Old 05-17-2014, 12:44 AM   #337
extrashaky
Drives: 2014 BRZ Limited
Originally Posted by DriftFreak View Post
I hear a lot of ppl say that on the streets no one really uses heel toe and it is really more for racing. So braking and downshifting at the same time is uncommon for a lot of people?
Yeah, it's pretty uncommon because it's not all that easy to do. If you can do it, you can downshift in more situations while saving wear on your clutch. If you can't do it--which is fine--you just use your brakes instead of engine braking.
I bought one of the Cusco heel/toe pedals for my car to make it easier to hit the accelerator with the side of my foot. My heel/toe technique still sucks though. One of these days I'm going to find a deserted industrial park and practice for a couple of hours to see if I can't improve a bit.
The Following User Says Thank You to extrashaky For This Useful Post:
SirBrass (05-17-2014)
Old 05-17-2014, 01:08 AM   #338
SirBrass
Trust me, I'm the Doctor
SirBrass's Avatar
Just practice heel toe like you do rev matching when you need to brake & downshift at the same time (instead of braking earlier then rev match downshift) and you'll find yourself doing it rather easily soon enough. Just make sure you start with using good shoes which allow good pedal feel. That'll help you learn.
On phone I am. Therefore, if mistakes I make, Frank Oz blame you should.
^GT5 Replay Photo Mode^
Old 05-17-2014, 01:16 AM   #339
daiheadjai
daiheadjai's Avatar
Drives: 2003 S2000, 2008 Fit
I was like that too.
One thing to point out: heel-toe is actually easiest when you are braking HARD.
One mistake I made (initially) was trying to heel-toe while gently braking to decelerate - that is much harder to modulate (at least initially).
Just make sure you have lots of room to recover/stop safely if it goes sour (empty big-box parking lots are fantastic - watchout for curbs and shopping carts)
One downside: Having since gotten the hang of it, I now find myself heel-toeing all my right turns. My gas consumption has suffered significantly.
daiheadjai is offline   Reply With Quote
The Following 3 Users Say Thank You to daiheadjai For This Useful Post:
extrashaky (05-17-2014), SirBrass (05-17-2014), strat61caster (05-19-2014)
Old 05-17-2014, 01:31 AM   #340
AznKirby
Are you 20/20?
AznKirby's Avatar
Drives: Hopes and dreams
I find that heel-toe'ing in the streets is easier when I use the side of foot & toe method.
Unless I'm braking hard, I always seem to over rev when I use my heel.
It's also probably because I have dress shoes on for work and they have a different heel.
My 0.02
2014 FR-S Monogram
2005 Acura RSX Type-S
IG: @MonKehC
The Following User Says Thank You to AznKirby For This Useful Post:
Old 05-17-2014, 02:32 AM   #341
Manic
Is not fast.
Manic's Avatar
Drives: 2014 Whiteout M/T
Like others have said, it's a lot easier when braking hard so it's not as common on the street.
I've however begun using it for hill starts. Instead of using the hand brake method or riding the clutch to hold position on a hill, I just blip the throttle and "catch" revs as I let the clutch slip a little bit. That way I don't have to fiddle around with the hand brake as much. On steeper hills, I'll still use the hand brake, but for most gentle inclines, it works perfectly.
Manic is offline   Reply With Quote
Old 05-18-2014, 02:00 AM   #342
DriftFreak
Drives: FR-S/CR-Z
Thanks for the replies. When you brake how do you know when to clutch in or do you clutch in the moment you hit the brake pedal? I try to clutch in at the last possible moment, which gets harder in higher gears as I don't know how low of a speed they can go without damaging the transmission.
