#29 |
Drives: 4-Runner Sport - 13' BRZ SportTech
Pretty much bang on with what I see. Where did you install the pressure and temp probes ?
Sent from my HTC One using Tapatalk
Top Tier Imports - Check out my build journal HERE
| The Following User Says Thank You to protpibe For This Useful Post: | Dezoris (05-23-2014) |
#30 |
Drives: Scion FRS Firestorm
@Dezoris Can you get a video going through the RPMs once warm and post it here?
| The Following User Says Thank You to blackfireball5 For This Useful Post: | Dezoris (05-23-2014) |
#31 |
I'm thinking I will update the first post soon with everyones data so that it can be found quicker for people looking for this answer.
#32 | ||
I have a pseudo install video and more detail coming, just been buried trying to get car back together this week.
| The Following 2 Users Say Thank You to Dezoris For This Useful Post: | blackfireball5 (05-23-2014), Tye300 (05-23-2014) |
#33 |
Oil pressure always correlates with oil temp.
I have the pressure gauge hooked up where the stock oil pressure switch is at and I see slightly higher pressure than that. At 198F (after commuting) I see right at 14psi. This is with Eneos Sustina 0w-20. |
| The Following User Says Thank You to xwd For This Useful Post: | Dezoris (05-24-2014) |
#34 |
Drives: Toyota 86
Went to the track today. My oil temp reached 127C (260F). At that temperature, oil pressure was always less than 3.0 bar across the rev range till redline. I set my oil pressure gauge to beep when pressure drops below 3 bar. It was beeping almost the whole time while lapping. It would sometimes drop to 2.5 bar (36 psi) during gear changes or at the corners. Definitely not good. I'm already running 5w30.
#35 | |
| The Following User Says Thank You to protpibe For This Useful Post: | Dezoris (05-24-2014) |
#36 |
Drives: Toyota 86
I already have a Perrin oil cooler and Koyo radiator. Imagine what the oil temp and pressure might have been if I didn't have an oil cooler. My car is also supercharged, which undoubtedly contributes to the high oil temp
#37 |
Oh I didn't even realize. What was the ambient temperature ??
#38 | |
Either this is by design or oversight. But I have to say when I had my 2-3 hour track session oil peaked at 265 with cooler, UOA was perfect. So I can assume pressures were as low as your and no wear materials in oil. We just need to get more people involved again. Maybe guys like CSG, Robi and Evasive. I know @Dave-ROR had logged pressures as well. Lets see if we can get a bunch of data and make a FAQ post.
| The Following User Says Thank You to Dezoris For This Useful Post: | blackfireball5 (05-24-2014) |
#39 |
I got my gauge installed yesterday. I noticed my pressures tend to be higher than what most are reporting here so far.
#40 | |
When my oil is around 170F pressures are still like 50-60 at 2000rpm.
#41 | |
#42 | |
Drives: Toyota 86
I also watched the oil pressure gauge during the 110km drive home. With oil temp at 92C (197F) and cruising at 2700 rpm in 6th, oil pressure was around 4.0 bar (58 psi) with the 5w30 oil. |
| The Following User Says Thank You to HRTROB For This Useful Post: | Tye300 (05-25-2014) |
| Stock clutch+flywheel+pressure plate+ ACT lightweight flywheel & pressure plate | PineappleFriedRice | Transmission and Driveline | 0 | 11-08-2013 05:54 PM |
| Mid range really lacking | goli5oda | Electronics | Audio | NAV | Infotainment | 4 | 08-19-2013 11:27 AM |
| Range on a tank of Gas! | crank | Southern California | 28 | 02-10-2013 05:04 PM |
| Cruising Range? | skoodge | Scion FR-S / Toyota 86 GT86 General Forum | 4 | 05-25-2012 03:31 AM |
| UK Price range £25-£32k!? | ZeeSpeed | Scion FR-S / Toyota 86 GT86 General Forum | 56 | 11-27-2011 03:11 PM |
