#4579 | |
Just the tip
Current: 2013 Lightning Red Subaru BRZ Limited
Past (sold): Click here to see previous cars and bikes ![]() |
#4580 |
Grip>Slip
do you still have the plastic innovate pipe? could you do some tests/datalogs of IAT's at the MAF to see how much the nameless pipe helps?
#4581 |
Drives: Raven FR-S
I have the nameless pipe ceramic coated as well and I can honestly say it gets hot as hell.
Raven FR-S mods: Unichip, Ground Control street coilovers with camber plates and strut tower brace, SPC Lca's, Drag DR-38 wheels with Dunlop Direzza DZ101s, Perrin CAI and silicone inlet tube, Perrin 3" resonated catback, Perrin high flow catted front pipe, Rev Works UEL header.
#4582 |
Just the tip
I don't really have time to do this but the guy above just said it gets hot. Perhaps he can do some tests. I have the JDL UEL and not the Nameless headers so I'm thinking mine will be a little cooler since the header isn't up there.
#4583 |
Grip>Slip
#4584 |
Drives:
JW- Does the intercooler upgrade kit come with the stage 2 tune or do you have to purchase that separately?
#4585 | |
Drives: Asphalt 2013 FR-S
So much so that people on the freeway stop trying to provoke me when they hear it pick up. Below 3K the SC just makes a funny whirly noise, like if the car stereo had a bad ground (not that I ever bother to turn on the stereo).I almost went with the Forester oil cooler as well, but decided to go with a front mounted cooler instead because it just seemed easier to install for a newb like me. With standard rubber hosing it doesn't look out of place in the engine bay. A cop I met was actually surprised when I told him that it wasn't stock. He said he would have expected a sports car like ours to come with one from factory. He was also surprised to see that our gauge cluster doesn't have oil pressure and oil temp gauges. I don't see the Nameless intake pipe on their website, so I guess it's special order only? I imagine the powder coat should help with airflow as well as combating heat? I'm curious, when you got your tune form Bill did it come with 4 maps or 2? Mine came with 4, 2 maps for 91 octane and 2 maps for 93 octane.
#4586 |
Drives: 86 GT
Dumb question, but im from Australia, if the kit comes with a 93 octane tune and I use a 98 octane tune, this wont cause problems will it?
#4587 |
Drives: Slowly
#4588 |
That Guy
Drives: 2013 asphalt FRS MT
#4589 | |
Drives: JDL Turbo FRS, 335SC BRZ (ret)
![]() Frankly I've not been impressed with anything that uses the stock snorkel. Yes, it is a well designed piece, but it is sized for 200 crank hp. It is just unfortunate that the opening in the front bulkhead is so small and narrow, makes it nearly impossible to make a viable aftermarket piece that both flows better and can be mass produced. I think with some fiberglass works or CF you can make a real nice one. Those nameless pipes look really nice, but I would definitely ceramic coat it. The plastic the stock kit uses retains heat much less than a big piece of stainless, ceramic will at least give it a fighting chance. Our MX5 intakes are exclusively ceramic coated for this reason. |
#4590 | |
Drives: 2013 SWP BRZ
![]() I'm still curious to see your setup though so if you have any more info on it please pm me or shoot me an email. Just want to see wtf this thing looks like
#4591 | |
Drives: beater
#4592 |
Twin Screw You
Drives: 2013 Supercharged Whiteout FR-S
For those that have checked the oil level with the use of a syringe, where did you get the syringe from?
| Innovative ideas to increase interior storage capacity? | swift996 | Cosmetic Modification (Interior/Exterior/Lighting) | 0 | 01-30-2013 11:45 PM |
| AVO vs Innovative | diss7 | Forced Induction | 32 | 01-21-2013 07:15 PM |
| Not another need to drive topic | Sargy | Mid-Atlantic | 5 | 11-27-2012 01:18 PM |
| Technical topic sub-forums | OrbitalEllipses | Site Announcements / Questions / Issues | 1 | 07-18-2012 12:38 AM |
| Can you close the topic please? | Standardsuspension | Brakes, Suspension, Chassis | 14 | 06-26-2012 06:14 PM |
