Old 06-13-2014, 09:48 AM   #15
kiichiro
corolla specs/GTR looks
Drives: ooh oooh pretty tail lights
Crank seal
SOLD THEM BOTH
Hers: 2007 987S
Mine: 2012 991S
That was fun, thanks Hachi
kiichiro is offline   Reply With Quote
Old 06-13-2014, 09:51 AM   #16
billwot
Drives: '11 Cayman , '14 Camry, '11 Tacoma
Originally Posted by mfbmike View Post
Hm.
Would coolant be able to ignite to a flame if it sat on top of a hot enough exhaust manifold heat shield?
No.
billwot is offline   Reply With Quote
Old 06-13-2014, 06:09 PM   #17
Accurate Race Shop
Accurate Race Shop's Avatar
Drives: Scion FR-S
Thanks. Unfortunately, going to the dealership may be necessary. Wasn't going to tear into it with it under warranty but figured I might be able to find the source before taking it in. Just an annoyance that turns me off. lol.
What are the symptoms of your leaking head gasket?
Just very minor leaking. It is not enough to really show on the dip stick or in the radiator. I have to mixing of the two just a little external leaking.
Sent from my Q10
Old 06-14-2014, 06:41 AM   #18
PeterK
Drives: BRZ SE LUX
I've had a similar issue on a different car. I didn't realise I'd dropped a paper towel used for mopping up oil spills when changing the filter and a day later it had travelled down the floor pan and was sitting under the exhaust - very pleased it didn't catch fire. Hope that is the solution.
PeterK is offline   Reply With Quote
The Following User Says Thank You to PeterK For This Useful Post:
mfbmike (06-14-2014)
Old 06-14-2014, 10:53 PM   #19
mfbmike
Drives: 2013 FRS, 2008 R32
Interestingly enough, the smoke has been more intermittent and as of late sometimes just resulting in a smell being present but no actual smoke. With that being said, after driving home lastnight, the white smoke was present and I was able to see traces of oil leaking onto the bottom of the exhaust manifold heat shield. Car will be going to the dealership sometime next week.
mfbmike is offline   Reply With Quote
The Following User Says Thank You to mfbmike For This Useful Post:
strat61caster (06-15-2014)
Old 06-18-2014, 02:52 PM   #20
mfbmike
According to dealership, oil leak is coming from timing cover.
Makes sense since the smoke is coming from the bottom passenger side of the engine, above the exhaust manifold.
http://www.ft86club.com/forums/showt...light=oil+leak
http://www.ft86club.com/forums/showthread.php?p=1617278
Old 06-19-2014, 03:52 AM   #21
N1rve
N1rve's Avatar
Drives: 2019 BMW ///M4
So what did they do to correct the issue?
N1rve
Old 06-19-2014, 09:32 AM   #22
andrew20195
Drives: 2013 Subaru BRZ
I would guess they resealed the timing cover.
andrew20195 is offline   Reply With Quote
Old 06-19-2014, 11:36 AM   #23
mfbmike
Car is currently still at dealership being repaired. THey told me it would be ready today, yesterday.
I will post the repair order once I get car back.
Old 06-20-2014, 11:30 AM   #24
red_saiyan
Drives: incoming red GT86
I had possibly the same problem, fixed today by the service, for me it turned out to be this:
http://www.ft86club.com/forums/showthread.php?p=1482585
cam plate leak
red_saiyan is offline   Reply With Quote
Old 07-09-2014, 02:10 AM   #25
mfbmike
As it turns out, leak was due to an o-ring part of the dipstick assembly went bad. Go figure.
What are the odds?
strat61caster (07-09-2014)
Old 07-09-2014, 02:16 AM   #26
Fastbrew
Drives: 2014 Pearl White BRZ
What are the odds?
In your case - 100%
Glad you figured it out without a major hassle.
Fastbrew is offline   Reply With Quote
Old 07-09-2014, 02:45 AM   #27
mfbmike
Originally Posted by Fastbrew View Post
In your case - 100%
Yeah, service rep laughed when I returned to the dealership. I intentionally drove the 10 minute drive to the dealership hard.
He sees my car and says, "looks like it's still smoking huh?"
lol. Thankfully, no major hassle. Service rep at Toyota of South Florida, Larry, was awesome.
Cloud of white smoke on startup wawro569 Issues | Warranty | Recalls / TSB 25 01-16-2015 12:55 PM
White smoke in Engine bay Pinoywhiz Engine, Exhaust, Transmission 7 04-07-2014 06:10 PM
Smoke Coming From Hood When Driving HD86 Issues | Warranty | Recalls / TSB 29 02-06-2014 08:31 PM
White smoke coming from the exhaust. hansthegerman Engine, Exhaust, Transmission 17 10-02-2013 04:23 PM
Turbo, white smoke out the exhaust, ideas? Synack Forced Induction 44 09-09-2013 09:57 AM
