
Cusco Zero-A w/PB  +1.0-1.4"/5.0k +1.0-2.0"/5.0k  96560NCP      $2640
D2 Racing RS        0.5-3.5"/7.4k  0.5-3.0"/5.0k  D-SC-06       $1525
DG-5                TBD-TBD/TBD    TBD-TBD/TBD    TBD           $TBD$
Fortune Auto 500    TBD-TBD/6.0K   TBD-TBD/7.0K   TBD           $1149
Fortune Auto 510    TBD-TBD/8.0K   TBD-TBD/8.0K   TBD           $1499
Ground Control Kit  1.0-1.5"/6.7K  1.0-2.5"/7.7K  TBD           $TBD$
HKS Hipermax IV     0.0-2.8"/6.0k  0.0-3.0"/4.0k  80230-AT001   $2250
HKS Hipermax IV GT  TBD/8.0k       TDB/6.0k       80230-AT001V  $2350
JRZ RS1             TBD-TBD/CSTM   TBD-TBD/CSTM   TBD           $TBD$
KSport Kontrol Pro  0.5-3.5"/7.5k  0.5-3.0"/6.3k  CSC080-KP     $1600
KW Variant 3        0.8-2.0"/6.1k  0.8-2.0"/7.1k  35258004      $2299
KW Street          TBD-TBD/CSTM   TBD-TBD/CSTM   TBD           $TBD$
Megan Street        TBD-TBD/8.0    TBD-TBD/6.0    MRCDKSFR12    $999
Megan Track         TBD-TBD/10.0   TBD-TBD/8.0    MRCDKSFR12TS  $999
Nitron NTR          TBD-TBD/TBD    TBD-TBD/TBD    TBD           $TBD$
Ohlins BTO         +0.2-1.2"/9.0k +0.2-1.0"/7.0k  TBD           $3674.88
PRS Soft            TBD-TBD/6.0K   TBD-TBD/6.0K   TBD           $TBD$
PRS Medium          TBD-TBD/8.0K   TBD-TBD/8.0K   TBD           $TBD$
PRS Hard            TBD-TBD/10.0K  TBD-TBD/10.0K  TBD           $TBD$
RS*R iSport Soft   +0.6-1.6"/5.0k +1.2-3.2"/6.0k  SPIF065S      $TBD$
RS*R iSport Std    +0.6-1.6"/6.0k +1.2-3.2"/7.0k  SPIT065M      $$1799
RS*R iSport Hard   +0.6-1.6"/7.0k +1.2-3.2"/8.0k  SPIF065H      $TBD$
Sachs (no model)    TBD-TBD/TBD    TBD-TBD/TBD    TBD           $TBD$
Stance (no model)   TBD-TBD/TBD    TBD-TBD/TBD    TBD           $TBD$
Standard ENR        0.0-3.0"/CSTM  0.0-2.8"/CSTM  SC01I2        $4595
Standard R3         0.0-3.0"/TBD   0.0-2.8"/TBD   SC01R3        $1795
Standard R7         0.0-3.0"/TBD   0.0-2.8"/TBD   SC01D7        $2095
Standard R7-TA      0.0-3.0"/TBD   0.0-2.8"/TBD   SC01T7        $2095
Suivax Standard     TBD-TBD/7.0k   TBD-TBD/5.0k   TBD           $TBD$
Suivax 86 Edition   TBD-TBD/8.0k   TBD-TBD/6.0k   TBD           $TBD$
Tanabe Sustec Pro Z40  1.8"/5.0k    1.8/5.0k    TSE4166           $2,190.00
Tein M/Flex *NOTE*  0.2-1.8"/8.0k +0.2-2.8"/9.0k  GSQ54-F1SS1   $TBD$
Tein Street *NOTE*  TBD-TBD/TBD    TBD-TBD/TBD    TBA           $TBD$
Tein T/Flex *NOTE* +0.1-2.2"/7.0k +0.1-2.5"/7.0k  DSQ54-61SS1   $TBD$
TRD FRA Set      0.6"/3.5K   0.6"/5.8K   MS260-18001           $3289
XYZ Super Sport     TBD-TBD/TBD    TBD-TBD/TBD    TBD           $TBD$
*K-Sport SCS080-KP (FR-S) and CSB200-KP (BRZ) are identical
*AirREX S-JP09006 (FR-S), S-JP07010 (BRZ) and S-JP01027 (GT86) are identical
ISC Basic Coilovers Comfort or Sport Spring Rates: F - 10K R - 7K Part Number: S018B-C or -S MSRP: 1150 Includes solid top plates
ISC N1 Coilovers Comfort or Sport Spring Rates: F - 10K R - 7K Part Number: S018-C or - S MSRP: 1250 Includes Front Camber Plates with pillow-ball upper mounts and thrust bearings.
