Old 06-20-2014, 05:04 PM   #15
Shagaliscious
Drives: Firestorm FR-S (MT)
I just had this issue when I left work today. White smoke from the exhaust on start up for a couple seconds. I got out quickly to smell the exhaust and I didn't smell oil.
I also had white smoke come from the vents yesterday when I switched the A/C from recirculate to pull in air from outside. It didn't really smell like anything. It has been hot the past couple days so I have been running the A/C quite a bit, but I did not use it this morning going to work. Almost 20k miles on the car.
Old 06-20-2014, 05:25 PM   #16
mike the snake
Usually if it's condensation, the steam will dissipate quickly.
Smoke lingers, and floats away depending on wind.
The white smoke is actually steam, and happens to just about every car. It is more or less depending on the weather humidity.
The cooling exhaust causes condensation inside the same as water collects on a glass of ice water.
White SMOKE on startup usually indicates rings or valve guides, and I'd be surprised if either of those is happening on a newer, low miles engine.
Old 06-20-2014, 06:04 PM   #17
radroach
Drives: car
A brz owner at the last autox (80+*temps) had a tomei 60s exhaust and was also getting some white smoke, and we couldn't figure out what it was.
Old 06-20-2014, 06:08 PM   #18
stugray
Drives: 2013 GBS BRZ Limited
As @whaap mentioned above. Boxers are notorious for smoking a little right at startup.
Especially if it sits for a long time or is parked at an angle.
OR.... if you overfill the oil
Old 06-21-2014, 09:11 AM   #19
Shagaliscious
I am feeling confident that it is steam now. When it came out of the vents it disappeared pretty quickly, and had no smell. When it came out of the exhaust on start up, by the time I jumped out of the car to check it out all the smoke/steam had disappeared.
Old 06-21-2014, 01:16 PM   #20
WNDSRFR
Drives: FR-S,GTI
Yeah, this happens to me just about every morning. I'm pretty sure it is steam. I have a Manzo catback. The exhaust tips are angled up. So any time it rains, the muffler could get filled with water. I almost need those flappers you see on semis to keep the water out.
So yes I do keep it in the garage. But when it rains here it RAINS.
Old 06-22-2014, 10:06 PM   #21
stevesnj
stevesnj's Avatar
Condensation from high idle and cold start rich fuel mix. Normal
Old 11-18-2014, 09:32 PM   #22
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
While I normally would agree with condensation, high idle, etc, this is probably something unique to the boxer engine.
Today, this issue happened again.
Conditions:
~ 70-75F, mid-day (around 1PM)
Car has been parked in garage since the weekend, I last drove it on Sunday (all day), and moved it today because I am swapping out the diff.
Upon startup, there was a large plume of smoke behind the car. I got out, smelled it, it's definitely oil + condensation as it's not entirely blue, but has enough burn smell to let me know it's oil.
Oil level is very good, no other burning oil. Currently at close to 5000 miles, oil was changed back in May 2014.
It is not condensation. It's not rain. I have only had this happen twice, both times there wasn't anything to produce condensation in the amount that would produce the smoke volume exhibited.
FWIW: the amount of smoke was about the same as if you ran a fog machine about 2-3 seconds. I'd say about 2-3 tablespoons of oil burnt at the same time...
It's honestly not an issue, just posting this for documentation purposes so people can stop attributing this to just "condensation"...
-alex
Old 01-15-2015, 04:14 PM   #23
Eski
Eski's Avatar
Drives: '15 Brz Series Blue
Originally Posted by automatic View Post
I noticed this too...
But I also noticed that my car produces more condensation when driving in cold weather compared to other cars...and does not seem to stop producing condensation "smoke" even after driving a while. It doesnt smell funny or anything...anyone know why?
i have this issue too. this thread seems dead so hopefully i can revive it.. my car seems to be producing steam/smoke at all times at night even when the engine is up to normal operating temps. it does this in the morning as well but i just chalk that up to cold start in the morning.
i was wondering if anyone else had this issue? its not smoke its more like steam, it dissipates quickly into the air. if the answer is simply this is normal i want to know why
Eski is offline   Reply With Quote
Old 01-15-2015, 06:46 PM   #24
billwot
Drives: '11 Cayman , '14 Camry, '11 Tacoma
Because water vapor is a normal byproduct of combustion, and when the exhaust gasses, carrying that water vapor are cooled (by colder ambient air) that water vapor condenses out into condensate.
billwot is offline   Reply With Quote
The Following User Says Thank You to billwot For This Useful Post:
Eski (01-16-2015)
Old 01-16-2015, 01:55 PM   #25
This thread was dead because the question had been answered 20 times already!
The answer is not going to change.
Red tail lights: Will it cloud/crack? raul Cosmetic Modification (Interior/Exterior/Lighting) 60 09-26-2013 08:39 AM
long startup!!! HELP! juanam0909 Issues | Warranty | Recalls / TSB 11 05-18-2013 09:17 PM
NAV startup screen brett_g Electronics | Audio | NAV | Infotainment 1 07-22-2012 08:16 AM
Help finding thread about startup rpm needle Prava Electronics | Audio | NAV | Infotainment 2 07-01-2012 02:29 PM
2013 FR-S (Auto) Cluster Startup Sequence xravexboix FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 6 05-21-2012 07:36 PM
