Old 05-06-2014, 02:14 PM   #71
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
mmmmm updates.....?
Old 05-06-2014, 02:22 PM   #72
Jason@DSG
Jason@DSG's Avatar
Drives: 1997 Eagle Talon TSi AWD
Hey guys!
I wrote this in my sales thread on here but figured this may help clear up some issues as to what each part does.
Source for info -- I worked at SSP for 2 years
High Stall Torque Converter:
Allows you to get a higher RPM launch by holding the brake (it's set to 3,100rpm limit) so in general this is great for a launch but even better on forced induction applications. Higher revs = higher boost
that brings me to the next item;
Transmission Cooler:
The more power and higher launch, the higher the internal temps. This badboy from SSP does an amazing job of keeping the temps down. Having a cooler will definitely extend the life of the transmission also.
Valve Body Stage 1:
This is the main hub for the transmission. All the solenoids and valves are located here so for the Stage 1 upgrade, SSP has modified it to have 1st, 2nd and 3rd gears engage very aggressively. There's no "slip" engagement or smooth engagement, it grabs the next gear right away. Gears 4-6 remain as stock engagement.
This means red-line gear changes get right into the next gear, it's a HUGE difference and is very much like a DCT (twin-clutch) transmission. The gear changes are this hard no matter the RPM, so even cruising you get immediate engagement into the next gear.
Valve Body Stage II:
The stage II adds in the aggressive engagement for all gears (includes 4-6 also). So every gear will be instant engagement. This could be a little rough for daily driving but I'm someone that likes precision and no slop, even daily driving so this would be my choice along with the cooler
I hope this sums it up, if you need any further info please let me know. I'm always here to help in any way I can!
Cheers,
Jason
Jason@DSG is offline   Reply With Quote
Old 05-06-2014, 03:00 PM   #73
kavanagh
Fat on Corn Syrup
Thanks Jason!
Can you clarify a question on the Stage I and II?
Does it do what it does regardless of the 'Sport' mode selection or if you're in manual or auto mode?
Sport mode speeds up the shifts in the stock tranny (right?), so I'm wondering if this valve body is more aggressive in both modes, or only in Sport mode.
Old 05-06-2014, 03:55 PM   #74
Jason@DSG
Jason@DSG's Avatar
Thanks Jason!
It actually doesn't matter what mode. The valvebody will make the shifts hard ALL the time. That's why stage I is great because the first 3 gears are really sharp and the rest are OEM making the daily drive fine. The Stage II is every gear so no matter what, ever gear engagement is very sharp and snappy.
Personally, I love my car to be snappy and have the gears engage immediately without any hesitation so even for daily, Stage II works for me but to each their own!
Cheers,
Jason
Old 05-06-2014, 04:21 PM   #75
FastWhite
Drives: Subaru BRZ Limited M/T
All we need now is to have a meet so we can test and discuss the various setups.
Dreaming I know.
But I haven't been to Montreal in a while.
Good excuse for a trip.
That is where you are located?
FastWhite is offline   Reply With Quote
Old 05-06-2014, 09:49 PM   #76
Jason@DSG
Jason@DSG's Avatar
Dreaming I know.
We actually don't have out shop FRS yet soon though, if anything SSP in MN probably has someone with their AT done up (might be an easier trip for you).
But I have the full SSP lineup on my EvoX and it's very similar to that type of shifting. The valvebody makes it feel much more like a twin clutch DCT type transmission. It's a really amazing upgrade for these cars with an AT IMO
Old 05-06-2014, 11:02 PM   #77
Captain Insano
This stuff is def on my list. Jason, for the stage II valve body do the gear shifts "feel" violent all the time or does it depend what throttle/rpm/gear you are at when the shift occurs?
Captain Insano is offline   Reply With Quote
Old 05-06-2014, 11:44 PM   #78
Jason@DSG
Jason@DSG's Avatar
Under lower loads there much harder than OEM but it's a good kind of thing. Under heavier loads it's even more aggressive so redline shifts. I have a couple going out to customers, I'll see if they can take a vid of the shifting for you guys
Old 05-06-2014, 11:49 PM   #79
kavanagh
Fat on Corn Syrup
SSP A960E Transmission Upgrades
Please please please.
