neutron256, Robftss
Old 06-20-2014, 11:40 AM   #673
jflogerzi
jflogerzi's Avatar
Got to say I am looking forward to your results. If you can produce 5psi of boost and hold it till red line, that would be fantastic.
Sent from my SGH-T999 using Tapatalk
2013 Series 10 FRS #553
Old 06-20-2014, 12:04 PM   #674
neutron256
neutron256's Avatar
Drives: '13 GBS Subaru BRZ
Thanks, I think 5psi at redline is being very optomistic, but I really have no idea how it will perform at this point. Hopefully I'll be able to start doing some real testing this weekend. The rest of the parts for my controller should be arriving today, and I'm working on soldering up the wiring and connectors.
The Following User Says Thank You to neutron256 For This Useful Post:
jflogerzi (06-20-2014)
Old 06-20-2014, 06:01 PM   #675
AN
Drives: 2010 MX-5
I spent some time estimating how much air the Seadoo will flow in this application. I came up with the following table.
Assumptions and calculations :
Based on what we know about the 2 different Seadoo chargers, I have estimated that the red compressor (185hp) flows 17.36 lbs/min @ 39k rpm and the black (215hp) one flows 19.99 lbs/min @ 43k rpm. If somehow we are able to spin the black compressor to about 38~40k rpm (which I understand is a tall order), we should be able to flow roughly 18 lbs/min of air. this means in a 2.0L application we should be able to generate a little over 1.2psi of boost @ 7500 rpm. At a lower rpm, more boost will be generated but the compressor will be limited by the surge line in the compressor map.
AN is offline   Reply With Quote
The Following User Says Thank You to AN For This Useful Post:
neutron256 (06-20-2014)
Old 06-20-2014, 06:58 PM   #676
neutron256
neutron256's Avatar
Those numbers would seem to indicate similar performance to the Phantom setup which isn't surprising, and I'd be alright with that. I still think there are way to many variables we can't account for here so it will be interesting to see what happens.
Old 06-20-2014, 07:11 PM   #677
jflogerzi
jflogerzi's Avatar
@AN interesting. Very similar to Robs current ECS which can only hold about 1-1.5 PSI of boost @ redline.
Old 06-20-2014, 07:36 PM   #678
AN
Drives: 2010 MX-5
Yep, I am really looking forward to what actually transpires ...
Old 06-22-2014, 02:18 PM   #679
jwestra
Drives: Seat Ibiza
Great project!
When looking for some information, I found that this compressor might be a better option:
20psi @ 8,500rpm
http://www.rivayamaha.com/RivaStore/...0and%20Housing
Compared to even the seadoo "XXX":
15.5psi @ 8,500rpm
http://www.rivaracing.com/RivaStore/...%20XXX-Charger
I am not sure what these RPM mean, I am guessing engine RPM
jwestra is offline   Reply With Quote
Old 06-22-2014, 02:40 PM   #680
jflogerzi
jflogerzi's Avatar
Originally Posted by jwestra View Post
Great project!
20psi @ 8,500rpm
15.5psi @ 8,500rpm
The amount power in battery you would need would be insane to hold that PSI near redline. If you are looking for that kind of power, you missing the point of this type of bolt-on.
Old 06-22-2014, 03:03 PM   #681
jwestra
Drives: Seat Ibiza
I don't think we will hit anything close to those PSI's. Just a bit better than the seadoo for a decent price.
Old 06-23-2014, 11:39 AM   #682
neutron256
neutron256's Avatar
I'm working on the wiring for my control system. Here are the wedges to tap into the TPS and MAP sensors.
AN (06-24-2014)
Old 06-24-2014, 08:24 PM   #683
AN
Drives: 2010 MX-5
How did we miss these motors before :
They come in anything from 3kW to 12kW and have models that hit 50k rpm and 60k rpm.
Priced super cheap.
2 different manufacturers: TP-Power and SSS Motor.
http://tppower.com/sort.asp?class_id=4&news=44
SSS:
http://www.horracing.com/index.php?m...page=1&sort=4a
Trying to locate Manufacturers site for SSS Motors to see all the motors they make. With that RPM, we can get a smaller wheel / compressor housing.
Update: TP Power motors have reasonably good reviews .... (only read first 3 links on reviews )
Old 06-24-2014, 09:52 PM   #684
neutron256
neutron256's Avatar
Priced super cheap.
SSS:
Nice find. Keep the max voltage in mind. You'll need to have a system that operated near that max voltage to get the max speed/power out of the motor. It does look like some of them would work with a 24V or 36V system.
Old 06-24-2014, 09:57 PM   #685
neutron256
neutron256's Avatar
Priced super cheap.
SSS:
Here is the link for the TP a Power USA site.
http://www.tppowerusa.com/index.php?route=common/home
AN (06-25-2014)
Old 06-25-2014, 08:37 PM   #686
neutron256
neutron256's Avatar
Working on my control system. I tried designing my own controller with limited success. I was just having too much trouble getting the signaling right. So I'm back to using the Unichip as a controller for the compressor motor.
Every thing is wired up right, and I can hook a servo up and control it just fine, but for some reason the Turnigy Fatboy V2 ESC I'm using doesn't like the servo signal from the Unichip.
Any RC experts out there have any ideas as to what might be going on? It works just fine when I hook it up to a servo tester.
hairdyerperformance, only pulls hard one gear
Full throttle Electric Supercharger Build Thread fenton Forced Induction 11315 04-07-2025 07:42 PM
DUP THREAD MODZ PLZ DELETE KTHX SloS14 Forced Induction 0 07-09-2013 06:41 PM
Electric Turbocharger Shankenstein Forced Induction 91 06-24-2013 03:47 PM
Electric 86 frosty86 Scion FR-S / Toyota 86 GT86 General Forum 8 11-10-2012 03:16 PM
WRX Electric turbo Neilus Engine, Exhaust, Transmission 42 05-03-2012 10:20 PM
