Tip in knock?
Hi all. I've searched this forum and couldn't find any specific info but I did find someone on youtube that posted the same symptoms that I'm experiencing. It happens on 1-2 shifts and 2-3 shifts at standard rpm shifts(3-4k). If anything it seems to happen less frequently at high rpm. Car is a 2014 purchased late December 2013 and currently has 10k miles. Happens on all different brands of 91 gasoline in Southern California. No modifications.
[ame="https://www.youtube.com/watch?v=g8nnFeP7ib0"]Frs/Subaru Brz "tip in knock"? and VVT sound - YouTube[/ame] Any help would be appreciated. |
#2 |
Drives: FT86
Yep stock tune requires 93 octane (usa) for best result and minimum knock, on 91 it going to knock .
especially in areas you quote even on 93 it will get tip in knock occasionally no where near what it will be on 91 If you on older rom series eg 700 900 or A00 its worth getting dealer to update to at least A01 or preferably B01 series rom as these have transient ignition retard enabled, they will reduce that type of knock which was apparently the cause of some DI seal failures. If your not on the later series rom get dealer to update. however if your car is fairly new it likely to be on the later rom. Unless your going to modify tune your only option is to run better fuel see below for further info (for tip in knock) You rearly need to log the knock parameters to be sure its knock though. http://www.ft86club.com/forums/showthread.php?t=61820 Last edited by steve99; 06-04-2014 at 03:48 AM. |
| The Following User Says Thank You to steve99 For This Useful Post: | bmsi30 (06-04-2014) |
#3 | |
Take a listen to my under the hood audio on track its very very loud. And this is completely logged, zero knock etc. [ame="http://www.youtube.com/watch?v=wGcv6SKj858"]Vortech FR-S Track Testing | Audio and Video Testing - YouTube[/ame]
| The Following 4 Users Say Thank You to Dezoris For This Useful Post: |
#4 |
Drives: 2014 BRZ Limited
LOL at that Mustang clogging up the turns.
| The Following User Says Thank You to extrashaky For This Useful Post: | Synack (06-04-2014) |
#5 |
Thanks for all the replies! I will keep an eye on it.
#6 |
Drives: Audi A3 2012
it's my video
at first i thought it was knock but my datalogs has showed no sign of knock like Dezoris said im sure it's related to throttle Ive tried a lot of frs/brz and all of them do that
Moto east Ecutek /JDL UEL Header/Nameless Performance axleback exhaust-Motiv overpipe/Full Perrin CAI/BC Racing Coilover/Traklite angle 18x9/Federal 595 RS-R (245-35-18)/Blackhousing,hid 4300k headlights/Crystal eyes taillight/Anarchy Motive Heavy ShiftKnob/Cusco Sport pedals/Jpm Coachworks alcantara dash panel,cluster,shift boot,
| The Following User Says Thank You to mxsled For This Useful Post: | bmsi30 (06-04-2014) |
#7 | |
Drives: '13 FRS - STX
The manual specifically states that 91 octane is perfectly acceptable for the vehicle and will cause no damage. |
| The Following User Says Thank You to strat61caster For This Useful Post: | bmsi30 (06-10-2014) |
#8 |
Turbo 86
Drives: GT86
it is normal
10 - 1 = 0
real math |
| The Following User Says Thank You to calibrz For This Useful Post: | bmsi30 (06-10-2014) |
#9 | |
Drives: FT86
The ecu works by detecting knock then retarding timing, then it waits a bit and starts advancing timing till it either get to the maxium values or it detect knock again. On 91 it will generally start to detect knock before it gets to the max advance values so it drops advance again. So its in a cycle of knock detect retard advance knock detect, the knock it detects is reliativly minor but its still knock. The older roms it appears they forgot to enable the transient ingnition timing retard feature in the ecu to its definitly worth getting the newer roms flashed by dealer it often refered to as the DI seal fix as some cars driven hard were getting damage to DI seals due knock
| The Following User Says Thank You to steve99 For This Useful Post: | hmong337 (08-25-2014) |
#10 | |
| The Following User Says Thank You to strat61caster For This Useful Post: | steve99 (06-04-2014) |
#11 | |
Drives: None (yet)
What part of the throttle is making this noise? Thanks!
#12 |
StreetKart
Drives: 2014 Scion FR-S Monogram
mine has a part throttle tip in knock when its above 95*... i've been making sure i run pure 93 octane and not abusing it when its so hot now.
TRD|Verus Engineering|Titan7|DEZOD Motorsports|JDL Auto Design
#13 | |
#14 | |
Drives: None (yet)
I'm not saying I'm an expert on the matter but I'm not ready to just start ignoring it as normal sound without a bit more evidence. I drive 'around' it so that it doesn't happen in case it is pinging. Edit: For the record, this only started happening a few months ago. From when I completed the break-in (mid January) up until ~May, it did not make this noise at all. I know there were some ECU updates surrounding some of this, so I'm going to have the dealer take a look at my version (Its a 2014, but I bought it on December 31st, 2013). I would like to get to the bottom of it since it keeps me from having as much fun in the car.
| Does this sound like 'tip-in knock'? | 1Cor10:23 | Engine, Exhaust, Transmission | 48 | 04-02-2016 02:06 AM |
| Knock Correction vs Knock Correction Learn values? | swift996 | Software Tuning | 19 | 11-03-2015 11:09 PM |
| FR-S Rod knock | pozer | Issues | Warranty | Recalls / TSB | 95 | 11-03-2015 10:39 AM |
| Header Knock | 912matthews | Engine, Exhaust, Transmission | 3 | 04-26-2014 03:19 PM |
| Would you rather buy knock off parts for your car? | EJ20 | Engine, Exhaust, Transmission | 63 | 11-02-2011 07:17 PM |