Old 05-07-2014, 12:19 AM   #80
mid_life_crisis
Drives: FR-S 10 #103 AT
Originally Posted by Brianjoy77 View Post
http://www.sspperformance.com/brz-fr...y-upgrade.html
"The A960E Stage 1 street strip valve body is designed for everyday street driving and weekend trips to the drag strip.
Designed to pull heavily thru 1-4th gears at redline."
Sounds awesome just need a price.
Hey guys!
Valve Body Stage 1:
Cheers,
Jason
Is it 1 through 3 or 1 through 4?
1-4 makes the most sense since 5 & 6 are stretched out highway gears (I think they are both overdrive).
“Sex is like Bridge. If you don't have a good partner, you'd better have a good hand.” - Mae West
Papa said, "son there's a lot of evil temptations out there. Best to try 'em all so you know which ones to avoid."
mid_life_crisis is offline   Reply With Quote
Old 05-07-2014, 12:28 AM   #81
mid_life_crisis
@sspkris
Any chance of a valve body .5 that speeds up/ firms up the 1-4 shifts without being neck snapping? When I'm driving on winding roads or maneuvering in light traffic, I frequently wish the car shifted faster in response to the paddles or the shift lever, but don't want it to be dragster harsh.
Old 05-07-2014, 02:16 AM   #82
BRZPDX
Boosted Member
BRZPDX's Avatar
Drives: 2013 SWP BRZ Limited
So do we send the core to you, SSP revalves it and sends it back? how long will the down time be?
Does this decrease the longevity of the tranny? Any adverse effects or other parts we need to reinforce?
Suzuki Swift GTI '89, Subaru Impreza L '96, Lancer OZ '03, Subaru Impreza WRX '06, Honda CBR600RR Graffiti, Volvo c30 T5 R '11, Subaru BRZ '13, Audi RS4 2007
SUV's: Mercedes Benz R500 '06, Mercedes Benz ML350 '12
BRZPDX is offline   Reply With Quote
Old 05-07-2014, 01:40 PM   #83
Jason@DSG
Jason@DSG's Avatar
@mid_life_crisis Just to clarify, it's not brutal neck snapping type shifts, there's just no slop and gears engage like a proper sports car should ie. you can chirp the tires in an AT at full redline
If you're in traffic and have to do lower speed cruising, I suggest driving in manual mode to control the gears yourself so they don't switch in and out. You can cruise in 2nd type of thing and roll.
@BRZPDX How it works for the core, we are offering introductory pricing on this and SSP is running all their line through us on here You send your core directly to them and they'll send it back (or you can buy a new core directly from them and keep yours as a spare).
Here's pricing on everything (please don't delete this post -- people are asking for the info I'm not pushing sales):
Stage 1 Valvebody Upgrade
(no core being sent in, new OEM core included)
MSRP -- $1,249.00
DSG Introductory Price -- $1,194.99
(core being sent in -- shipping cost of core at customers expense)
MSRP -- $699.00
DSG Introductory Price -- $644.99
Stage 2 Valvebody Upgrade
MSRP -- $1,349.00
DSG Introductory Price -- $1,294.99
MSRP -- $799.00
DSG Introductory Price -- $744.99
Old 05-07-2014, 05:01 PM   #84
BRZPDX
Boosted Member
BRZPDX's Avatar
awesome info man, thank you. How long does it take to revalve/shipping it back? Should I expect about a 2week downtime on my car?
Also how would the DDability be affected so much for stage2 if it is just an added aggressive shift change from 4 to 6? Won't the 1 to 4 more commonly used during DD? Once its slapped in 5th or 6th, you don't shift gears too often..
Need Transmission Upgrades for Turbo? Admired Forced Induction 26 11-10-2013 02:48 PM
All Possible Car Upgrades? pwnisher Scion FR-S / Toyota 86 GT86 General Forum 31 07-23-2013 12:27 PM
Transmission moving after upgrades? Sniper2606 Engine, Exhaust, Transmission 2 07-10-2013 01:54 AM
GPS Map Upgrades? Enemies Electronics | Audio | NAV | Infotainment 0 04-20-2013 04:18 PM
topspeed difference between manual transmission and automatic transmission torquemada BRZ First-Gen (2012+) — General Topics 51 05-04-2012 07:54 PM
