Old 06-06-2014, 12:14 AM   #1401
gmsii
gmsii's Avatar
Originally Posted by post_break View Post
Has running the car without the belt been covered in this thread? Is there an official way to do so as stated by kraftwerks? My belt didn't break but I'd like to know how to limp home if that time ever came.
Removing the broken belt should be enough...you should be able to draw through the supercharger compressor without issue...if you disconnect the intake tube, you will be drawing unfiltered air into the engine...which shouldn't be a problem either unless you are planning to drive a while on a dirt road
gmsii is offline   Reply With Quote
Old 06-06-2014, 11:34 AM   #1402
glamcem
glamcem's Avatar
Drives: 2022 BRZ Limited
Question Lightweight crank pulley
@KraftWerks @gmsii Is there a way to use an aftermarket/lightweight crank pulley with the kit? I know the crank pulley hub adapter uses the slots on the OEM pulley but I was just wondering if you know any aftermarket pulley that I can use to help the engine rev a bit faster ( since it will help dramatically for the track use when I blip the throttle to rev match the car)..
Thanks in advance
glamcem is offline   Reply With Quote
Old 06-06-2014, 01:10 PM   #1403
SPCorBUST
SPCorBUST's Avatar
Would like to know this as well!
New aluminum or carbon drive shaft should help as well
Sent from my SGH-M919 using Tapatalk
Setup 3: JR C30, DW 700, Grams 265, 3bar, FlexFuel, Moto-East
Setup 4: JR C30 HBP, DW 700, Grams 265, 3bar, FlexFuel, Church
Setup 5: JR C30 HBP, DW 700, DW 300, 3bar, FlexFuel, Delicious, Built Motor
Setup 6: JR C30 HBP, DW 700, DW 300, 3bar, FlexFuel, Delicious, Closed Deck Built Motor
SPCorBUST is offline   Reply With Quote
Old 06-06-2014, 01:25 PM   #1404
Taino-BRZ
Taino-BRZ's Avatar
Drives: Subaru BRZ-SWP
I have the aluminum drive shaft, I'll say the difference is significant. Car accelerates faster. I have the drive shaft shop one.
Taino-BRZ is offline   Reply With Quote
Old 06-06-2014, 01:33 PM   #1405
post_break
Professional Smartass
post_break's Avatar
Drives: White Out FRS
Does yours vibrate? I can't stop the vibration at 60mph. Drives me insane.
post_break is offline   Reply With Quote
Old 06-06-2014, 01:38 PM   #1406
Taino-BRZ
Taino-BRZ's Avatar
No mine doesn't, maybe you need to rotate yours, I read somewhere that might help
Old 06-06-2014, 01:52 PM   #1407
SPCorBUST
SPCorBUST's Avatar
I'll be installing mine next weekend. Today is all day dyno tuning :-)
Old 06-06-2014, 06:11 PM   #1408
Freeman
Freeman's Avatar
Drives: 2013 Ultramarine FR-S
I had to send my DSS aluminum shaft back to get rebalanced, after that no noticeable vibration under 80mph. I had tried repositioning it 4 times, no luck.
Freeman is offline   Reply With Quote
Old 06-06-2014, 07:01 PM   #1409
Model Citizen
Lacking brains
Drives: frz
I lucked out. Got the rotation right first try on my cf dss shaft.
Originally Posted by cjsporl1996 View Post
If this thread is not deleted I can file a lawsuit.
Model Citizen is offline   Reply With Quote
Old 06-06-2014, 07:54 PM   #1410
glamcem
glamcem's Avatar
Originally Posted by vgi View Post
circuit werks from ebay works, at least it was left on mine.
Do you have a picture of the crank pulley or link?
I couldn't find a pulley that looks like a good fit for the crank hub adapter that comes with the kit, like the OEM piece..
Old 06-06-2014, 09:06 PM   #1411
gmsii
gmsii's Avatar
Thanks in advance
the KW crank adapter was designed for use with the stock crank pulley.
we are not familiar with aftermarket pulley designs so we cant really comment whether they will work with our pulley adapter. however, because we are using a cogged belt a certain amount of pulley misalignment/offset will be acceptable (ie the offesets of the machined aluminum faces on the pulley become less critical. there bigger concern would be whether the aluminum pulley allows the KW adpater to be hubcentrically centered per KW design.
generally we steer away from using any non-dampened aluminum crank pulley on the sheer basis that it does not have enough mass to dampen harmonics in the rotating assembly. furthermore, the change in material and diameter does not make a significant change to the the moment of inertia. our experience has shown us that a proper crank damper dampens harmonics, smooths out the engine, and increases power; aluminum crank pulleys are NOT dampers.
If your goal is to improve the throttle response and how quickly the engine revs up and down, then you need to look at the rotating assembly as a whole and start with areas with the highest moment of inertia (ie flywheel, clutch, crank&rods)
so back to the subject of aluminum crank pulley with KW crank adapter, i think the easy answer would be: not recommend, use at your own risk.
Old 06-06-2014, 09:10 PM   #1412
glamcem
glamcem's Avatar
Did you install the kit yet? I wonder how you managed to insert the hub adapter to the lightweight pulley since holes look like it won't fit in
Old 06-06-2014, 09:27 PM   #1413
gmsii
gmsii's Avatar
the kit is installed. ping @PrimeMotoring
how did you center the KW hub adapter?
did you grind the 4 nubs off the back of the KW adapter?
...seems a bit iffy
perhaps they are still using the stock crank pulley and just changed the waterpump and alternator pulleys
Old 06-06-2014, 09:40 PM   #1414
glamcem
glamcem's Avatar
...seems a bit iffy
That doesn't look like the stock pulley since it looks like there are more than 4 holes on it.. I also think they either trimmed it or fabricated somehow ..I wonder how it would affect the rigidity..
Do you know any lighter aftermarket crank pulley that keeps the OEM design and compatible with your adapter hub?
Kraftwerks Rotrex Supercharger Discussion nelsmar Forced Induction 697 01-18-2022 12:06 PM
All SUPERCHARGER kits compilation thread subatoy Forced Induction 76 03-10-2016 12:38 PM
Kraftwerks Supercharger?? umpadupa Forced Induction 1 08-05-2013 05:27 PM
