go_a_way1
Old 06-10-2014, 09:54 PM   #1485
dradernh
Drives: Used to Drive:Grand-Am GS #54 E36M3
Originally Posted by uncivilised View Post
yeah the a050 are quite a bit normally but i have mates in the industry that can help on that
Mates are always good. We here in the States are frequently shocked by what things cost out there in the real world; if we have to pay more than we want, we just scream and cry until things go our way! lol
dradernh is offline   Reply With Quote
The Following 2 Users Say Thank You to dradernh For This Useful Post:
CSG Mike (06-11-2014), uncivilised (06-10-2014)
Old 06-11-2014, 11:07 AM   #1486
becauseracecar1
becauseracecar1's Avatar
Drives:
Originally Posted by ddeflyer View Post
One thing that will help some is to not do such a binary steering input. Feed steering in to let the car's weight transfer. Specifically you want to have the derivative of your steering lock (so the rate of change) have a curve to it (sort of like a bell curve). The idea here is to get the weight to transfer smoothly so you have more consistent traction.
As there is no view of your hands in the first video I don't know if you were doing it there, but in the second one you are having pretty jerky inputs (though it looks like you smooth it out some for the second lap's start).
I'll definitely work on that!! Thank you!!
2014 Ultramarine Scion FR-S
facebook.com/86motorsports
becauseracecar1 is offline   Reply With Quote
Old 06-11-2014, 11:11 AM   #1487
becauseracecar1
Drives:
Does this look normal?
Size:  209.3 KBName:  ImageUploadedByTapatalk1402495779.014918.jpg
Hawk HP+ pads after a track day and auto x...
Thank you!!
PS: @CSG Mike I will get the carbotechs now!!
Old 06-11-2014, 04:27 PM   #1488
CSG Mike
CSG Mike's Avatar
Attachment 81620Attachment 81621
Attachment 81622
Thank you!!
I have no idea WTF happened to the pads, but the rotors tell me that you're smearing the pad compound.
You definitely need higher grade pads.
Any of the race compounds will work, Carbotech included.
I think our Project Mu Club Racer special is ending this week, so you may want to try those if you want to hop on the deal. Otherwise, Carbotechs, Hawk DTCs, etc will all be okay.
Old 06-11-2014, 05:10 PM   #1489
gramicci101
Off Topic
That looks like the back of the outside pad, so that's probably just a collection of road gunk and dirt. The dirty spots were all exposed to outside air and debris, but it's clean where it was touching the caliper. I'd be a little concerned that the gunk looks very oily though. If it is, where did the oil come from?
Old 06-11-2014, 09:07 PM   #1490
becauseracecar1
Drives:
Got a track related question? I'll try to answer.
It's not oil, it looks like the back of the pads(front pads) caught fire or got really hot as the black covering on the back side melted off. Here is a closer look at the front side and back side of the front and rear pads. Are these pads done?
Hawk HP+
Front pads:
Hawk HP+
Rear Pads
Thank you!!
Old 06-11-2014, 09:21 PM   #1491
troek
troek's Avatar
Drives: 2012 Toyota 86
looks like the paint/protective coating burned off. the white trd letters on my old pads bubbled up and looked oozy like that.
troek is offline   Reply With Quote
The Following User Says Thank You to troek For This Useful Post:
becauseracecar1 (06-11-2014)
Old 06-12-2014, 02:01 AM   #1492
RFB
RFB's Avatar
Drives: FRS
Charcoal briquets
The thickness seems to indicate lottsa life left.
CERBERUS
RFB is offline   Reply With Quote
The Following 2 Users Say Thank You to RFB For This Useful Post:
becauseracecar1 (06-12-2014), CSG Mike (06-12-2014)
Old 06-12-2014, 12:19 PM   #1493
akuhei
akuhei's Avatar
Drives: Raven M/T FR-S
Hawk HP+
Front pads:
Hawk HP+
Rear Pads
Thank you!!
That happened to mine on the weekend I used them at NOLA. It was the protective paint coating that bubbled/boiled/burned off (i was actually watching it bubbling after I'd finish a 25-minute session). I plan on using them again because, like yours, mine appear to have quite a bit of life left to them and I never had any fading or issues on those days. Its just the back of the pad...
