2.1L 3SGTE
Drives: MR2 Turbo & Tacoma
which brake pads?
I'll likely run the factory pads until i either get pad fade or wear them out. once either of those two things happen, i might simply step up to porterfield R4S pads, or depending on how i like the carbotech xp8 pads i'll be putting on the MR2 shortly, i may get those. anyone else?
1991 MR2 Turbo - 2.1L high compression stroker 3SGTE
2006 Tacoma 4x4 TRD Off Road - All-Pro front bumper, Old Man Emu shocks, Old Man Emu HD front coils, All-Pro leafs 1990 240SX Coupe - sold 2008 Civic Si Sedan |
#2 |
Drives: Volkswagen Golf GTI
Have you considered installing the TRD brake pads? (If it is sold over here in NA)
#3 |
2.1L 3SGTE
i guess it's something i would consider looking into, but i assume those would be in between OEM and the R4S pads in terms of bite and fade resistance. we'll see what happens on-track.
#4 |
Site Moderator
Drives: Stuff
Street: I'll run OEM pads most likely, unless they have serious issues.
Track: I'll start with Carbotechs and go from there. Most likely I'll start with XP12s up front and XP8s in the back.
-Dave
Track cars: 2013 Scion FRS, 1998 Acura Integra Type-R, 1993 Honda Civic Hatchback DD: 2005 Acura TSX Tow: 2022 F-450 Toys: 2001 Chevrolet Corvette Z06, 1993 Toyota MR2 Turbo, 1994 Toyota MR2 Turbo, 1991 Mitsubishi Galant VR-4 Parts: 2015 Subaru BRZ Limited, 2005 Acura TSX Projects: 2013 Subaru BRZ Limited track car build FS: 2004 GMC Sierra 2500 LT CCSB 8.1/Allison with 99k miles |
#5 |
This. Or maybe tens up front,I can't remember and I have a couple beers in me at the moment
#6 | |
Site Moderator
Drives: Stuff
I'll be talking to carbotech soon about it.
-Dave
#7 |
Registered you sir
Drives: 99 impreza coupe
No complaints with bobcats on the street. Ill have to wait for more figures to decide what kind of competition setup (same calipers and rotors?) Id end up with.
#8 |
2.1L 3SGTE
i understand that to mean you swap pads at the track before and after you run, right dave?
so far my research has pointed me in the direction that xp8s can be run on the street but once you step up to the 10s and 12s, it becomes a pretty bad idea in terms of bite and rotor wear. how long have you used carbotech pads? is there anything you don't like about them? and how many track days do you generally get out of them?
#9 |
Drives: 2006 Scion tC RS 2.0
I run Carbotech Bobcats up front and can keep XP8 on the rears on my tC on the street. I switch to XP8 for the front when I track. You should NEVER run AX6 or above on the street unless you plan on replacing rotors with the same frequency as changing your oil, and plan on cleaning your wheels every two days... I speak from personal experience Hahahahahaha!!
As for pad life, you'll get 3-6 HPDE days and a full season of Auto-x.
Brake. Turn. Accelerate. Repeat as necessary.
#10 | |
Site Moderator
Drives: Stuff
I use to be a Hawk Blue user, used to swear by them, destroyed paint and all but I've seen the light. I love how aggressive Blues are but the short life and iron damage to.. well everything isn't something I'm willing to accept anymore. For awhile I was a Cobalt user, but I'm not a fan anymore. I have a set of XR3s for the ITR as well, the initial bite sucks. They stop the car, it's just not the brake feel I expect and want. Every time I'd go deep I'd have a split second of "oh crap where are the brakes? oh.. there..." with them. And yes, I change at least pads, sometimes rotors and pads for track days. "Light duty track"/"Semi streetable" pads aren't my cup of tea. I try not to make too many compromises on the track, especially as it relates to brakes and safety. For me, the expense (and extra time spent) is worth it.
-Dave
#11 |
2.1L 3SGTE
thanks for the input! i'm not going to be endurance racing the MR2, so i think the lower-level track pads should be good for 20 minute sessions. i'm 100% in agreement that brakes are not something to cheap out on, which is precisely why i'm going with the more effective 93T brakes and track pads. street/autocross pads won't cut it for more than a couple laps.
on the FRS/BRZ, i don't anticipate using it as hard on-track as the MR2, but we'll see what happens...
#12 | |
Site Moderator
Drives: Stuff
-Dave
#13 | |
2.1L 3SGTE
after re-reading carbotech's description of their different compounds, i think i definitely want the XP10s at least on the front of the MR2, with XP8s on the rear. maybe xp8s all around on the FRS/BRZ. i appreciate the input, and i swear i'll make it to tampa one of these days.... lol
#14 |
Drives: 2017 Subaru BRZ PP
Probably the Endless NS97. They are the best all around pads but are fookin expensive! BTW, these are the stock pads:
![]() They call them "Sports Pads" But they're made by Advics which is a joint effort of Aisin, Denso, and Sumitomo. |
| The Following 4 Users Say Thank You to Bristecom For This Useful Post: |
| Brake cooling duct kit | tranzformer | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 14 | 12-14-2011 01:37 PM |
| FR-S Rear brake light... | MF_DEUCE | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 70 | 05-05-2011 03:53 PM |
| Secondary Rear Brake Caliper for drifting or parking brake?? (pics) | Axel | Scion FR-S / Toyota 86 GT86 General Forum | 20 | 02-25-2010 10:28 AM |
| Brake override system in the FT-86? | mrKiKaZ | Scion FR-S / Toyota 86 GT86 General Forum | 10 | 02-22-2010 11:33 AM |
