Old 05-21-2014, 03:41 AM   #1121
glamcem
glamcem's Avatar
Drives: 2022 BRZ Limited
Originally Posted by sw20kosh View Post
It's simple. Regardless of what comes in a kit you do not want positive pressure going into either the pcv system (it can leak) or the crank case (via the crank breather hose). If you have catch cans installed into these 2 breather systems, you don't want positive pressure going into the cans either. Put check valves in hoses to keep the positive pressure contained to the intake manifold/ic piping. They are cheap.
So if I understand correctly, I will need to add two check valves:
first one on the hose that goes between PCV catch can outlet and intake manifold and the second one on the hose between the breather catch can outlet and air intake inlet, correct?
also, I know the flow direction ( assuming they both need to be added after the outlet ) but how can I tell the flow direction on the check valves? can you recommend a good quality 1/2 " check valve? I believe there are some metal ones like the one I posted..
Thanks again
glamcem is offline   Reply With Quote
Old 05-21-2014, 04:08 AM   #1122
sw20kosh
Drives: 2013 Black FR-S
Thanks again
Valve will have an arrow on it. Many people on here use these:
http://www.usplastic.com/mobile/item...6844&catid=489
Old 05-21-2014, 04:12 AM   #1123
glamcem
glamcem's Avatar
Did I understand where I need to put the valves correctly?
Also Can I simply use the 3/8" valves with 1/2'' hose?
Old 05-21-2014, 05:34 AM   #1124
CSG Mike
CSG Mike's Avatar
Do you think it becomes necessary after a catch can install? and why 8psi of boost? tuned KW kit typically makes 10-11 psi of boost IIRC
Can anyone from @KraftWerks chime in and explain ?
Yes, it is necessary for YOU. For most people, it's not necessary, but definitely good to have.
Under cornering, you will get oil that pools on the driver side of the engine, and pushed out the breather, into your intake tract.
If you have time, take off your intercooler or intake piping, and see if there is a layer of oil. I'll bet there is.
Old 05-21-2014, 08:20 AM   #1125
TmP
TmP's Avatar
Drives: A bunch of 'em...
Originally Posted by Taino-BRZ View Post
I ordered mine today but they haven't send me a tracking yet.
Sent from my SGH-M919 using Tapatalk
WOOOOOT!
Checked the tracking again this morning, now it's Friday this week.
Winning!
TmP is offline   Reply With Quote
Old 05-21-2014, 08:38 AM   #1126
TmP
TmP's Avatar
Do auto parts stores like O'Reilies (spelling?) / Autozone / Advanced sell these?
If not, who does?
Old 05-21-2014, 11:42 AM   #1127
sw20kosh
If not, who does?
I couldn't find any. I ordered from that site. bought a bag of 5 of them.
Old 05-21-2014, 11:43 AM   #1128
TmP
TmP's Avatar
Not gonna get there in time. Damn.
Old 05-21-2014, 11:53 AM   #1129
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
Originally Posted by Freeman View Post
I suppose this doesn't effect vented catch cans?
Correct. Vented cans generally aren't connected to the intake manifold, so they don't need to worry about seeing boost.
Old 05-21-2014, 11:55 AM   #1130
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Thanks again
You only need one check valve. Place the check valve between the intake manifold and your catch can. Remember that hose actually changes in size as it transitions from the intake manifold (larger) to the hose barb (smaller) on the block.
Old 05-21-2014, 11:55 AM   #1131
Freeman
Freeman's Avatar
Drives: 2013 Ultramarine FR-S
That's what I thought, just wanted to double check. Thanks
Freeman is offline   Reply With Quote
Old 05-21-2014, 12:53 PM   #1132
gmsii
gmsii's Avatar
the KW thread has turned into a treatise on check valves..
1) you don't need a check valve if you are venting the block(or valve cover) to atmosphere/catch can. the PCV check valve is only there because the pcv line connects into the intake manifold for emissions compliance reasons (no venting to atmosphere). if the vent line connects to somewhere it wont see positive pressure on the outlet side(ie catch can or atmosphere), then you dont need a check valve.
4) the factory PCV might leak a tiny bit of air if the pressure delta on the inlet and outlet side of the line is over 10-15psi...but i won't cause any appreciable drop in system boost or performance what we have seen on the dyno.
gmsii is offline   Reply With Quote
Old 05-21-2014, 01:14 PM   #1133
glamcem
glamcem's Avatar
IIRC I have used 11/32" between catch can and valve, and 1/2 " between catch can and intake manifold so I am not sure about the size of the check valve that needs to be used on the 1/2" hose..
Thanks again
Old 05-21-2014, 01:16 PM   #1134
glamcem
glamcem's Avatar
Are you referring to the catch can or check valve?
for the record I have dual catch can on both PCV and breather tube
Thanks in advance
Kraftwerks Rotrex Supercharger Discussion nelsmar Forced Induction 697 01-18-2022 12:06 PM
All SUPERCHARGER kits compilation thread subatoy Forced Induction 76 03-10-2016 12:38 PM
Kraftwerks Supercharger?? umpadupa Forced Induction 1 08-05-2013 05:27 PM
