go_a_way1
Old 05-10-2014, 08:19 PM   #1191
Sideways&Smiling
Drives: AP2 S2000, S14 240sx
Sweet baby jesus... http://www.ft86club.com/forums/showt...09#post1728609
Sideways&Smiling is offline   Reply With Quote
Old 05-10-2014, 09:29 PM   #1192
vh_supra26
Site Moderator
Drives: Supra
I like doing these photo comparisons.
vh_supra26 is offline   Reply With Quote
The Following 4 Users Say Thank You to vh_supra26 For This Useful Post:
juliog (05-11-2014), Levi (05-11-2014), sprintertrueno86 (05-10-2014), xia (05-13-2014)
Old 05-10-2014, 09:38 PM   #1193
gramicci101
Off Topic
I was next to one on the road, and my first thought was that the S2K is a much smaller car. Now that I'm going back to look at the actual dimensions, it's really not. The S2K is about 4.5 inches shorter front to back, with a 7 inch shorter wheelbase, but it's about the same height and width. The front track is 2 inches narrower and the rear track is 1 inch narrower. So it's a little smaller, but not nearly as much as my initial impression made me think.
It's also about 800 lbs heavier, according to Motortrend. Interesting.
Old 05-10-2014, 10:28 PM   #1194
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Uhmm unless the frs/brz are really 2050lbs or so... No.
The brz limited is just under 100lbs lighter than a ap2, about the same weight as an ap1.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 05-10-2014, 10:54 PM   #1195
gramicci101
Off Topic
Motortrend was saying 2750 for the FR-S and 2830 for a 2005 S2K.
Edit- ok, I'm a dumbass who can't math. One too many zeros there.
Old 05-11-2014, 12:38 AM   #1196
fatoni
You'll find the CdA of the Veyron is smaller
Cd is only half of the equation.
the only point im making is that you cant just look at a car and figure out the aerodynamics. the xb is a more aerodynamic shape than the veyron. whether or not the xb is bigger shouldnt change that point.
Old 05-11-2014, 04:59 AM   #1197
CSG Mike
CSG Mike's Avatar
It absolutely does.
Using just the Cd to say a car is aerodynamic, is like judging an engine by it's torque output.
Old 05-11-2014, 06:35 AM   #1198
CSG David
CSG David's Avatar
Uh...Cd is "coefficient of drag", which means it's just a number or factor you use to the overall equation. You still need to figure out the area to find out the force of drag applied to the vehicle itself...
Old 05-11-2014, 02:14 PM   #1199
fatoni
It absolutely does.
my only point is that you cant eyeball aerodymanics. the cda for the veryon is larger before it does its fancy superspeed thing by the way. then, when it does that thing the cda is near identical to the xb.
also, would the size of a car alter the cd?
Old 05-11-2014, 03:06 PM   #1200
Boxer486
Drives: small
Frontal surface (rough brick estimate) to drag area:
FRS - 24.56 sq ft x 0.28 = 6.88 sq ft
Veyron - 25.19 sq ft x 0.35 = 8.82 sq ft
xB - 30.95 sq ft x 0.31 = 9.60 sq ft
S2000 - 24.21 sq ft x 0.33 = 7.99 sq ft
Lol, actually mixed up the xB and xA in my head. Forgot about the toaster...
Boxer486 is offline   Reply With Quote
Old 05-11-2014, 05:01 PM   #1201
CSG Mike
CSG Mike's Avatar
I absolutely can. It's no different from any other practiced skill; you just need to know what you're looking for.
CdA doesn't change with speed; Cd and A are both constants, as long as nothing is changing (active/passive aero).
Old 05-11-2014, 05:16 PM   #1202
fatoni
i would say your assumption about the veyron and xb thing was kind of off but im kinda over that topic. we can have different viewpoints but i still appreciate all your knowledge. i know cd and a are fixed. my question was probably less than clear. if you changed the scale of a car would it change the cd? like if you had a 4/5 scale frs would it have the same cd as our cars?
Old 05-11-2014, 05:22 PM   #1203
CSG Mike
CSG Mike's Avatar
Absolutely. Wind tunnel testing is typically done with scale models.
fatoni (05-11-2014)
Old 05-11-2014, 06:23 PM   #1204
Boxer486
Drives: small
Yeah Cd has nothing to do with size. Behold one of the best Cd found in the animal kingdom 0.06.
http://www.the-scientist.com/?articl...d-the-boxfish/
The Following User Says Thank You to Boxer486 For This Useful Post:
CSG Mike (05-11-2014)
FR-S vs S2000 vang FR-S / BRZ vs.... 436 09-19-2012 05:52 PM
E36 M3 vs FR-S vs S2000 (for me) RearDrive FR-S / BRZ vs.... 48 07-02-2012 11:46 PM
S2000 or MX-5 balance Other Vehicles & General Automotive Discussions 10 11-01-2011 03:01 AM
S2000 from hell CyberFormula Other Vehicles & General Automotive Discussions 13 07-09-2010 10:05 PM
