| View Poll Results: Where do you set your rev limiter? | |||
| Below 7000 |
37 | 28.46% |
| 7000 |
37 | 28.46% |
| 7100 |
5 | 3.85% |
| 7200 |
9 | 6.92% |
| 7300 |
8 | 6.15% |
| 7400 |
24 | 18.46% |
| Above 7400 |
10 | 7.69% |
| Voters: 130. You may not vote on this poll | |||
#15 |
Drives: 2014 FR-S Monogram Hot Lava
Just to be clear the FR-S does have a fuel cut off that kills power at high rpms. Not sure if the adjustment to the indicator light affects the operation of this cut off, or is it just a warning signal.
#16 |
Emperor JDM
Drives: '91 MR2 Gen3 3SGTE, '13 FRS
7100. By the time the light comes on and going to make the upshift, should be 7300rpm.
#17 |
Drives: '13 Nissan Frontier (4.0L 6spd 2WD)
7k rpm for me...see the shift indicator light and hear the beep every day...
Had a '13 FR-S Asphalt 6spd manual (bought new 5/25/12, sold 6/10/20) but needed to let her go... she will be missed.
#18 |
EndlessClouds
Drives: 2013 Scion FRS
Take your dreams and smash it!
#19 | |
Drives: 2013 asphalt scion FRS
its just a warning. it doesn't matter if you set it at 2000 rpms. at 7500 the car will cut fuel
2013 raven frs(dd/grocery getter)
1990 mitsu eclipse gsx(street/strip car) 1995 gmc 1500 4x4(off road toy) 2005 Yamaha yz250f |
#20 |
StreetKart
Drives: 2014 Scion FR-S Monogram
good lord some of you people are slow to react... i have mine set at 7300..
TRD|Verus Engineering|Titan7|DEZOD Motorsports|JDL Auto Design
#21 |
Toyota Master Tech
Drives: Whiteout MT
And people wonder why their transmissions grind....
#22 |
Hardworking
Drives: 2013 Subaru Brz, 2013 C300 4Matic
I set mine at 3500 because I simply like to hear the beep, gives me the impression I'm revving hi. Note: I'm a daily driver, not a racer/tuner and have an automatic
![]() Sent from my Nexus 4 using Tapatalk
Lawyer in NJ and Pennsylvania.
My BRZ gets me to court quick! 2013 WRB BRZ Limited 2013 C300 4Matic Septa, NJtransit, MTA |
#23 |
Drives: Toyota GT86 Coupe Red (UK)
#24 | |
Drives: 2006 Cayman S, 2007 Outback 2.5i
(That doesn't mean you always want to shift at redline, just that you always want to shift past peak power) |
#25 |
Indeed and a car gear box is correctly tuned when it hits peak power at it's top speed and cannot go faster, cause if it tries to the power starts to fall and it stops accelerating.
Obviously this depends on a load of factors, most notably air temp and pressure, hills, road surface, dry/damp etc. |
#26 |
Just a dude
Drives: Scion FR-S 2013
People look at the dash while getting their F&F on?
#27 | |
When torque to the ground in 2nd gear exceeds the same in 1st, that is your optimal shift point. If 2nd never exceeds 1st, then you should shift at redline. Because of the way gearing is setup in most cars, it ends up that the optimal shift point is at/near readline in the lower gears, but gets lower as you go up the gears.
2022 BRZ Build 2013 FR-S Build |
#28 |
Remember that torque does nothing unless it "operates over rotation".
Throwing units out of it for simplicity. Power output = Torque * RPM. So DarkSunrise your method needs to take account of the drop in RPM the torque is applied at. (As above if you just forget the units and multiply torque directly by RPM is easiest). If you actually want "Watts" or "Horsepower" there are a few more complexities. Examples.... 200Nm torque @ 3,000rpm == 100Nm torque @ 6,000rpm. 200Mn torque @ 6,000rpm > 220Nm torque @ 4,500rpm. In terms of power output, which is the energy transferred to the car in the form of momentum. aka Speed. EDIT: And... if your engine is delivering 200Nm torque at 6,000rpm, regardless of what gear you are in or what size of wheels you have the actual power output at the wheels is the same. In a lower gear, you will just have higher torque applied at a lower rpm, same energy. |
| Fast / slow rev limiter??? | Mike86 | Engine, Exhaust, Transmission | 19 | 09-09-2013 10:01 AM |
| Lets talk rev limiter. | Method | Engine, Exhaust, Transmission | 7 | 06-13-2013 09:20 PM |
| Top/Speed limiter for the 86? | DriftEightSix | AUSTRALIA | 4 | 09-12-2012 01:53 AM |
| Rev limiter? | feldy | Scion FR-S / Toyota 86 GT86 General Forum | 4 | 06-03-2012 10:47 PM |
| <3 my rev limiter | NESW20 | Other Vehicles & General Automotive Discussions | 1 | 05-02-2010 11:05 PM |
