Old 06-29-2014, 05:43 PM   #15
themajesticone
themajesticone's Avatar
Drives: '13 UM86
Your on E85 right ?
Looks ok to me (im not a tuner) their is a bit of knock 6500 and 7100 rpm here judging by the chunks out of your KC Learned value it would be easier to see if you logged Knock correction and FLCK it does not look bad probably less than 1 degree pulled . Its just a bit unusual on E85 to see knock is it your first tank and e% is a bit low. AFR is plenty rich enough.
http://datazap.me/u/themajesticone/r...zoom=2890-3167
Alright thank you. It is actually my 2nd tank of E85 so no more 91 should be in there. I was running the 1.42 E85 EL map. Today I just updated it to the 1.59 map from their website. I am going to drive around a bit then do some runs tonight and post another log. Hopefully it will look ok.
themajesticone is offline   Reply With Quote
Nameless Overpipe/Front Pipe VIDEOS RESONATED OR NON-RESONATED POST HERE !! ScionFR-S Engine, Exhaust, Transmission 20 05-27-2014 05:36 AM
Front pipe choices, resonated vs straight pipe jflogerzi Engine, Exhaust, Transmission 4 12-29-2013 11:14 PM
WTB: Perrin Over Pipe + Catted Front Pipe + Cat Back (Resonated) coolaron Engine, Exhaust, Bolt-Ons 0 07-13-2013 04:37 PM
Will a resonated front pipe make alot less noise than test pipe? Mike86 Engine, Exhaust, Transmission 8 01-26-2013 08:24 PM
Help installing AP front pipe... S1000rr Engine, Exhaust, Transmission 6 12-28-2012 11:10 PM
