Old 05-23-2014, 09:47 AM   #29
protpibe
protpibe's Avatar
Drives: 4-Runner Sport - 13' BRZ SportTech
Pretty much bang on with what I see. Where did you install the pressure and temp probes ?
Sent from my HTC One using Tapatalk
Top Tier Imports - Check out my build journal HERE
protpibe is offline   Reply With Quote
The Following User Says Thank You to protpibe For This Useful Post:
Dezoris (05-23-2014)
Old 05-23-2014, 10:04 AM   #30
blackfireball5
blackfireball5's Avatar
Drives: Scion FRS Firestorm
@Dezoris Can you get a video going through the RPMs once warm and post it here?
blackfireball5 is offline   Reply With Quote
The Following User Says Thank You to blackfireball5 For This Useful Post:
Old 05-23-2014, 10:30 AM   #31
blackfireball5
I'm thinking I will update the first post soon with everyones data so that it can be found quicker for people looking for this answer.
Old 05-23-2014, 10:50 AM   #32
Dezoris
Dezoris's Avatar
Oil gallery plug.
I have a pseudo install video and more detail coming, just been buried trying to get car back together this week.
The Following 2 Users Say Thank You to Dezoris For This Useful Post:
blackfireball5 (05-23-2014), Tye300 (05-23-2014)
Old 05-23-2014, 01:16 PM   #33
xwd
Oil pressure always correlates with oil temp.
I have the pressure gauge hooked up where the stock oil pressure switch is at and I see slightly higher pressure than that. At 198F (after commuting) I see right at 14psi. This is with Eneos Sustina 0w-20.
The Following User Says Thank You to xwd For This Useful Post:
Dezoris (05-24-2014)
Old 05-24-2014, 06:56 AM   #34
HRTROB
HRTROB's Avatar
Drives: Toyota 86
Went to the track today. My oil temp reached 127C (260F). At that temperature, oil pressure was always less than 3.0 bar across the rev range till redline. I set my oil pressure gauge to beep when pressure drops below 3 bar. It was beeping almost the whole time while lapping. It would sometimes drop to 2.5 bar (36 psi) during gear changes or at the corners. Definitely not good. I'm already running 5w30.
HRTROB is offline   Reply With Quote
Old 05-24-2014, 09:36 AM   #35
protpibe
protpibe's Avatar
I ran I to the exact same thing, which is why I have an FBM oil cooler on the way. I I have a track day on June 6th and I'll post up the difference it makes in temp and pressure
Old 05-24-2014, 09:46 AM   #36
HRTROB
HRTROB's Avatar
Drives: Toyota 86
I already have a Perrin oil cooler and Koyo radiator. Imagine what the oil temp and pressure might have been if I didn't have an oil cooler. My car is also supercharged, which undoubtedly contributes to the high oil temp
Old 05-24-2014, 09:59 AM   #37
protpibe
protpibe's Avatar
Oh I didn't even realize. What was the ambient temperature ??
Old 05-24-2014, 12:16 PM   #38
Dezoris
Dezoris's Avatar
This is the issue we don't really have much data on whether or not this is normal. With the car running 0w20 from factory we already know oil temp ranges run from 190 to 225 on the street for a stock car. Spirted driving you can expect 230 easily which means preasures would always benin the 40-60 psi range based on your data.
Either this is by design or oversight. But I have to say when I had my 2-3 hour track session oil peaked at 265 with cooler, UOA was perfect.
So I can assume pressures were as low as your and no wear materials in oil.
We just need to get more people involved again. Maybe guys like CSG, Robi and Evasive. I know @Dave-ROR had logged pressures as well. Lets see if we can get a bunch of data and make a FAQ post.
The Following User Says Thank You to Dezoris For This Useful Post:
blackfireball5 (05-24-2014)
Old 05-24-2014, 12:38 PM   #39
blackfireball5
I got my gauge installed yesterday. I noticed my pressures tend to be higher than what most are reporting here so far.
Wheelwell Profile
Use code TWW-BOO5TED when shopping at Wheelwell to receive 10% off your order.
Old 05-24-2014, 12:57 PM   #40
Dezoris
Dezoris's Avatar
They are definately higher until you get plenty of heat in the oil.
When my oil is around 170F pressures are still like 50-60 at 2000rpm.
Old 05-24-2014, 01:00 PM   #41
blackfireball5
Hmmm. Alright. I'll just have to do more testing and see.
Wheelwell Profile
Old 05-25-2014, 07:54 AM   #42
HRTROB
HRTROB's Avatar
Drives: Toyota 86
Ambient temp was 36-38C (98-100F). It was really hot.
I also watched the oil pressure gauge during the 110km drive home. With oil temp at 92C (197F) and cruising at 2700 rpm in 6th, oil pressure was around 4.0 bar (58 psi) with the 5w30 oil.
The Following User Says Thank You to HRTROB For This Useful Post:
Tye300 (05-25-2014)
Stock clutch+flywheel+pressure plate+ ACT lightweight flywheel & pressure plate PineappleFriedRice Transmission and Driveline 0 11-08-2013 05:54 PM
Mid range really lacking goli5oda Electronics | Audio | NAV | Infotainment 4 08-19-2013 11:27 AM
Range on a tank of Gas! crank Southern California 28 02-10-2013 05:04 PM
Cruising Range? skoodge Scion FR-S / Toyota 86 GT86 General Forum 4 05-25-2012 03:31 AM
UK Price range £25-£32k!? ZeeSpeed Scion FR-S / Toyota 86 GT86 General Forum 56 11-27-2011 03:11 PM
