| Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack Specific topics relating to wheels and tires. |
Drives: Toyota gt86
Need help with 18x9.5 et48 in front
Bought WEDSSPORT SA15R 18x9.5 et48 255/35 all around. Destroyed front rubbers from internal side by suspension.
Can you give me advice how to solve my mistake? I have eibach prokit, everything else is stock. Now I know two options: 1. Only spacers 10 mm makes enough distance between wheel and suspension, but the wheel in this case would be too wide for stock fenders. 2. 235/40 did not help, it's just 2-3 mm narrower than 255/35 Have some photos of 255/35 and suspension |
#2 |
FT86Club Official Vendor
Drives: 2013 BRZ, 2015 WRX, 2000 RSTi
Use the 10mm spacers, then use aftermarket upper strut mounts (like Whiteline Com-C, or some other adjustable mount) to tilt the top of the shocks in. That will solve the fender clearance problem.
--Dan Mach V |
#3 |
what Dan said.
either get a top hat that will pull camber and pull the stru away from the wheel or use a spacer (be careful with spacers, you may need extended studs). OR get a coilover and that will eliminate all clearance issues. -Ivan ![]() Maintaining, Modifying and Educating TriState Enthusiasts since 2001. Like us on Facebook! | E-mail: sales@azpinstalls.com | 725 Fairfield Ave | Kenilworth, NJ 07033 | 908.248.AZP1 (2971) |AIM: AZP Installs "Race Tested, Enthusiast Approved!" |
#4 |
Drives: Toyota gt86
This weekend tried 235/40 and 5 mm spacers. Just made fitment. Next week I'll get specers and will try to run this option several days on used tyres provided by teammate.
#5 |
Drives: 2013 Raven FRS 2JZ-GTE/V160 swapped
You should look into aftermarket coils, that clearance looks scary.
#6 |
the tuna, no crust.
Drives: 2014 Hachiroku of the year
luckily everything is fixed, while its close it wont move because it physically can't. so you should be just fine, but for my personal taste, its too close for comfort.
| Tags |
| wedssport, wheel |
| Wheel Directory: Volk Racing TE37 18x9.0 +45 Front / 18x9.5 +40 | OmegaKnight | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 4 | 05-03-2016 08:09 AM |
| 16x8 et48 with a 245, yea or nea? | Skyllz | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 4 | 11-23-2013 12:03 AM |
| ** Volk TE37SL 18x9.5 +40 (Rear) 18x9 +45 (Front)** | SOURCE,LLC | Wheels and Tires | 23 | 09-17-2013 09:25 PM |
| 18x9.5 +45 (square) VS 18x9.5 +35 Front 18x8.5 +40 Rear (staggered) | Funky Fresh | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 42 | 05-07-2013 09:52 AM |
| Buddy Club SF 18x7.5 ET48 5x100**HOLIDAY SPECIAL** | AAI motorsports | Wheels and Tires | 2 | 11-30-2012 09:04 PM |
