Old 05-22-2014, 04:50 PM   #267
Norkoastal
Never on Time Always Late
Norkoastal's Avatar
Drives: #silenced crickets
Nothing against the "rub doctor," but can we have more unmolested cars chime in to verify if their drive shaft was violated by the TRD part? The violated car car has many small parts installed that may have a part in this inappropriate rubbing.
CO>CA Cartel
Norkoastal is offline   Reply With Quote
Old 05-22-2014, 04:57 PM   #268
OrbitalEllipses
Drives: Attitude
Originally Posted by xxBrun0xx View Post
I've got no rubs, no rattles, no noises at all. Also, for people who are between shifters, few things to keep in mind:
1. Toyota/Subaru cannot void your warantee with the TRD Quickshifter. Not sure they would with any other short shifter, but why take the chance?
2. The other shifters you guys are comparing to (Kartboy/BPS/TWM/etc) are +$100 more expensive than this.
3. Throws are actually shorter in the TRD
Got a receipt/work order showing it was installed by a professional or the dealer? Yeah, didn't think so. Subaru will shit on you all day and a Toyota dealership might play ball if you produce a receipt though I doubt it.
chanomatik (05-22-2014)
Old 05-26-2014, 11:45 AM   #269
Such Boost
Drives: 13 FRS
Originally Posted by Sprchrgd View Post
I did my install without a lift, just using two factory jacks most cars come with.
Please don't do stuff like this... Just go to walmart and spend 50 bucks on ramps. Factory scissor jacks aren't really intended for stuff like this and plenty of people have died from cars falling on top of them.
Not trying to give you shit but seriously, that's not safe.
Such Boost is offline   Reply With Quote
The Following 3 Users Say Thank You to Such Boost For This Useful Post:
Hanakuso (08-21-2014), swpbrz (05-31-2014), texasbound972 (05-26-2014)
Old 05-26-2014, 02:29 PM   #270
tjohnson104
Drives: brz
mine has this buzzing vibration in second gear only now... not at a certain rpm, but just no matter how fast I drive in second its there. and I can tell the shift throws are getting longer and longer, witch means that that dumb adapter bolt is coming undone.. again.
tjohnson104 is offline   Reply With Quote
Old 05-26-2014, 02:31 PM   #271
texasbound972
USMC
texasbound972's Avatar
Drives: 2013 FR-S 6-MT Raven
Again?? Not cool! I have had and still have that cluttering noise when in neutral when slowing down.
Sent from my SAMSUNG-SM-N900A using Tapatalk
texasbound972 is offline   Reply With Quote
Old 05-26-2014, 02:52 PM   #272
husker741
Drives: 2013 Whiteout Scion FR-S 6MT
Was so close to ordering until reading the last few pages. Thanks for the info, guys. I recommend letting TRD USA know about this so maybe they will make an upgrade.
husker741 is offline   Reply With Quote
Old 05-26-2014, 06:50 PM   #273
daiheadjai
daiheadjai's Avatar
Drives: 2003 S2000, 2008 Fit
Get some jackstands.
Canadian Tire sometimes has sales on 2T Michelin jacks for $15.99 CAD (2 per pack).
daiheadjai is offline   Reply With Quote
Old 05-26-2014, 06:53 PM   #274
Such Boost
Drives: 13 FRS
Reason I suggested ramps was because jack stands are best if you use 4 and if you have a floor jack. A stock scissor jack will not always provide enough lift to use jack stands effectively.
Figured since he was using two scissor jacks, the idea of spending 150 bucks on a good jack and stands might be ill-received.
That being said, I don't own ramps. I use a jack and 4 stands from harbor freight. No problems thus far.
So spool.
Much Power.
Wow.
daiheadjai (05-26-2014), FR-S Matt (05-27-2014), swpbrz (05-31-2014)
Old 05-27-2014, 11:00 AM   #275
xxBrun0xx
xxBrun0xx's Avatar
Drives: 2014 WRB BRZ Limited
Did you use any blue loctite? Since putting loctite on that bolt on mine, haven't had any issues. No buzzing, no loosening up, etc.
Also, it sounds like you have something else going on. When that bolt starts to come loose, throws don't get longer. What happens is the play in gear/in neutral increases, particularly side to side (forward/backward play does not increase). Sounds like the adapter bolt isn't your problem.
xxBrun0xx is offline   Reply With Quote
The Following User Says Thank You to xxBrun0xx For This Useful Post:
unsurety (05-27-2014)
Old 05-27-2014, 11:21 AM   #276
FR-S Matt
Been using the harbor freight low profile jack and jackstands for almost 2 years now with 0 issues. I love how they have the pinch weld support in the center on the jackstands. Sorry to derail the thread, but safety is important when it comes to lifting your car.
Old 05-27-2014, 11:29 AM   #277
jpit
Drives: Subaru BRZ
Talking about safety - remember when you have your front wheels on a ramp and you start jacking up the rear end there is a chance that the car will roll down the ramp. The front wheels are unaffected with the emergency brake on and the car in gear. Make sure you use chocks.
jpit is offline   Reply With Quote
The Following User Says Thank You to jpit For This Useful Post:
swpbrz (05-31-2014)
Old 05-27-2014, 01:12 PM   #278
tjohnson104
Drives: brz
well I dont have the side to side slop. but maybe its just because I got use to the short throws?? idk lol. But i was going to look under there when I do my oil change pretty soon so I will drench that bolt in loctite
The Following User Says Thank You to tjohnson104 For This Useful Post:
xxBrun0xx (05-28-2014)
Old 05-28-2014, 04:58 PM   #279
tomkozski
Drives: 2017 WRB BRZ w/ PP
I have the TRD Quick Shifter installed on my BRZ. So far no issues. Took a while for it all to break-in - initially required more effort to shift, was very notchy - but it's gotten better now. Our cars should've come this way from the factory. My BRZ has had no modifications to the driveshaft.
tomkozski is offline   Reply With Quote
The Following User Says Thank You to tomkozski For This Useful Post:
Old 05-28-2014, 10:57 PM   #280
zoth
zoth's Avatar
Drives: 2013 BRZ Premium Dark Gray Metallic
Installed mine last weekend and all I can say SWEET!!!!!!!!! Enjoying my SC car more with E85
zoth is offline   Reply With Quote
TRD Quickshifter lovebeingbleu98 Brakes, Suspension, Chassis 3 02-13-2014 12:14 AM
Amazing Wax geb2391 Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 27 04-12-2013 04:42 PM
The most amazing thing I've done with my BRZ so far azngolfur BRZ Photos, Videos, Wallpapers, Gallery Forum 8 01-09-2013 08:23 PM
Concept-Three-LED's DRL's are AMAZING! soros151 Cosmetic Modification (Interior/Exterior/Lighting) 4 11-09-2012 01:42 AM
