Old 06-10-2014, 06:24 PM   #1485
FR-S Matt
Received my kit today! Thanks @fteightysix for the great customer service and @KraftWerks for what looks like a gorgeous kit!
I'll be going through inventory tonight to make sure it is all accounted for. I cannot wait to be boosted!
Old 06-10-2014, 06:36 PM   #1486
post_break
Professional Smartass
post_break's Avatar
Drives: White Out FRS
Originally Posted by KraftWerks View Post
Initially the idea was to come in at that price, however the size and machining drove up the cost.
No worries, I just stumbled onto that thread after looking at the sema pics and knew I read about the prices from somewhere. It was like deja vu.
post_break is offline   Reply With Quote
Old 06-10-2014, 07:08 PM   #1487
zERoTu
Drives: 1st RBv2 10 Series FRS
Size:  317.9 KB installing mine atm
zERoTu is offline   Reply With Quote
Old 06-10-2014, 08:09 PM   #1488
Taino-BRZ
Taino-BRZ's Avatar
Drives: Subaru BRZ-SWP
Originally Posted by zERoTu View Post
Attachment 81561 installing mine atm
Don't forget to clamp those hoses behind the intake manifold
Sent from my SGH-M919 using Tapatalk
Taino-BRZ is offline   Reply With Quote
Old 06-10-2014, 08:39 PM   #1489
TmP
TmP's Avatar
Drives: A bunch of 'em...
Behind, or under?
I haven't clamped those yet so far...
TmP is offline   Reply With Quote
Old 06-10-2014, 09:40 PM   #1490
SPCorBUST
SPCorBUST's Avatar
I just used zip ties. Didn't have to remove anything and it seems to be holding 15 psi okay during dyno tuning and driving around so far.
Setup 3: JR C30, DW 700, Grams 265, 3bar, FlexFuel, Moto-East
Setup 4: JR C30 HBP, DW 700, Grams 265, 3bar, FlexFuel, Church
Setup 5: JR C30 HBP, DW 700, DW 300, 3bar, FlexFuel, Delicious, Built Motor
Setup 6: JR C30 HBP, DW 700, DW 300, 3bar, FlexFuel, Delicious, Closed Deck Built Motor
SPCorBUST is offline   Reply With Quote
Old 06-10-2014, 09:51 PM   #1491
Taino-BRZ
Taino-BRZ's Avatar
Under my bad, question, I'm on the basic kit how.much boost should I been getting? I'm at 9 I'm still confused if I got another leak.
Old 06-10-2014, 11:08 PM   #1492
zERoTu
Kraftwerks Supercharger Owners Thread
Everything is in. I just need to flash the ecu. Now I tried running the tune file. The USB isn't being detected and it's asking me to format. FML.
Car is sitting at the shop. Don't want to remove belt and drive it. Now I have to wait till tm to talk to kraftwerks to send me a tune file.
Old 06-10-2014, 11:49 PM   #1493
post_break
post_break's Avatar
So how does Visconti's tune compare to Delicious? Well it's not a fair fight because the Vtune is 93 octane and Delicious is 91 but here are two logs to compare.
Visconti:
http://datazap.me/u/postbreak/kraftw...i-93-flex-fuel
Delicious
http://datazap.me/u/postbreak/kraftw...ious-91-octane
Now the Vtune is MAF and Delicious is speed density I believe. You can see the D tune hit 11AFR where as the V tune stays in the 12's. According to my AEM wideband both hit 11.7 AFR at the lowest level. I'm not sure why the V tune doesn't record that in ecutek.
Now how do they compare on the butt dyno? Well they feel pretty close. I don't feel like I've lost a bunch of power. They are close and that's all I'm going to say without comparing both on a dyno.
On the street the V tune feels like beast mode. Power when you want it. It's pulls like crazy all over the place. If you stuff it, she'll give it to you. It's like a knife.
The D tune feels more like "stock" boost. Like you have to ask for power. It feels "smoother" to drive on the street because it's not begging to be unleashed.
How would I compare them? Honestly, I'm glad I have both, they both appear to be running how they should looking at my logs and my lean situation with the V tune was just an Evap leak. I didn't change the tune, just clamped those evap hoses and suddenly it was running in the rich areas where it should.
Overall I'm happy with both tunes and they work great.
Old 06-11-2014, 12:00 AM   #1494
Squishy
Drives: 2013 WRB BRZ
Visconti:
Delicious
Nevermind just read your Dtune is MAF so its the default shipped tune.
I ordered the kit without the tune and got the Speed density Delicious tune with 93 octane map and 91 as secondary.
Second place is just the first place loser.
Dale Earnhardt
Squishy is offline   Reply With Quote
Old 06-11-2014, 12:03 AM   #1495
post_break
post_break's Avatar
Originally Posted by Squishy View Post
Why did you order the Delicious tune with only a 91 octane map? I ordered with 93 octane as the primary map and 91 as option 2 so that when traveling to Cali or elsewhere with lower octane gas I could switch.
Otherwise are you comparing the default tune shipped with the Kraftwerks kit?
The tune was what the original owner of the kit I purchased requested. Delicious just transferred the tune to me because it was never installed or flashed to his vehicle.
I will have to get with Delicious to see how much they will charge to upgrade this tune to a 93 or flexfuel tune.
Old 06-11-2014, 12:08 AM   #1496
Taino-BRZ
Taino-BRZ's Avatar
I got the delicious and the kw tune, I have 4 maps two for 91 and two for corn, the DT is smother than the kw and it's a beast on e85, I still have one free revision after a log. But overall the kw tune was kinda bumpy but not that bad.
Old 06-11-2014, 04:32 AM   #1497
DeliciousTuning
PhoneFlash by EcuTeK
DeliciousTuning's Avatar
Visconti:
Delicious
Honest comparison, thank you.
Smooth and stock feel is a priority in our tunes.
Cheers,
William Knose
Old 06-11-2014, 06:03 PM   #1498
zoth
zoth's Avatar
Drives: 2013 BRZ Premium Dark Gray Metallic
Man I would love this sound on our kits.
http://www.ft86club.com/forums/showthread.php?t=67729
zoth is offline   Reply With Quote
Innovate (Sprintex) Supercharger Owners Topic DarrenDriven Forced Induction 9139 12-29-2023 11:58 PM
Kraftwerks Rotrex Supercharger Discussion nelsmar Forced Induction 697 01-18-2022 01:06 PM
All SUPERCHARGER kits compilation thread subatoy Forced Induction 76 03-10-2016 01:38 PM
Kraftwerks Supercharger?? umpadupa Forced Induction 1 08-05-2013 06:27 PM
