Old 06-12-2014, 06:18 PM   #337
MokSpeed
Granny Shifter
MokSpeed's Avatar
Drives: 2014 FR-S
Originally Posted by STV3 View Post
Any chance you can post up a pic?
I second this request.
MokSpeed is offline   Reply With Quote
Old 06-12-2014, 06:41 PM   #338
nosi9frs
nosi9frs's Avatar
Drives: Raven FR-S
This mine, similar set up tho:
OZ Ultraleggeras 17x8 +35 with TRD springs and no camber adjustments
nosi9frs is offline   Reply With Quote
The Following 8 Users Say Thank You to nosi9frs For This Useful Post:
BabaYaga (02-16-2015), Bimble Bamble (02-15-2015), evox2frs (06-12-2014), hmong337 (06-21-2014), JonAvalon (06-14-2014), makesdrivingfunagain (08-07-2015), newports (06-20-2014), STV3 (06-12-2014)
Old 06-12-2014, 07:20 PM   #339
STV3
Señor Member
STV3's Avatar
Attachment 81840
Thanks, but I still want to see the XXR 530 17x8.25 on TRD springs because I've been contemplating that same set up for my car.
STV3 is offline   Reply With Quote
Old 06-12-2014, 07:34 PM   #340
AVodka14
AVodka14's Avatar
Drives: 2013 Raven FRS MT
TRD springs don't lower the car enough. USDM TRD springs are good though. Wish we could import JDM TRD springs if they made them for the 86. Not sure if they do.
AVodka14 is offline   Reply With Quote
Old 06-14-2014, 09:56 AM   #341
frs10
Drives: tezla
u can order the JDM ones no?
frs10 is offline   Reply With Quote
Old 06-14-2014, 11:33 AM   #342
AVodka14
AVodka14's Avatar
Not good with import part info. Can someone chime in here? I would be all over JDM TRD springs and struts. If they are indeed more aggressive.
Old 06-15-2014, 08:29 PM   #343
Snowblind
Lower it enough for what? To impress high school kids with hellaflushfitment1111?
The Following User Says Thank You to Snowblind For This Useful Post:
Old 06-15-2014, 08:38 PM   #344
AVodka14
AVodka14's Avatar
Uhhhh...nah man. I impress the high school kids with my ginormous wing on my trunk alone. You probably meant to put !!!! instead of 1's I presume...Carry on.
Old 06-19-2014, 01:15 AM   #345
cslntuee
Drives: Subaru BRZ Limited
Originally Posted by skyloran View Post
I have TRD spring and TRD Sway bar both front and rear installed.
I love the rides, it gave the car more balance on corner sharp turns and less bumping on rocky roads. by far I like it alot. Plus, all the TRD springs and sway bars are manufacture by Eibach so the quality is top notch.
HI,
Which TRD sway bar you got?
I check the Scion and TRD website. The description of the size
is quite different and one sounds like that only has rear without front.
Scion (Please click the sway bar picture)
http://www.scion.com/cars/FR-S2015/a...wAll&view=grid
KIT INCLUDES:
  • Simple, bolt-on installation with no vehicle modifications required
  • 20.6mm 4130 solid front sway bar with polyurethane bushings
  • 15.8mm 4130 solid rear sway bar with polyurethane bushings
  • Rear sub-frame reinforcement brackets
TRD:
http://www.toyotaracing.com/trd/part...categories=all
Kit includes:
  • 17.5-mm. alloy steel rear sway bar
  • Factory-style ball end links
  • Polyurethane bushings and straps to hold the assembly to the FR-S
  • Polyurethane replacement front sway bar bushings that fit the OEM sway bar and brackets
  • Finished with durable, gloss-red powder coat, which resists corrosion while improving appearance and durability
Thanks.
ps. Are they hollow or solid?
cslntuee is offline   Reply With Quote
Old 06-20-2014, 11:43 PM   #346
newports
Drives: 2013 Scion FRS
Do you guys think the drop will lower it after a certain break in time?
newports is offline   Reply With Quote
Old 06-21-2014, 02:12 AM   #347
ZOMFGAARON
A Demon
ZOMFGAARON's Avatar
Drives: Raven GT86
It'll settle like any other springs but nothing major.
Old 06-21-2014, 01:18 PM   #348
Createddeleted
Drives: 2014 BRZ - 2004 GLI
Originally Posted by cslntuee View Post
HI,
KIT INCLUDES:
TRD:
Kit includes:
Thanks.
The sizes are wonky because of misinformation. The bars are solid. View my thread here
http://www.ft86club.com/forums/showthread.php?t=61880
Createddeleted is offline   Reply With Quote
The Following 2 Users Say Thank You to Createddeleted For This Useful Post:
cslntuee (06-22-2014), nosi9frs (06-21-2014)
Old 06-25-2014, 06:51 PM   #349
FR-Swag
Drives: 2014 Scion FR-S Monogram series
I just installed my TRD springs and TRD 18" rims with recommended tires and maybe its just me but it seems to have much more body roll than the stock setup I only drove it for about 30 minutes last night so I'm not 100% sure, maybe I need to install the TRD sway bars front and rear????
Sent from my DROID RAZR using Tapatalk
FR-Swag is offline   Reply With Quote
Old 07-02-2014, 03:05 AM   #350
newports
Can I please get some more Side shots of people with TRD springs on?
Lowering Springs|Alignment Kits|Strut bar|Sway Bars|Strut Mount +More SOURCE,LLC Brakes, Suspension, Chassis 445 05-11-2015 06:41 PM
ST Suspensions Lowering Springs & Anti-Sway Bars Now Available @ BMS! Boston Motorsports Brakes, Suspension, Chassis 84 07-24-2013 12:42 AM
Stock springs and sway bars Spencer Brakes, Suspension, Chassis 3 04-25-2013 10:41 AM
FR-S/BRZ SWAY BARS & STRUT BARS @ NINJA AUTOSPORTS!!! NJA Brakes, Suspension, Chassis 18 04-07-2013 07:00 PM
**The Eibach Thread** Springs, Coilovers, Sway Bars @ Pure Automotive Pure Automotive Brakes, Suspension, Chassis 1 02-06-2013 03:32 PM
