#99 |
Erected Member
Drives: frs
Idk how accurate this is but. I believe that wot at anything below 2krpm puts alot of strain on your motor and shouldn't be recommended.
I only do pulls from a minimum on 2.5krpm Edit: wot @1.5k rpm in 1st gear is perfectly fine �� |
| The Following User Says Thank You to shif7i7down For This Useful Post: | Blu-by-U (04-05-2014) |
#100 |
Drives: UK GT86
I agree. It's not really normal driving conditions so why do it. You'd never be below 2.5k when you actually want to drive fast.
.: Stealth 86 :.
| The Following User Says Thank You to Kodename47 For This Useful Post: | Blu-by-U (04-05-2014) |
#101 |
Some Dumb Guy
Drives: wanting an Acabian
Update, don't remember which post it was, but I read that VD only reads above 90 percent something throttle position. Once I stripped my data file down to that parameter, I ended up with a 160 whp / 150 ftlbs. Where as I understand that this about correct. I'm still skeptical. These finds are still from original data logs which I have not yet had an opportunity to try any of the suggested pulls from earlier posts. Still learning and trying to catch up.
She said it was her or the car. Longest
she had ever seen. |
#102 | |
Drives: FR-S Whiteout
Here's one for bones stock vs, OFT stg1 tune on a bone stock car.
#103 | |
Some Dumb Guy
Are you using a complete data log or am I correct that I have to save a log with just the pull?
#104 | |
yes, I skate... I cheap skate. lol |
#105 |
Drives: 86
I am not able to select a car. Any idae what is the problem I have?
VOLK LE37 17X7.5, SWIFT Springs, Bilstein B8, HKS intake duct, Cosworth Air Filter, HKS headers, PLM Over Pipe, EVS Down Pipe & Exhaust, FD 4.55, GFB pulleys, Axle-Exchange Drive Shaft, Mishimoto oil cooler, Cusco F&R strut bar, TRD door stabilizer, Innovate SC, Delicious Tuned
#106 |
Have you created a new profile? You need to create a profile, then you can pick a car.
Every time you go to use the program you have to make sure you selected the right profile too.
#107 |
Drives: 86
I created a profile and this the error message I am getting
************ Exception Text ************** System.Exception: E209: Object reference not set to an instance of an object. at VirtualDyno.RunControl.cRunControl.Error(String ErrorNumber, Exception ex) at VirtualDyno.RunControl.cRunControl.TreeView_NodeMo useDoubleClick(Object sender, TreeNodeMouseClickEventArgs e) at System.Windows.Forms.TreeNodeMouseClickEventHandle r.Invoke(Object sender, TreeNodeMouseClickEventArgs e) at System.Windows.Forms.TreeView.WndProc(Message& m) at System.Windows.Forms.Control.ControlNativeWindow.W ndProc(Message& m) at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
#108 |
Drives: Raven FR-S 6M
If you go under the profile pulldown menu select add a profile and you should see a blank profile pop up. There is Car pulldown menu to select the make and model.
“The World is Flat”
[||•]=(86)=[•||] |
#109 | |
Drives: 86
I dont get that list to select from Sent from my iPhone using Tapatalk
#110 |
Drives: 2013 Raven FR-S
is there a way to change virtual dyno to read below 90% throttle? my throttle tapers off to 89% by redline and thus won't show top end numbers...
edit: just changed the throttle values in my logs to above 90%. problem solved
Perrin (LWCP) - Blox (shift knob) - HID Powerhouse (LED's and HID's) - Eibach (sportlines) - Muteki (lugs) - SPL (LCA's) - Rays Engineering (57dr's) - Dunlop Direzza ZII (tires) - Greddy (Evo3) - Full Race (turbo kit) - Ecutek (tuned)
#111 |
I think you may be missing the app data. I can't remember if there was a way to update but if you are registered and online it should update automatically I think. Worst case is you go into car editor and create your car. I had to do that when I started using it in 2012 because FR-S wasn't in their data.
“The World is Flat”
[||•]=(86)=[•||] |
| The Following User Says Thank You to Apoc For This Useful Post: | 8686 (05-06-2014) |
#112 |
This has already been covered in the thread, but it's not an issue below 90%... the app assumes if the TP drops more than ~5% from the peak value it's no longer at WOT. I've messaged the guy that wrote it about this, but the easy solution is to just increase the TP values to be within 5% of the peak (I normally just set them all to 100).
| Data Logs! Post them here. | feldy | Software Tuning | 2162 | Yesterday 07:09 AM |
| Anyone help interpreting data logs? | cuddefred | Engine, Exhaust, Transmission | 8 | 10-11-2013 07:30 PM |
| Interpreting Ecutek Data Logs? | cuddefred | Software Tuning | 3 | 09-02-2013 01:55 PM |
| VIR - Impressions/Pics/Logs/Video (Track Daze) | swift996 | Tracking / Autocross / HPDE / Drifting | 39 | 08-30-2013 10:21 AM |
| Noise tube delete air/fuel logs? | jm1681 | Engine, Exhaust, Transmission | 13 | 10-17-2012 05:57 PM |
