Old 06-30-2014, 12:20 PM   #4915
xjohnx
Grip>Slip
xjohnx's Avatar
Originally Posted by civicdrivr View Post
I'm heading out of town this weekend, how about the following weekend after C&C?
Sounds good.
civicdrivr (07-01-2014)
Old 06-30-2014, 01:07 PM   #4916
Dustin
Twin Screw You
Dustin's Avatar
Drives: 2013 Supercharged Whiteout FR-S
Did 1 more data log this morning when it was a little bit cooler. Outside temp was 76-78 degrees F. A little bit warmer outside than with the Nameless intake and overall intake air temps were generally cooler with the Innovate. Both of these were done on the same stretch of road to make them as similar as possible with cruising, stopping, accelerating, ect.
Nameless intake uncoated - outside temp 70-75 F
Innovate intake - outside temps 76-78 F
Dustin is offline   Reply With Quote
The Following User Says Thank You to Dustin For This Useful Post:
DeliciousTuning (06-30-2014)
Old 06-30-2014, 01:18 PM   #4917
DeliciousTuning
PhoneFlash by EcuTeK
DeliciousTuning's Avatar
While logging these variables, I would suggest showing MAF grams/sec to see what peak values you hit between the two at similar RPM's and gears. I bet you will find a difference of higher MAF grams/sec on cooler intake temps, which in turn, equates to more power.
Cheers,
William Knose
Old 06-30-2014, 01:27 PM   #4918
DeliciousTuning
Originally Posted by Basket Case View Post
I know Ian oil cooler is a must for any FI application. What I am more concerned with is the water/air intercooler heat soaking either in traffic or after a few laps on a track in the he florida heat causing the IAT's to raise significantly and cause detonation. Every review I read are from people loving up north complaining about 80's being hot, lol...
We did do some testing on the intercoolers in the Innovate Kit and found even in extremely hot conditions it does keep the charge temp into the engine fairly consistent. Though it may seem high (160-180 F) compared to a remote intercooler on every other kit on the market it still does the job of keep the temps consistent. Being air temps outside will never really go above 120 F (unless you live in hell), the charge temps will always stay around 160-180 and so you should have a fairly consistent tune. Really the only difference will be intake temps at this point, as it changes the power because air density changes.
Cheers,
William Knose
The Following User Says Thank You to DeliciousTuning For This Useful Post:
Basket Case (06-30-2014)
Old 06-30-2014, 01:36 PM   #4919
Dustin
Twin Screw You
Dustin's Avatar
For whatever reason I only logged those 4 parameters with the Nameless intake but here is the Innovate intake with the MAF grams/sec. Maybe I'll switch back to the Nameless for a day or two to do another.
Old 06-30-2014, 03:35 PM   #4920
evan
Drives: fr-s
Originally Posted by Khorne View Post
Not sure how it doesn't make sense since i described the bit outlined in red in the below picture, all the parts mentioned are contained within the supercharger itself. I did mean Pulley hub not the pulley itself my mistake.
Basically that's how Sprintex will be selling the upgrade to the customer as a complete unit, unbolt the old 210 from the manifold and elbow at the back and slap on the 210+ total cost $2100 Australian, the pricing for it is on their website.
Like i said no idea how innovate would handle the upgrade to you in the USA as this only reflects buying from Sprintex directly.
http://www.sprintex.com.au/wp-conten...013_Page_1.jpg
Sounds way too expensive for a mild upgrade.
Through unofficial channels here in the US, I can upgrade to the 335 unit (starting off with a bigger 80 or 85mm pulley) for less than the cost of going 210+ (I send my 210 core back for credit and to be rebuilt/resold). I feel like there is some price gouging going on here.
Intake temps will be lower too with the 335. I don't buy the whole you must upgrade your motor to run the bigger unit fud. It sounds more like cya.
evan is offline   Reply With Quote
Old 06-30-2014, 03:39 PM   #4921
Draco-REX
Corner Junkie
Draco-REX's Avatar
Drives: 13 BRZ, 11 STI, 99 RS
I bet it will be about the same as the intercooler upgrade.