DriftFreak is offline   Reply With Quote
Old 05-18-2014, 02:18 AM   #343
nyfries
Drives: 14 FRS Whiteout
true if you use stock pedal. added the cusco pedal now i can heel toe under any braking condition. hence i been heel toeing a lot on the street.
as for when to clutch in when braking. i usually don't unless it a emergency braking situation where the car must be stop asap than i press both the brake and the clutch.
let say i see a red light up ahead. what i do is brake the slow down, when i am almost to the red light i clutch in a put the car in neutral. you shouldn't need to clutch in all the way to the stop light
i'm only 5 months into driving manual though so would appreciate input too
nyfries is offline   Reply With Quote
Old 05-18-2014, 01:17 PM   #344
dodah
Drives: na
when coming to a stop u can coast in neutral at any point, i wouldnt recomend leaving it in gear the whole way n then last minute popping the clutch in neutral.am pretty sure when you get to or below 1 rpm ur engine will start to bog n u might risk stalling out. I was taught, only downshift to speed up, use ur breaks to slow down since breaks cost less than tranny..so in the above example, if traffic piks up, just rev match from neutral into desired gear.One problem I am having with this car is having trouble hearing the engine since at low rpm its rather quite, hard to gauge apppropriate gears but i guess you can look at ur speed at get an idea but i would rather listen than see.iono , just my 2 cents.
dodah is offline   Reply With Quote
Old 05-18-2014, 01:20 PM   #345
dodah
Drives: na
Hard or sudden breaking are usually instances wher you would clutch +break or in parking lot as well when ur at very low speeds or rpms. Pretty much anywher wher u think engine might stall on u cause of low rpms.
Old 05-19-2014, 06:25 PM   #346
daiheadjai
daiheadjai's Avatar
Actually, coasting in neutral has a few disadvantages:
1) It wastes gas, because your fuel injectors must now feed fuel to keep the engine running (idle) - if you leave it in gear and coast to a stop, your wheels will turn the engine (keeping it running, and allowing the injectors to stay off).
2) It can be dangerous - not being in gear leaves you vulnerable in case someone behind you doesn't stop/slow down - at least you are in gear so you may have enough power to move out of the way.
Side note: Leaving it in gear to decelerate doesn't harm your car - I think what people advocate against is constantly downshifting in order to engine brake to a stop. If I coast to a stop in 3rd (and leave it in 3rd), there is no harm to the transmission or clutch.
The Following 2 Users Say Thank You to daiheadjai For This Useful Post:
AznKirby (05-20-2014), chas3wba0 (05-20-2014)
Old 05-19-2014, 06:33 PM   #347
sato
sato's Avatar
Drives: Dodge Patitas
To add to #1:
I'm not sure if this applies to this car, but my current vehicle does not add fuel while coasting until lower than 1500rpm. Thereby, only pumping air and saving fuel, which is also perfect if you are.going downhill for a long while.
Sent from my C6906 using Tapatalk
sato is offline   Reply With Quote
Old 05-19-2014, 09:21 PM   #348
DriftFreak
Drives: FR-S/CR-Z
I've heard it is recommended to leave the car in gear until the last possible minute. So should I just slow down to maybe 20mph and then clutch in and keep it clutched in until full stop?
Old 05-20-2014, 02:26 AM   #349
AznKirby
Are you 20/20?
AznKirby's Avatar
I know some of you are just starting out and have a lot of questions - which is fine - but I do believe you're putting too much thought into it.
2014 FR-S Monogram
IG: @MonKehC
Old 05-20-2014, 02:32 AM   #350
Simon99
Simon99's Avatar
Drives: 2013 BRZ Limited WRB
I wanna learn to hell toe that bitch. Am i in the good thread ?
Originally Posted by VesperLynn
This car has allowed car enthusiasts to come from all different walks of life, car cultures, and brands. Just as a panda is black, white, and Asian; the 86 is Toyota, Subaru, and downright fucking sexy.
Simon99 is offline   Reply With Quote
Best place to learn how to drive my car Pneub Southern California 1 06-07-2013 04:54 PM
what did you learn to drive on? 7thgear Off-Topic Lounge [WARNING: NO POLITICS] 31 08-10-2012 11:39 PM
Where to learn how to drive manual.... Saibot CANADA 12 03-13-2012 07:28 PM
Who needs to learn how to drive... RRnold Other Vehicles & General Automotive Discussions 14 08-27-2011 01:15 AM
Learn to Drive MtnDrvr86 Other Vehicles & General Automotive Discussions 102 03-14-2010 09:46 AM
