Old 05-20-2014, 01:30 PM   #351
chrisl
Drives: 2006 Cayman S, 2007 Outback 2.5i
Originally Posted by sato View Post
To add to #1:
I'm not sure if this applies to this car, but my current vehicle does not add fuel while coasting until lower than 1500rpm. Thereby, only pumping air and saving fuel, which is also perfect if you are.going downhill for a long while.
In my Outback, the cutoff is 2krpm, but aside from that, it's the same. I would assume the FR-S/BRZ would be similar.
chrisl is offline   Reply With Quote
The Following User Says Thank You to chrisl For This Useful Post:
sato (05-20-2014)
Old 05-20-2014, 05:26 PM   #352
daiheadjai
daiheadjai's Avatar
Drives: 2003 S2000, 2008 Fit
Originally Posted by DriftFreak View Post
I've heard it is recommended to leave the car in gear until the last possible minute. So should I just slow down to maybe 20mph and then clutch in and keep it clutched in until full stop?
I leave it in gear until I'm at about 10km/h (so under 10mph).
It doesn't make much of a difference though, because at that speed, your injectors have to kick in anyway (I think the revs would be just below 1k rpm)
daiheadjai is offline   Reply With Quote
Old 05-20-2014, 06:22 PM   #353
SirBrass
Trust me, I'm the Doctor
SirBrass's Avatar
Originally Posted by Simon99 View Post
I wanna learn to hell toe that bitch. Am i in the good thread ?
Can you rev match downshift already? If so, heel-toe is just doing that but while braking so it's easier to learn. If you haven't learned basic rev-matched downshifting, then get that down pat first.
^GT5 Replay Photo Mode^
Old 05-20-2014, 06:38 PM   #354
Simon99
Simon99's Avatar
Drives: 2013 BRZ Limited WRB
Ill start with that ! Basically bleeping the throttle before depressing the clutch ?
Originally Posted by VesperLynn
This car has allowed car enthusiasts to come from all different walks of life, car cultures, and brands. Just as a panda is black, white, and Asian; the 86 is Toyota, Subaru, and downright fucking sexy.
Simon99 is offline   Reply With Quote
Old 05-20-2014, 06:41 PM   #355
sato
sato's Avatar
Drives: Dodge Patitas
Yes. Blip it so engagement of the lower gear is as close as possible to the rev range when the clutch is released.
Sent from my C6906 using Tapatalk
sato is offline   Reply With Quote
The Following User Says Thank You to sato For This Useful Post:
SirBrass (05-20-2014)
Old 05-20-2014, 07:08 PM   #356
SirBrass
SirBrass's Avatar
No. You blip throttle while the clutch is disengaged (clutch pedal to the floor), then release clutch. You clutch pedal in, shift and blip (simultaneous), release clutch and balance with throttle.
The Following User Says Thank You to SirBrass For This Useful Post:
Simon99 (05-20-2014)
Old 05-20-2014, 08:31 PM   #357
DriftFreak
Drives: FR-S/CR-Z
Are you guys able to completely clutch out when in reverse? Rarely will I get the speed to let off the clutch pedal in reverse. Always have to clutch in about halfway.
DriftFreak is offline   Reply With Quote
Old 05-20-2014, 08:36 PM   #358
AznKirby
Are you 20/20?
AznKirby's Avatar
Drives: Hopes and dreams
You rarely go at full speeds when you reverse anyway so I don't think it matters. But I tend to give it a push, then control my speed with braking while in neutral
2014 FR-S Monogram
2005 Acura RSX Type-S
IG: @MonKehC
Old 05-20-2014, 08:41 PM   #359
dbrandt01
Drives: none
AznKirby, I go to engagement point then push it in and cost out unless I need more of a push out. Slight inclines are the only one where I somewhat hold it halfway
dbrandt01 is offline   Reply With Quote
Old 05-20-2014, 11:00 PM   #360
AznKirby
Are you 20/20?
AznKirby's Avatar
I'm confused. Isn't that the same as what I said?
Also: "coast". lol grammar Nazi over here.
2014 FR-S Monogram
IG: @MonKehC
Old 05-20-2014, 11:17 PM   #361
SirBrass
SirBrass's Avatar
I've never fully clutched out in reverse. Never. Not even with my dad's old '85 Nissan Kingcab.
You simply can't. Not unless you're looking to go way faster than you ought while backing out (or up). If you do but try and keep speed regulated with throttle only, you'll stall almost immediately.
On phone I am. Therefore, if mistakes I make, Frank Oz blame you should.
Old 05-20-2014, 11:30 PM   #362
dbrandt01
Drives: none
I mean to say I agree, but well between homework and typing a reply I didn't. I didn't even notice the errors I made. So I apologize.
Old 05-21-2014, 02:22 PM   #363
codesplice
Elite Recognized Geek
codesplice's Avatar
Drives: 2014 DGM BRZ Limited
I've been driving a manual since before I got my license (circa 2001, IIRC), and regularly practicing heel-toe downshifting in daily driving since about 2006. Even so, I recently participated in the two-day Porsche Sport Driving School and picked up a few pointers from the instructors that have certainly helped improve my driving and shifting in particular. So I figured I'd pop in and see if I can offer any help.
