Old 06-15-2014, 01:33 AM   #4761
Dustin
Twin Screw You
Dustin's Avatar
Drives: 2013 Supercharged Whiteout FR-S
Has anyone tested the top speed of their car yet? I tried to top out my car today to see how well it would do. I made it almost all the way to red line in 6th gear but seemed to hit a "wall" and it just seemed to die off. And not like it was struggling at those last few RPM's. It was pulling hard and then it seemed like I lost power but only in 6th gear.
My list of mods are as follows:
Innovate Stage 2 w/ 70mm pulley
Nameless header w/ full 3" exhaust
Nameless intake tube
Delicious E85 tune
4.56 final drive
Like I said before, it pulls hard in every gear to red line except for 6th gear. I hit 140mph at 6800 rpms. I know that leaves only 600 more rpms and whoop dee doo but it still leaves me wondering why all of a sudden the power drop in those last 600 when it seems to be pulling hard up until that point.
Dustin is offline   Reply With Quote
Old 06-15-2014, 01:40 AM   #4762
wallace03
wallace03's Avatar
Drives: WRB BRZ
Has anyone with this SC ran the 1/4 yet?
wallace03 is offline   Reply With Quote
Old 06-15-2014, 03:56 AM   #4763
Kodename47
Kodename47's Avatar
Drives: UK GT86
Delicious E85 tune
4.56 final drive
You hit the limiter.
.: Stealth 86 :.
Kodename 47 DJ:
Old 06-15-2014, 06:43 AM   #4764
CK_Bladesmith
CK_Bladesmith's Avatar
Drives: Raven FR-S
I've only dared to hit 135 in mine and it felt like it had plenty left in it.
Raven FR-S mods: Unichip, Ground Control street coilovers with camber plates and strut tower brace, SPC Lca's, Drag DR-38 wheels with Dunlop Direzza DZ101s, Perrin CAI and silicone inlet tube, Perrin 3" resonated catback, Perrin high flow catted front pipe, Rev Works UEL header.
CK_Bladesmith is offline   Reply With Quote
Old 06-15-2014, 12:21 PM   #4765
Dustin
Twin Screw You
Dustin's Avatar
6800? I thought rev limiter was 7400.
Same here. Felt like I still had enough to go that bit further. Then it just dropped off.
Old 06-15-2014, 12:26 PM   #4766
xjohnx
Grip>Slip
xjohnx's Avatar
Originally Posted by DeliciousTuning View Post
I will need to watch for this while I am on 91 octane. Once again didn't notice this on the 75mm pulley. But will see what it does now on the 70mm pulley.
1st gear not really, 2-6 is extremely noticeable if you're trying to accelerate without going into boost. I'm talking maximum fuel economy takeoffs.
I really think it's due to the fact that while not boosting, the air is channeled through such a small hole, and when you give it just enough gas, or not enough, the vacuum/throttle controlled bypass valve kinda freaks out, causing the stuttering.
It's only really severe while cold, but once normal operating temps have been reached it's waaaaay less pronounced.
If you really wanna test it take the car for a highway ride and set the cruise at 75mph. Of your engine isn't totally warmed up it's gonna stutter like crazy IF you, say, climb a slight knoll such as an overpass. While the terrain is flat it's deliciously smooth, bit small hill climbs will trigger it, I think, due to the fact that it needs to boost based on the position of the throttle.
Feather the throttle and you will see. Try not to go Into boost as long as you can and it will pop up.
Bill -
If it helps, this sounds a lot like the issues I was experiencing with the logs i sent you a week or so ago. I haven't followed up since my car has been in the shop getting some hail damage repaired. Should have it back tomorrow.
Old 06-15-2014, 01:03 PM   #4767
Draco-REX
Corner Junkie
Draco-REX's Avatar
Drives: 13 BRZ, 11 STI, 99 RS
There's a speed limiter too. I believe it is 155mph. It could be 140mph. Not sure.
Whistled through a tin can and string.
Old 06-15-2014, 01:28 PM   #4768
xjohnx
Grip>Slip
xjohnx's Avatar
http://www.ft86club.com/forums/showthread.php?t=58835
According to this, the ECU starts pulling throttle at 137MPH (down to 50% throttle by 140).
Old 06-15-2014, 02:00 PM   #4769
Michael Blue
Drives: 1998 Audi A4 Quattro Sport 30v
I wonder how hard it would be for one of the illustrious ECU tuners to remove that?
Browncoat Society "Firefly"/"Serenity" Facebook Group
Project StormTrooper BRZ Ltd Coming Soon!
Michael Blue is offline   Reply With Quote
Old 06-15-2014, 02:06 PM   #4770
Draco-REX
Corner Junkie
Draco-REX's Avatar
I'm sure most do already. But the CARB tune would have to retain it.
Old 06-15-2014, 02:21 PM   #4771
Dustin
Twin Screw You
Dustin's Avatar
No CARB tune here. Running Delicious E85 tune. @DeliciousTuning any input on this?
Old 06-15-2014, 04:28 PM   #4772
DeliciousTuning
PhoneFlash by EcuTeK
DeliciousTuning's Avatar
We have not changed the speed limiter due to safety concerns. This is due to the fact that the manufacturer has set this limit for some reason aerodynamic, or other reasons unknown to us. From previous experience we have found it better to leave the limit in place. But if anyone does request it to be changed please send an email informing us that you are aware of the risks involved and agree to take full responsibility of anything that may occur by changing this limit.
The OEM speed limit in the us is set to 221 kph or about 136.
Cheers,
William Knose
The Following User Says Thank You to DeliciousTuning For This Useful Post:
Dustin (06-15-2014)
Old 06-15-2014, 04:36 PM   #4773
Dustin
Twin Screw You
Dustin's Avatar
No change needed on mine. Just wanted to know what was up. Thanks Bill!!
Old 06-15-2014, 06:23 PM   #4774
whataboutbob
AutoX-10/10ths every run
My car has just started to have misfire issues above 5K RPMs. I suspect the DI seals are gone on 3 of 4 cylinders based on it's behavior being consistent with DI seal failure and the fact that the dealer did some diagnosis and found 3 of 4 cylinders misfiring above 5K RPMs.
Build thread:Here
Innovative ideas to increase interior storage capacity? swift996 Cosmetic Modification (Interior/Exterior/Lighting) 0 01-30-2013 11:45 PM
AVO vs Innovative diss7 Forced Induction 32 01-21-2013 07:15 PM
Not another need to drive topic Sargy Mid-Atlantic 5 11-27-2012 01:18 PM
Technical topic sub-forums OrbitalEllipses Site Announcements / Questions / Issues 1 07-18-2012 12:38 AM
Can you close the topic please? Standardsuspension Brakes, Suspension, Chassis 14 06-26-2012 06:14 PM
