#85 |
Mentat
Drives: 2013 Scion FRS 6MT
They need to replace the shitty brass synchros with carbon fiber synchros.
#86 |
Drives: BRZ WR Blue, E85, Fully modified.
I have this issue too when I drive around 100km/h in 6th and needs to downshift to 5th to overtake it would grind. But, if I drive at the lower speed such as 70-80km/h in 6th and downshift to 5th it wouldn't grind. I also do rev-matching or even heel and toe to make shifting goes smoothly still it doesn't work. This problem occured to me a week ago, after getting my 10,000km maintenance at the local Subaru Dealer.
I guess, I should take my car to do some inspection for this issue before it leads to another big problem. Is there any update to fix this issue yet ? |
#87 |
EL_to_FR-S!
Drives: Scion FR-S
That is exactly the problem I had on my first tranny.
My second one has 2nd and 3rd grind now so I will be trying Pentosin 75W-80 once I have dealer approval, and then if that doesn't work it will be time for another replacement. As far as I know, there is still no fix (see links below). Take yours in and get them to check the tranny fluid - it will have metal shavings in it and that will be the justification they need to replace it. Good luck! http://www.ft86club.com/forums/showthread.php?t=16604 http://www.ft86club.com/forums/showthread.php?t=61827 http://www.ft86club.com/forums/showthread.php?t=8437 http://www.ft86club.com/forums/showthread.php?t=31929 |
#88 |
Drives: 2010 WRX (sold) 2013 brz
any update on this? 6th gear on my car is starting to grind with 15,000 miles on it. Aftermarket clutch, Aftermarket fluid, short shifter, and bushing. I have to many modifications to take it back to the dealer for this kind of problem. Is it possible that I could buy the synchros and replace them myself?
#89 | |
Drives: Skoda Yeti DSG diesel 4x4
With mine it was a 5th gear grind and they didn't hesitate to replace the gearbox under warranty, soon after those symptoms appeared. Less miles than yours, about 9000. If replacing the syncros was a fix why would they fit a new box? |
#90 | |
#91 | |
I like to think they have modified future gearboxes based on that policy, which might mean any spares could be to a different spec and could upgrade repairs? I would drop the oil first, to see what's in it, if anything? |
#92 | |
#93 | |
Are you sure it's nothing to do with the clutch not releasing fully? |
#94 | |
#95 |
Hey guys I wanted to update that I switch from pentosin to redline with 1 quart of shockproof. 5th gear grind is completely gone and its shifts like butter.
#96 | |
You might pass that on to Toyota and Subaru to try instead of changing gearboxes. |
#97 |
#98 |
| 3rd-4th gear grind...but only near redline | hushypushy | Engine, Exhaust, Transmission | 89 | 06-03-2016 09:39 PM |
| Steering grind | Kregar | Issues | Warranty | Recalls / TSB | 19 | 08-11-2014 02:47 PM |
| High pitch sound at freeway speeds | l0aded | Issues | Warranty | Recalls / TSB | 7 | 06-14-2013 05:25 AM |
| RPM at Highway Speeds | sparis45 | Scion FR-S / Toyota 86 GT86 General Forum | 21 | 05-26-2013 02:41 PM |
| 3rd gear grind | Mo707 | Scion FR-S / Toyota 86 GT86 General Forum | 18 | 07-29-2012 07:37 PM |
