Old 05-26-2014, 02:47 AM   #1
ActionJackson
Drives: Miata
Built engines
I am intrigued. All these 450+ hp brzs/frs talking about fully "built engines".
I have a couple questions for the veterans.
1. What has to be done to the engine to fully build it?
2. What's the general cost for parts and labor on building a brz engine?
3. Once the compression ratio is lowerd I have my big ole turbo kit in it and my racing clutch.... It's there anything else mandatory to swap out to Handel increase in power/torque
4. (Off topic). Jackson racing makes a super charger for these guys and I was wondering, if it made 100 more hp and 45% more torque with no building or compression changing.... In theory would lowering the compression ratio increase output? Or is that entirely based on the forced induction kit you have on the car....
5. If I lowered the compression ratio with no added forced induction would the car run ultra sluggish?
6. (Off topic). What are the stock speakers like? And brakes? It's the car super tail happy with the thin tires?
7. Is everything crawford did there brz really necessary? I drool over that car and I see it has 30+ grand after market in it and I feel two achieve that sort of power and race compatibility you don't need to double the price of the car.... Correct me if I'm wrong, it does seem like they've got there act straight.
Anyone and everyone feel free to answer whatever you like I'm open to all opinions and facts,
Thank you,
AJ
P.S. I'm also new to the forum and I'm glad to find a forum with so many step by step builds and avid tuners as this I look forward to posting my project once it is....well.... Purchased.....
ActionJackson is offline   Reply With Quote
Old 05-26-2014, 03:01 AM   #2
midnight23
dying bird under the hood
Drives: 2013 SWP Limited BRZ
Cost wise, at minimum 15k for turbo kit built motor and supporting mods with labor but that all depends on brand as well. Judging by your questions I'd suggest lurking the forced induction/engine section for a few months and reading up on every bit of info there.
Build Thread
Instagram
Old 05-26-2014, 03:30 AM   #3
J_kennington
Drives: 2013 asphalt scion FRS
typically refers to: redoing the whole internals of the motor itself{pistons, rods, cams, etc etc}
2. What's the general cost for parts and labor on building a brz engine? no idea
technically, no.
lowering the compression ratio will DECREASE the output. for the trade off of being able to run more boost.
absolutely.
this question will get 50/50 answers. I believe the stock speakers are quite decent, brakes work perfectly fine but do fade under extreme stress. car is fine for me on stock tires, stays planted unless I tell it not to.
keep in mind, they built a race car...it costs to race...simple as that.Could you get by with less, probably. would you be in the shop every day after a race, most likely.
Thank you,
AJ
answers bolded in the quote
2013 raven frs(dd/grocery getter)
1990 mitsu eclipse gsx(street/strip car)
1995 gmc 1500 4x4(off road toy)
2005 Yamaha yz250f
J_kennington is offline   Reply With Quote
Old 05-26-2014, 05:33 AM   #4
misooscar
misooscar's Avatar
Drives:
Actually Crawford sells the built motor for 5k on their website.
The Crawford is not a race car, but a daily driver.
Sent from my SM-N900T using Tapatalk
misooscar is offline   Reply With Quote
Old 05-26-2014, 08:46 AM   #5
Basket Case
Drives: 2013 Raven fr-s
If you are willing to do work yourself, I think you can build a motor for around $3k...supposedly the crank is already forged and the Crawford motor uses the stock crank. You can get the rods for around $800-1000, and forged pistons for around the same pricing. There really isn't a cam option out yet, so no money spent there yet. Upgraded valve springs probably wouldn't hurt though. Also, I believe most people are lowering the compression to 11.5/1 like the the DIT motors.
Like others have said, read, read, and read. Check out the forced induction section and the engine section.
Basket Case is offline   Reply With Quote
The Following User Says Thank You to Basket Case For This Useful Post:
misooscar (05-28-2014)
Old 05-28-2014, 02:32 AM   #6
misooscar
misooscar's Avatar
Drives:
DIT?
Old 05-28-2014, 09:30 AM   #7
Basket Case
Originally Posted by misooscar View Post
DIT?
The turbo motors for the other Subaru cars, I believe it is the forester that gets them.
Old 05-28-2014, 12:25 PM   #8
swpbrz
Drives: swp brz limited
I can't understand this. the car is fun stock. And for all the money and hassle why not just find 40k worth of Cayman. Instead you'll have 40k worth of I hope I don't break down.
swpbrz is offline   Reply With Quote
WTB: blown engines AVOturboworld Want-To-Buy Requests 1 02-15-2016 08:37 AM
VR6 engines... dem00n Other Vehicles & General Automotive Discussions 29 01-25-2013 02:41 AM
100 hp/l NA engines einzlr Other Vehicles & General Automotive Discussions 95 11-15-2012 08:55 PM
What other engines fit our transmissions 1strwdcar Engine, Exhaust, Transmission 36 08-02-2012 05:45 PM
So you think you know engines? Ryephile Other Vehicles & General Automotive Discussions 43 02-04-2012 04:49 AM
