| DIY (Do-It-Yourself) Guides For all DIYs. |
#15 |
Drives: Scion FR-S 10 Series
Nice! I already have a TapTurn and love it. Might have to upgrade to the new model with strobe.
#16 | |
Drives: 2013 DGM BRZ Ltd
#17 |
Installed mine just a while ago and here are some additional pictures that may help with install.
In the first picture you see the flasher, white clip and the metal brace. 2 10mm bolts (red circles) removes the cross brace and makes it way easier to get to the flasher. Flasher is on the left side of the column. In the 2nd picture you want to insert a long thin flat bladed screwdriver on the right side of the white clip (red line) between the clip and the dash brace. In the drawing in the 4th photo (I'm no artist) you will see that the clip has a horseshoe type U-shape to it that goes into the dash brace hole and that is in essence sort of a spring loaded type attachment. You want to try and push the horseshoe part towards the left as you twist the screwdriver counter clockwise to pop the clip out of the hole. 3rd picture is the flasher unit itself and how it is oriented under the dash. To remove the white clip from the original flasher you have to lift the beige tab from the firewall side of the flasher to slide the clip out. Now, the bottom picture is of the main wiring harness crossing under the steering mechanism and where the red line is is where I found my harness pressed hard against the bottom edge of the steering unit. The factory has installed a black sleeve over the blue wires because this harness is going to rub/vibrate (at least on my car) against the steering unit. I rolled up a small piece of bubble wrap and shoved it between the wires and the steering unit. While you're in there installing your Tap-Turn, check your harness. This, a few years down the road, could be a problem that will arise. I've seen a power steering hose eat its way into a wiring harness under the hood and that was a rubber hose, so I can't imagine that rubbing/vibrating against a metal edge won't do the same thing over time. Last edited by White64Goat; 01-12-2014 at 04:08 PM. |
#18 |
Drives: none yet
i sent you PM!
WANT!!!! so if i just want 2 blinks (called the tapturn?), then i turn "off" on the strobe? should the ING/always switch be where? "Always" im assuming? i dont want 3 blinks, just 2. thanks. |
#19 |
Drives: 06 Subaru Legacy
There is no more switch on strobepack, this one KAR had was an early prototype.
Everything is controlled in soft settings now.
#20 |
Drives: 2013 BRZ Limited
#21 |
Drives: brz
sry but what does this flasher do that the stock one doesn't?
#22 | |
Drives: Toyota Skyline Type-R
strobe function for hazards/signals elminates hyperblinking with LED signals plus a couple other functions im missing. Read their website for all the features
#23 |
Drives: CBS brz limited
So I replaced my flasher when I got my toms tail lights. If I bought one of these will I have any issues with my toms??
#24 | |
Scott
| TapTurn flasher - convenience signaling for LEDs or stock bulbs! | scottmcphee | Exterior Parts - Lighting | 120 | 09-22-2017 01:45 PM |
| TapTurn - best signal flasher upgrade for FR-S BRZ | scottmcphee | Audio/Visual, Electronics, Infotainment, NAV | 160 | 03-30-2015 11:15 PM |
| My New LED+TAPTURN=COOL | KAR | Cosmetic Modification (Interior/Exterior/Lighting) | 0 | 10-09-2013 02:26 AM |
| FS: gently tested TapTurn flasher | scottmcphee | Exterior Parts (Aero, Lighting, Etc.) | 7 | 09-02-2013 11:14 PM |
| Blue/Red Strobe Lights? | 636 | Cosmetic Modification (Interior/Exterior/Lighting) | 15 | 11-04-2012 10:10 PM |