Thanks for the replies. When you brake how do you know when to clutch in or do you clutch in the moment you hit the brake pedal? I try to clutch in at the last possible moment, which gets harder in higher gears as I don't know how low of a speed they can go without damaging the transmission.
For the longest time, I had been clutching-in too early. I'd downshift and coast when approaching a stop, but generally throw both feet down (brake and clutch) at about the same time when I got ready to actually stop. That's something the PSDS folks slapped me around for. At least for heavy, track-style braking, they said it was much better to brake hard and then clutch-in as you start to taper off the brake, or when the engine speed drops to ~1500rpm, whichever comes first. Now, I generally don't clutch-in until I'm almost completely stopped.
Of course, don't ask me the reason for why they made that recommendation... they had one, but I can't for the life of me remember what it was.
The best advice I can give on learning heel-toe is to practice while sitting still. Go through all the motions with the car stopped and idling. Getting the timing down is critical, and it's a lot easier to practice that when you don't also have to worry about stopping or dodging ditches.
Firstly, you need to figure out how much pressure it takes to correctly (and repeatedly) blip the throttle up to ~3000rpm without fumbling with the clutch or shifting or steering or any of that other driving stuff. With the car idling in neutral and your foot on the brake pedal, practice stretching the outside of your foot over to the accelerator and quickly blipping it. You don't need to be smooth, and you don't need to sustain it, just concentrate on how much movement is needed to consistently jump the tach needle to ~3000rpm. Yes, you'll look like a tool sitting alone in a parking lot revving your engine, but you'll feel like The Stig once you get this sorted.
Once you've got the accelerator movement down, it's time to work on timing - the most critical part. There are essentially three steps, or rather groups of actions:
1) Braking and clutch-in.
2) Throttle blip and gear change.
3) Clutch-out.
The clutch pedal part is pretty easy, so you don't necessarily have to practice that while sitting still. I'd focus on getting your right foot and right hand to work together. Start out stationary, with the clutch depressed and the gearshift in third. Apply pressure to the brake. Practice moving the gearshift smoothly from third to second, blipping the throttle as the lever moves through neutral territory. Do it quickly, but don't rush it - concentrate on being fluid. Speed will come with time.
Once you've got the hang of those movements you can start working on it while moving, bringing the clutch work into the picture. Once more, the process is (1) brake firmly, and push the clutch in; (2) downshift and blip the throttle simultaneously; (3) smoothly (but quickly!) let the clutch out. The goal with that last step should be to release the clutch before the revs fall back down. And keep in mind that your rev-matching doesn't necessarily have to be perfect - really any RPM above idle/coast will be beneficial for smooth downshifting.
One last note on the subject of heel-toe: it's not mandatory. Hell, it's not even necessary 98% of the time. Even the Porsche instructors (all of whom were current or retired professional racers) said so. It's a nice little bonus when you can nail it just right, but the far more important part of the puzzle is the braking. If you fumble the downshift, worst case there's jarring feeling and a slight momentary loss of traction. If you screw up the braking, you might end up in a ditch or another car's rear end. Always make sure that braking is your number one priority.
I've tried my best to put my process into words; I hope it can be helpful to some of you. Feel free to ping me if you have further questions or need better words.
This post is a work of fiction. Names, characters, places, and incidents either are the product of the poster's imagination or are used fictitiously, and any resemblance to actual persons, living or dead, business establishments, events, or locales is entirely coincidental.
G+
codesplice is offline   Reply With Quote
The Following 5 Users Say Thank You to codesplice For This Useful Post:
bpmorgan7 (06-02-2014), extrashaky (05-22-2014), Simon99 (05-21-2014), SirBrass (05-21-2014), Want.FR-S (05-21-2014)
Old 05-21-2014, 08:36 PM   #364
daiheadjai
daiheadjai's Avatar
Sorry - I missed the last part.
AVOID holding the clutch in for extended periods of time.
Press the clutch in, put it into (or out of gear), and release the clutch ASAP.
IIRC this is to keep the release bearing and springs etc. good for as long as possible.
I clutch in, pop it into neutral, and clutch out once I drop down to about 10 km/h
The Following User Says Thank You to daiheadjai For This Useful Post:
codesplice (05-21-2014)
Best place to learn how to drive my car Pneub Southern California 1 06-07-2013 04:54 PM
what did you learn to drive on? 7thgear Off-Topic Lounge [WARNING: NO POLITICS] 31 08-10-2012 11:39 PM
Where to learn how to drive manual.... Saibot CANADA 12 03-13-2012 07:28 PM
Who needs to learn how to drive... RRnold Other Vehicles & General Automotive Discussions 14 08-27-2011 01:15 AM
Learn to Drive MtnDrvr86 Other Vehicles & General Automotive Discussions 102 03-14-2010 09:46 AM