Race kit Spring Rates: F - 12K R - 8K Available with solid top plates with rubber bushings as well as top camber plate with pillow-ball upper mounts and thrust bearings. Part Number: S018B-R or S018-R MSRP: 1150 or 1250
ISC Suspension is offline   Reply With Quote
The Following User Says Thank You to ISC Suspension For This Useful Post:
WingsofWar (04-01-2014)
Old 04-07-2014, 01:54 AM   #242
imravenit
give us this day
imravenit's Avatar
Drives: AE86 - FRS
anybody know where i can get the TRD Springs for the frs? thanks in advance
imravenit is offline   Reply With Quote
Old 04-07-2014, 01:27 PM   #243
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
Originally Posted by Bomz View Post
Just a question
Better to post in the suspension Q&A thread tag team style by CSG and RCE
Old 07-01-2014, 06:51 PM   #244
chicagokid
Club Member
chicagokid's Avatar
Drives: 2014 Asphalt FR-S Monogram 6MT
Is it necessary for a 4 wheel alignment after a 1 inch drop and/or a rear chamber kit using eibach pro or Hotchkis or tein h tech? Sorry if already mentioned but I didn't see it.
chicagokid is offline   Reply With Quote
Old 07-01-2014, 07:37 PM   #245
jvincent
jvincent's Avatar
Yes.
Old 07-02-2014, 08:38 AM   #246
chicagokid
Club Member
chicagokid's Avatar
Thanks... but which one? or both? And if chamber kit needed. Which one to get and where? Thanks again!
Originally Posted by jvincent View Post
Yes.
Old 07-02-2014, 09:49 AM   #247
Racecomp Engineering
You don't necessarily need a camber kit.
I'd recommend the factory front camber bolts though since they're like 10 bucks and will help you even things out and make an improvement in handling.
For the rear, some rear lower control arms would be helpful but not required.
Either way you need an alignment to adjust toe (which can be done without changing/adding parts).
- Andy
Old 07-02-2014, 10:00 AM   #248
jvincent
jvincent's Avatar
General rule is if you are changing any aspect of your suspension setup, i.e. lowering, changing camber, etc., you should get an alignment.
I read your original question as do you need an alignment after installing a camber adjustment kit, not whether one was needed.
Old 07-02-2014, 04:16 PM   #249
chicagokid
Club Member
chicagokid's Avatar
Thank you....
Old 07-10-2014, 02:24 PM   #250
glorydays
Remember me?
glorydays's Avatar
Drives: BRZ Series.Blue
raceland coilover specs still being omitted?
glorydays is offline   Reply With Quote
Old 10-02-2014, 05:06 PM   #251
Shark_Bait88
Shark_Bait88's Avatar
Drives: 2013 Firestorm FR-S
If you want to update the information for the SACHS coilovers the information is here:
https://webcat.zf.com/index.asp?PKW=...teile_info.asp
The rates are
Front: 880kg
Rear: 945kg
Oh, and I believe that the model name is simply SACHS Performance Coilovers.
"Shark_Bait88, the man who’s spent the most money modding his stock FR-S and it’s still stock." -@jdnguyen
Shark_Bait88 is offline   Reply With Quote
Old 10-03-2014, 10:38 AM   #252
SMOKY
Drives: RX7
Which is good suspensions for daily use Blitz ZZ-R or TEIN Flex?
SMOKY is offline   Reply With Quote
brz aftermarket coilovers, brz aftermarket springs, brz coilover, brz coilovers, brz lowering springs, brz springs, brz suspension, fr-s coilover, fr-s coilovers, fr-s lowering springs, fr-s springs, fr-s suspension, frs coilover, frs coilovers, frs lowering springs, frs springs, frs suspension, scion fr-s coilover, scion fr-s coilovers, scion fr-s springs, subaru brz coilovers, subaru brz foru, subaru brz forums, subaru brz springs
Adjustable shocks+ springs vs Coilovers CyberFormula Suspension | Chassis | Brakes -- Sponsored by 949 Racing 44 06-08-2013 03:59 PM
Canadian FR-S options VS U.S.A's options? Tino Scion FR-S / Toyota 86 GT86 General Forum 15 11-06-2012 10:07 PM
coilovers or springs? koyv90 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 45 04-01-2012 08:49 PM
Gearing Options and Diff options airboy808 Engine, Exhaust, Transmission 26 12-25-2011 01:11 PM
Subaru BRZ different suspension / springs tuning ahausheer Suspension | Chassis | Brakes -- Sponsored by 949 Racing 35 12-06-2011 12:52 PM