Akuhei's Blog
"Inconceivable"
akuhei is offline   Reply With Quote
The Following User Says Thank You to akuhei For This Useful Post:
Old 06-12-2014, 02:48 PM   #1494
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
at what point during rotation at corner exit from WOT does the sliding begin to decrease the vector speed...?
after analyzing my last autocross run against other FRS/BRZ drivers it was made glaringly apparent that I could stand to stand on the gas a lot harder
what I thought was me being gentle with the throttle was simply not enough throttle.. always fearing of having the car drift which leads to lost time.. but I know that there is that certain balance, and curious how others would explain that point in space in time
(I will note however that my carefulness was still enough to land a 2nd place in class finish but I suppose that was due to other factors)
The Following User Says Thank You to 7thgear For This Useful Post:
Old 06-12-2014, 04:41 PM   #1495
TrogDor the Burninator
TrogDor the Burninator's Avatar
Drives: 2013 Hot Lava FR-S 6 MT
This may be a silly question, but in my last NASA track event at Heartland Park Topeka I became curious of the optimum RPM to shift at when traversing the long straight.
Typically I find myself shifting around 7200. (Car is NA with only catback exhaust)
At what point does the maxing out of a lower gear actually take speed away from you if you would have shifted instead? Is it best to ride a gear to the redline or shift sooner?
2013 Scion FR-S Hot Lava 6MT Current Mods: KW V3 Coilovers - Raceseng CasCam Plates - Volk TE37SL Black Edition 18x9 +45 - Dunlop Direzza ZIIs 255/35 - Tomei Expreme Ti 60S - FT86 SpeedFactory UEL Catted Header
TrogDor the Burninator is offline   Reply With Quote
Old 06-12-2014, 04:45 PM   #1496
CSG Mike
CSG Mike's Avatar
Best for lap times? Per dyno, at 7400.
dradernh (06-12-2014)
Old 06-12-2014, 04:47 PM   #1497
CSG Mike
CSG Mike's Avatar
Thank you!!
It looks like the grease you used may have just burned off.
However, even with a lot of pad left, if they faded on you, you need to upgrade a few steps.
Old 06-12-2014, 04:50 PM   #1498
CSG Mike
CSG Mike's Avatar
If you have to reduce steering input to get around the corner, it's faster. If you're countersteering, it's slower. Not reducing steering input enough MAY result in eventual countersteering, so you have to find the fine balance.
Also, remember that you have to be giving the car a lot of throttle to get into the stage where the torsen is helping you turn. You know that feeling where it feels like the car is sometimes about to rotate, but then it just yaws a few degrees, and then just "hooks"? That's you reaching the limits of your tires, and then the LSD "kicking in", and "increasing" rear grip by forcing the rear tires to work together. From here, the next step is increasing that rotation without getting to the point where you're countersteering.
A (properly tuned) Cutch type LSD substantially smooths out the engagement of the LSD, and makes the window for throttle steering, literally, like 5x bigger. Drivers who can throtte steer a Cutch type LSD can't always throttle steer a Gear type, but those that can throtte steer a Gear type will always be able to transition to a clutch type.
The Following 3 Users Say Thank You to CSG Mike For This Useful Post:
7thgear (06-12-2014), BatStig (06-13-2014), RehabJeff86 (06-13-2014)
Simple question, hard to find answer... Mango22 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 5 05-16-2013 07:23 PM
Silly question about protecting track rims sw20kosh Tracking / Autocross / HPDE / Drifting 16 04-25-2013 01:34 PM
Asking the question that I already know the answer to. Are the engines the same? Bigmaxy Engine, Exhaust, Transmission 10 01-19-2013 08:47 PM
Random dog-related question for those who have their BRZ GMU-BRZ BRZ First-Gen (2012+) — General Topics 11 05-31-2012 08:48 AM
Got my answer - BRZ comes with HID headlights as STD Z_Rocks BRZ First-Gen (2012+) — General Topics 20 01-10-2012 10:54 AM
