Old 06-30-2014, 04:23 AM   #29
Black86
Black86's Avatar
Drives: 2013 Raven Black FR-S
I'm interested in this. Don't know how it compares to a full blown turbo kit as far as power you can push and ect but wouldn't be a bad idea. Sounds wicked too! If it can hit 400whp+ just like the other kits and spool that much quicker sounds promising to me. Anyone have any dyno or in car footage?
-Raven Black 13 FR-S : The daily driver
-88 supra turbo : 2jz 66mm single on E85 in the process
Black86 is offline   Reply With Quote
Old 06-30-2014, 12:39 PM   #30
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
What would lead you to believe that turbo for turbo this kit would spool faster?
Old 06-30-2014, 01:05 PM   #31
SomeoneWhoIsntMe
Drives: 2013 Subaru BRZ
a fundamental misunderstanding of basic concepts of thermodynamics?
it's remarkable that fans of rear-mount turbos brag about the extra feet of charge piping under the car "working like an intercooler", while they totally ignore the heat loss in the exhaust piping.
1jz salvaged brz build thread brought to you by visconti tuning --> Pipe dreams and poor life choices
SomeoneWhoIsntMe is offline   Reply With Quote
The Following User Says Thank You to SomeoneWhoIsntMe For This Useful Post:
Sithspawn (06-30-2014)
Old 06-30-2014, 02:10 PM   #32
Cross
It's the Mad Cow
Cross's Avatar
Many just wrap the exhaust piping to negate said loss, just like those of us with it like having an engine bay not crammed with such "Hot Exhaust" next to things that really don't always react as well to it.
But then I have an intercooler and E85 with my rear mount so I guess I am using the best of both worlds with how mine is setup.
Old 06-30-2014, 02:12 PM   #33
Roxy86
Roxy86's Avatar
Drives: Diesel daily / FR-S
if the turbo sits under the trunk....
how long is the inlet pipe from the turbo? and please show dyno graph of the "No boost lag" claim
I also thought that by retaining heat inside the turbine increases turbo efficiency = spool.
By having it under the trunk un-shielded against cold air, only benefit I can see is the intake air getting cooled.
Roxy86 is offline   Reply With Quote
Old 06-30-2014, 02:20 PM   #34
Cross
It's the Mad Cow
Cross's Avatar
I haven't made any claims of there being "no lag" I have explained how you get lower amounts by using smaller charge pipes but I believe I have even stated with my intercooler setup my boost on a manual boost control starts around 3200 - 3500 rpm.
As for heat again heating the very air you are charging increases heat on the cool side.
By wrapping your exhaust pipes going back and using a turbo blanket like most do with any turbo setup now the fears of loss are greatly reduced.
While there has been a lot of requests for dyno proof I have not had the time. However a simple Google search shows the dyno charts of Corvettes, Camaro, Trans Ams, Mustangs and many more running and dynoing with rear mounts. This isn't a new idea it's just unconventional. Each has its own merit's. I personally enjoy mine but if I was to change it I would put it around the trans because I like not having it in the engine bay.
Old 06-30-2014, 04:11 PM   #35
Roxy86
Roxy86's Avatar
Originally Posted by BuhhDill View Post
I stumbled across this kit on youtube and thought that it was a win across the board.
No extra engine bay heat
No boost lag
Decent price ect.
I should rephrase since it was a more of...."have you seen this" thread from the OP.
Old 06-30-2014, 05:16 PM   #36
Cross
It's the Mad Cow
Cross's Avatar
I have tried to stick to providing real world FRS results since I have the prototype and can answer many of the questions asked. Hints my responses concerning heat, lag, etc.
The OP may have made that claim but as far as I know there are less than 5 users running this and I am one of the most vocal on answering questions.
Old 06-30-2014, 06:33 PM   #37
Simon99
Simon99's Avatar
Drives: 2013 BRZ Limited WRB
I'm gonna ask a stupid question, flame me if you'd like, but I never ran a turboed car without intercooler. Could a pipe like this ( http://www.siliconeintakes.com/produ...3057cfa4a9778d) reduce the temperature just a bit to increase efficiency (or be manifactured longer to do so from the back of the car) or i just sound stupid ?
Originally Posted by VesperLynn
This car has allowed car enthusiasts to come from all different walks of life, car cultures, and brands. Just as a panda is black, white, and Asian; the 86 is Toyota, Subaru, and downright fucking sexy.
Simon99 is offline   Reply With Quote
Old 06-30-2014, 06:37 PM   #38
Cross
It's the Mad Cow
Cross's Avatar
It's been brought up before and it could but being under the car it would probably ending getting damaged on one side however it should do something. Wouldn't hurt to see it tested.
Old 06-30-2014, 07:31 PM   #39
andrew20195
When people refer to "lag", they are either talking about boost threshold or transient response. You're talking about the RPM where the turbo starts to create positive relative pressure: boost threshold. It would not be affected by length of piping as much as transient response. What I would be interested in seeing what the transient response looks like with this system. How long does it take to build boost transitioning from a steady cruise to wide open throttle? It will vary with RPM and gear, of course.
andrew20195 is offline   Reply With Quote
Old 06-30-2014, 07:37 PM   #40
Cross
It's the Mad Cow
Cross's Avatar
Response really seems quite quick but I honestly can't say I have made any attempts to measure length of time but I do have some logs from the brag strip. However those may not be as useful as just a log from cruising to WOT.
Is there a preferred test method? I would think which great would effect load which would effect results.
Old 06-30-2014, 07:46 PM   #41
andrew20195
Load would definitely have an effect. I would think 3rd and/or 4th gear runs starting at various RPM above the boost threshold, e.g. 3500, 4k, 4500, etc., and running in both directions to average out slope and wind. Admittedly, the data aren't really useful unless you have something to compare it to, but it would be nice for someone to start collecting it.
I guess most people are too busy enjoying their new power to bother testing these things.
Old 06-30-2014, 08:02 PM   #42
Cross
It's the Mad Cow
Cross's Avatar
I have some 3rd gear pulls at lower boost from when I was trying virtual dyno. But they start at 3000.
FBM Stage 1 Base Turbo Kit Starting @ $3995 Garrett or PTE Turbo Choices FullBlown Forced Induction 588 12-02-2015 03:41 PM
FRS Rear Turbo Roadstercycle Forced Induction 176 06-18-2015 07:13 PM
Free-Rear bumper cover (entire rear facia) replaced after slight rear-end collision n7011n Exterior Parts (Aero, Lighting, Etc.) 7 03-26-2014 05:46 AM
Turbo Tuesday 12/4/2012 (Dynamic Turbo Miami) F3dzo Southeast 46 12-06-2012 02:49 PM
