Old 07-01-2014, 11:45 AM   #1
whatsinaname
Drives: 1998 Ford ZX2
Noise while slowing to a stop
I have been hearing this faint sound every time I slow to a halt. Sounds like some pump/fan spooling up and then stopping. Lasts for a few seconds. Any idea what it could be?
I will try to capture it on video/audio sometime today evening.
(2013 BRZ Limited)
whatsinaname is offline   Reply With Quote
Old 07-01-2014, 11:54 AM   #2
Ernie L
Ernie L's Avatar
Drives: 2014 BRZ black premium
(2013 BRZ Limited)
maybe
http://www.ft86club.com/forums/showthread.php?t=68912
Ernie L is offline   Reply With Quote
Old 07-01-2014, 12:35 PM   #3
wheelhaus
wheelhaus's Avatar
Are you putting it into first as you're slowing down with the clutch in? If so, what you're probably hearing is the faint whine of the gears as the synchros force the transmission input shaft up to a higher speed. (In 1st, the input shaft is at a shorter ratio to the output shaft, thus engaging 1st at a given speed requires a higher rpm).
Or in other words, it's normal, nothing to be concerned about.
Old 07-02-2014, 11:31 AM   #4
whatsinaname
Originally Posted by Ernie L View Post
Doesn't really sound like a fluttering sound.
I don't think it's that because it started fairly recently. Most times I don't even hear it because I have the radio going.
Maybe it is the A/C compressor running for a really short time? I wasn't running the A/C this morning and I heard nothing.
Old 07-02-2014, 11:41 AM   #5
hobojoker
Drives: SWP BRZ Limited
Does it sound like a chuttering/puffing sound sort of?
I've noticed when I have the AC on that when I come to a stop sometimes my revs drop to 500ish rpm, then flare up to 850ish before settling back down to a normal idle.
With the windows down and no radio on, it sounds strange.
hobojoker is offline   Reply With Quote
Old 07-02-2014, 01:35 PM   #6
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
Do you have a manual transmission? If so I'd guess flywheel/clutch rattle.
http://www.ft86club.com/forums/showp...0&postcount=20
ineedyourdiddly
Old 07-02-2014, 02:10 PM   #7
ScionFR-S
ScionFR-S's Avatar
Drives: Raven Scion FR-S
Air condition fan turning on? Could be you hear it bc your slowing down. It goes on and off
"To make it in America you need three things, a smile, a gun, and a plan. If you need to give up one thing, give up the smile. If you need to give something else up, lose the gun. But never, ever, give up your plan."
ScionFR-S is offline   Reply With Quote
Old 07-02-2014, 02:47 PM   #8
Kuros
Drives: 2014 FRS Raven. 2011 sti red (gone)
If manual - flywheel
If auto - an automatic transmission being an automatic
Kuros is offline   Reply With Quote
Old 07-03-2014, 06:24 PM   #9
whatsinaname
I did some more testing and this is it. I think I didn't hear it before because I got the car in fall of last year and the last couple of weeks are the first time I have extensively used the A/C.
2nd gear grind while slowing down NO clutch Muskokan Issues | Warranty | Recalls / TSB 12 07-18-2017 02:35 PM
Ratting when slowing down aghuman Issues | Warranty | Recalls / TSB 9 03-23-2014 04:08 AM
Hearing a ticking noise when slowing down to a stop with fan and/or AC on itisthumper Issues | Warranty | Recalls / TSB 1 07-18-2013 10:34 PM
MT, neutral 15-10mph slowing, ratcheting noise bcj Engine, Exhaust, Transmission 7 04-18-2013 01:33 AM
Automatic Shuddering when slowing to stop Craig Issues | Warranty | Recalls / TSB 0 11-14-2012 07:40 PM
