| Software Tuning Discuss all software tuning topics. |
PhoneFlash by EcuTeK
EcuTeK RaceROM Map Switching - Restore Last Map on Startup Trick (VIDEO)
Hi All,
I am not sure if this is common knowledge or not but thought we would make a quick video to show a small trick to restore the last map stored when your Toyota 86, Scion FR-S or Subaru BRZ was shut off last. As most of us are aware the vehicle defaults back to map one after a certain time frame of being shut off. This makes restarting the vehicle, and switching to the proper map a nuisance or maybe we are just lazy. LOL For those of you that are not familiar with EcuTeK RaceROM, there is an option your Master Tuner can setup/enable. This allows you the user to switch between multiple maps on the vehicle through the cruise control and a couple other methods. Cruise control is by far the most common approach used from our customer base and what we will go through in the video. [ame="https://www.youtube.com/watch?v=V6wwv46hZN8"]https://www.youtube.com/watch?v=V6wwv46hZN8[/ame] Restore Last Map on Startup - Quick Reference: 1. Turn the vehicle to the "ON Position" 2. Let the gauge cluster do a full sweep 3. Shut the vehicle OFF 4. Now start the vehicle normally Hope this makes things a little quicker and easier for everyone. Have a great weekend. Cheers, William Knose Delicious Tuning |
| The Following 4 Users Say Thank You to DeliciousTuning For This Useful Post: | Chad86 (08-25-2016), Circuit Motorsports (06-07-2014), mkivsoopra (06-06-2014), Sportsguy83 (06-08-2014) |
#2 |
This was posted a while back, but thanks for reminding people and putting together a video. It doesn't seem to be talked about a lot.
http://www.ft86club.com/forums/showthread.php?p=841033 |
| The Following User Says Thank You to mkivsoopra For This Useful Post: | DeliciousTuning (06-06-2014) |
#3 |
It is definitely makes things a little easier for when customers come in and you have no idea what map they were last on and you forget to ask them.
| The Following User Says Thank You to DeliciousTuning For This Useful Post: | Sportsguy83 (06-08-2014) |
#4 |
Whats next?
Drives: '13 Asphalt FRS MT
@DeliciousTuning Does using the Cruise control to switch between maps, Disable your' cruise control function?
Getting boosted soon and I want two maps that I can switch from on the same octane. |
#5 |
Drives: UK GT86
No
.: Stealth 86 :.
| The Following 2 Users Say Thank You to Kodename47 For This Useful Post: | FRS_FIEND (06-08-2014), Sportsguy83 (06-08-2014) |
#6 | |
Here is a quick video on it. [ame="https://www.youtube.com/watch?v=GGdrhnKNr_8"]https://www.youtube.com/watch?v=GGdrhnKNr_8[/ame] Cheers, William Knose Delicious Tuning |
#7 |
Life to short to be slow!
Drives: Toyota GT86
Delicious Tuning, I have a question with the AEM failsafe data log are we able to see a catastrofic failure in a blown enguine?
Can I get ecutek data log by myself or do I need ask the tuner for it? Sent from my SAMSUNG-SM-G900A using Tapatalk
#8 | |
Now you could see some interesting data in your logs that might show where things started to go wrong, but this could have been after the the engine failed. Such things as check engine lights, car running leaner, knock correction, etc... can all happen after the fact. With EcuTeK Dongle, Cable and Software you can log the vehicle yourself. You get the basic logging parameters on a stock vehicle but if your vehicle has been tuned you can grab even more variables to log. Hope that helps, William Knose Delicious Tuning |
| The Following User Says Thank You to DeliciousTuning For This Useful Post: | kombatlion (06-15-2014) |
#9 |
Drives: Toyota GT86
Gracias William, I will start the data log on mine also, It was a friend and we have same turbo kit, same tuner... and meth kit.
#10 | |
| The Following User Says Thank You to DeliciousTuning For This Useful Post: | kombatlion (06-16-2014) |
#11 |
Drives: Toyota GT86
Yeah, not using my meth tune any more.
| 200+ WHP Completely Stock Vehicle, E85 and EcuTeK ProECU RaceROM Only (VIDEO) | DeliciousTuning | Software Tuning | 156 | 07-01-2014 09:37 PM |
| EcuTek map switching with OFT? | andrew5826 | Software Tuning | 25 | 05-10-2014 04:23 PM |
| EcuTek RaceRom Questions. | feldy | Engine, Exhaust, Transmission | 7 | 02-12-2014 05:07 PM |
| EcuTek racerom feature help | lbroskee | Engine, Exhaust, Transmission | 10 | 05-08-2013 11:45 AM |
| Trick to restrat on last map used on ecutek | Mars2 | Engine, Exhaust, Transmission | 23 | 04-05-2013 05:30 PM |
