Old 06-06-2014, 01:49 PM   #15
FirestormFRS
The most common area for any engine to leak oil is the area where TCC, Head, and block meet. With the differences in the metal expansion/retraction due to heat the sealant used will eventually crack. The crack will allow small amounts of oil to leak. There really isn't a good fix for it once it starts other than removing the TCC and cleaning the intersection well. Reapply sealant and allow it to cure fully.
FirestormFRS is offline   Reply With Quote
Old 06-06-2014, 02:28 PM   #16
carbonBLUE
Reverse Burnouts
Drives: 2013 Argento FRS
its not the TCC, its coming from below the top of the engine. the only part that has oil on it is the front, and with the stock intake its hard to see where exactly its coming from
2000 Carbon Blue Toyota Celica GTS 152000 miles
(wont forget you)
2013 Argento Scion FR-S
2011 Infiniti G37x
carbonBLUE is offline   Reply With Quote
Old 06-06-2014, 02:34 PM   #17
Accurate Race Shop
Accurate Race Shop's Avatar
Drives: Scion FR-S
Add me to the list as well mine is on the passenger side. Took it to a toyota dealer they said they are not sure where it's coming from and told me I have to take it to a scion dealership. I am waiting to get an appointment to take it in.
Sent from my Q10
Old 06-06-2014, 02:43 PM   #18
bjun
bjun's Avatar
Drives: white premium brz M/T
You can see small cracks on my engine in the picture, do you think that's the problem?
bjun is offline   Reply With Quote
Old 06-06-2014, 03:18 PM   #19
carbonBLUE
Reverse Burnouts
mine is the same, probably worse lol
(wont forget you)
2011 Infiniti G37x
Old 06-06-2014, 04:42 PM   #20
Dezoris
Dezoris's Avatar
Garbage.
Old 06-06-2014, 05:12 PM   #21
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
No. That is roughness from the casting process when they make the block, it's not worth the OEM's time to prep every block so it looks pretty.
Some examples:
http://www.mitsu-media.com/forums/sh...ad.php?t=14522
http://twinturbo.net/nissan/300zx/fo...et-Part-2.html
ineedyourdiddly
Old 06-06-2014, 06:35 PM   #22
bjun
bjun's Avatar
Some examples:
Oh sounds reasonable. I thought they were cracks when I was cleaning the leak today
Old 06-06-2014, 10:07 PM   #23
Accurate Race Shop
Drives: Scion FR-S
Let me know if anyone makes it to the dealership before me what they find out. I'm not looking to have an engine fire from an oil leak. I have seen to many people say it's just a little oil and then a few weeks later post a picture of a ball of flames because a small leak turned into a big leak.
Sent from my Q10
Old 06-09-2014, 10:32 AM   #24
Tt3Sheppard
Tt3Sheppard's Avatar
Drives: Whiteout FR-S
I'm curious about this as well I just hit 41k and I've been having a burning smell come through the vents a lot lately. Will be doing a thorough inspection of the engine bay.
2013 Ford Focus St
2013 Scion FR-S
2007 Honda Civic Si
2003 Acura RSX Type-S
1998 Ford Escort ZX2
Tt3Sheppard is offline   Reply With Quote
Old 06-09-2014, 11:48 AM   #25
choi0706
Drives: t
this is where the leak is..
choi0706 is offline   Reply With Quote
The Following User Says Thank You to choi0706 For This Useful Post:
Tt3Sheppard (06-09-2014)
Old 06-09-2014, 11:57 AM   #26
choi0706
Drives: t
you can run your hand underneath the chain cover to feel for leaks..
Old 06-09-2014, 01:32 PM   #27
FrX
Drives: 2013 Scion FR-S, 1993 Lexus SC300
I noticed a leak in the same location on my car while inspecting it recently. Car has 22k miles on it ( 8k boosted ). Bought 5/31/2012. Can't do much about it for now. Will keep an eye on it and my oil levels for the near future.
FrX is offline   Reply With Quote
Old 06-09-2014, 09:51 PM   #28
carbonBLUE
Reverse Burnouts
my leak isnt from here though :/ its form the front, top side not bottom
(wont forget you)
2011 Infiniti G37x
Water Leak inside passenger side floorboard AtlasMick Issues | Warranty | Recalls / TSB 30 03-28-2019 05:43 PM
New Body Parts from WORKS WORKS Exterior Parts - The Rest 2 06-13-2014 07:58 PM
Tranny fluid or engine oil leak? G.I.Choe Issues | Warranty | Recalls / TSB 1 05-28-2014 07:53 AM
Small Oil Leak under center of engine? brillo Issues | Warranty | Recalls / TSB 6 11-09-2013 10:52 PM
Wanted: drivers side front fender Yruyur Miscellaneous 0 11-26-2012 10:30 PM