Old 06-30-2014, 06:44 PM   #4922
Kodename47
Kodename47's Avatar
Drives: UK GT86
Compare the 335 to the 210+. Like for like the 335 is more expensive.
If you're sending the 210 unit back anyway, surely you can do that with either upgrade?
The 335 will undoubtedly push too much boost at lower RPM for a stock block. You'll either need to run massive overlap (if even that works) or you'll bend rods. We already know the rods on these are a potential week point when you go bumping up low end cylinder pressures.
.: Stealth 86 :.
Kodename 47 DJ:
Khorne (06-30-2014)
Old 06-30-2014, 08:09 PM   #4923
whataboutbob
AutoX-10/10ths every run
I like gold too, been playing with my Nameless ceramic coated intake pipe, air raid intake, and gold tape. Also picked up this legsport replacement intake scoop which changes the air entry to right behind my grillcraft grill. The gold tape isnt sticking so great to the air raid box so I might have to get out the superglue, and I haven't mounted the legsport replacement intake scoop yet. I also sheathed the MAF sensor cable with some 3/8 tube to give it some protection in case the belt comes off, and if you get an air raid intake you'll need some sort of extension/adapter as it moves the coupling point further away from the intake tube. Oh yeah, "I like gold" too.
Build thread:Here
The Following User Says Thank You to whataboutbob For This Useful Post:
CK_Bladesmith (06-30-2014)
Old 06-30-2014, 09:55 PM   #4924
Khorne
Super 86
Khorne's Avatar
Drives: Red 86 GTS
Also before i get told I'm lying about prices again, everything I'm saying in is Australian dollars. A video game in the us retails for $60 here it'll retail for $100-$120.
RRP intercooler upgrade from Sprintex is $1700 Australian.
This guy gets it, I'm simply talking about cost of the unit itself and what has to be upgraded. I don't know what arrangement you have with your dealer, I'm working out a trade sorta thing with Sprintex myself but I'm not going to post what I'm getting here.
230rwhp/184ftlb on 98RON/93AKI
Build thread
Red 86 GTS MT | Sprintex Intercooled Twin Screw SC | Invidia N1 | Mocal 10 row | Invidia Front Pipe | Motiv Overpipe| Enkei RPF01 with Bridgestone RE002s | MCA Blue Coilovers | Radium Catch Can
Khorne is offline   Reply With Quote
Old 07-01-2014, 02:33 PM   #4925
DeliciousTuning
Originally Posted by xjohnx View Post
That's what I'm looking to do. I know @Slip Angle had one made Fortune Auto, but when I inquired about them they said they don't make them.
In the mean time, enjoy some videos from 8.59.
Are you spinning 1st and 2nd gears until you hit 3rd? Sounds like it. Nice.
Cheers,
William Knose
Old 07-01-2014, 02:43 PM   #4926
olorin
olorin's Avatar
Drives: GBS Premium
Did anyone else remove the hood insulation after installing the kit? I am worried about the hood getting to hot and damaging the paint/clear bra. Thoughts?
olorin is offline   Reply With Quote
Old 07-01-2014, 02:48 PM   #4927
Dustin
Twin Screw You
Dustin's Avatar
Removed mine. No issues.
Old 07-01-2014, 02:50 PM   #4928
mikalem
mikalem's Avatar
Drives: 2020 DGM BRZ Limited
I have mine off as well - no problems either
mikalem is offline   Reply With Quote
Innovative ideas to increase interior storage capacity? swift996 Cosmetic Modification (Interior/Exterior/Lighting) 0 01-30-2013 11:45 PM
AVO vs Innovative diss7 Forced Induction 32 01-21-2013 07:15 PM
Not another need to drive topic Sargy Mid-Atlantic 5 11-27-2012 01:18 PM
Technical topic sub-forums OrbitalEllipses Site Announcements / Questions / Issues 1 07-18-2012 12:38 AM
Can you close the topic please? Standardsuspension Brakes, Suspension, Chassis 14 06-26-2012 06:14 PM
