go_a_way1
Old 05-03-2014, 11:58 AM   #4985
robwbright
Drives: '13 BRZ Limited WRB Phantom ESC 1.5
I'm in Ohio lol
Me too.
'13 BRZ Ltd MT WRB Phantom ESC 1.5
2012 Honda Accord Coupe
2006 Saab 9-3 2.0t
1997 Honda Accord Coupe
1995 Honda Prelude VTEC
robwbright is offline   Reply With Quote
The Following User Says Thank You to robwbright For This Useful Post:
raven1231 (05-03-2014)
Old 05-03-2014, 01:15 PM   #4986
Gary in NJ
Gary in NJ's Avatar
Drives: WR Blue BRZ, 240Z
Being that it runs when its off makes me thing the tune isn't the problem either . Unplugging the controller will disengage the system thoufh right? Wouldn't that be the same as leaving it off ? Also it still pulls great when going wot and the voltage drops when engaged so I'm guessing the compressor is good as well
Until you isolate the problem, its all just a guess.
If the problem completely goes away with the Arm switch off, then it's either something in the ESC system (compressor, controller, harness) or something that the ESC system is interacting with (through the installation).
Check you installation again. But if the ESC is shutting down the electrical system...STOP using it. Get in touch with Rob.
Phantom ESC, ECUtek Tune, Nameless Front Pipe & Axle Back, Enkei RS+M 17x8 et35, OEM+Ref
Gary in NJ is offline   Reply With Quote
Old 05-03-2014, 01:21 PM   #4987
Robftss
Drives: VW
This morning However everytime after I engage the Esc all the lights on my dash turn on and the power is cut off causing the car to stall... Any ideas what's causing this ?
'Stall after WOT event'. Sounds like the compressor brake has been disabled, causing the car to stall. email me and I'll tell you how to reset it.
Thks, Rob.
Robftss is offline   Reply With Quote
The Following User Says Thank You to Robftss For This Useful Post:
DAEMANO (05-03-2014)
Old 05-03-2014, 01:29 PM   #4988
raven1231
Thks, Rob.
That's exactly what it sounds and feels like. I'll email you, thanks Rob !
Old 05-03-2014, 01:45 PM   #4989
raven1231
I did double check my installation and everything looked perfect. I haven't been engaging it since the issue started. I do appreciate your help and input though, it's nice having for the most part such a helpful forum. I'm going to try Rob's suggestion then get back to all of you on the outcome.
On a side note, with the exception of this occurrence, this system has been amazing!
Old 05-03-2014, 02:25 PM   #4990
fenton
If for any reason your tune wasn't on the car anymore that would probably cause a issue to. Check with the oft that you are still running the phantom tune.
fenton is offline   Reply With Quote
The Following User Says Thank You to fenton For This Useful Post:
Old 05-03-2014, 02:26 PM   #4991
fenton
So I got a problem... I am running the Esc on 93 octane with the oft tune. For the first few days everything was perfect. This morning However everytime after I engage the Esc all the lights on my dash turn on and the power is cut off causing the car to stall... Any ideas what's causing this ?
When I read this again it really does just sound like the compressor brake.
The Following 2 Users Say Thank You to fenton For This Useful Post:
DAEMANO (05-03-2014), raven1231 (05-03-2014)
Old 05-03-2014, 03:13 PM   #4992
shif7i7down
Erected Member
Drives: frs
Is this normal?
shif7i7down is offline   Reply With Quote
Old 05-03-2014, 03:28 PM   #4993
fenton
Originally Posted by shif7i7down View Post
Is this normal?
Well the compressor always needs to brake. Maybe his wasn't set strong enough for some reason.
If its not strong enough it can cause the engine to stall from continuing to force air into the engine. Normally it isn't a problem but if you go WOT and then clutch in right after and the brake isn't fast enough it can cause a stall.
Old 05-03-2014, 03:52 PM   #4994
raven1231
So I reset the compressor before leaving work as Rob suggested and it worked perfect! Everything is back to normal, I just hope it stays that way. Thanks everyone! By the way I do have to say Rob's customer service has been phenomenal.
The Following 2 Users Say Thank You to raven1231 For This Useful Post:
DAEMANO (05-03-2014), fenton (05-03-2014)
Old 05-03-2014, 03:53 PM   #4995
Sojhinn
Lightning McQueen Driver
Sojhinn's Avatar
Drives: Limited Red 6MT BRZ
Full throttle Electric Supercharger Build Thread
Process for reseting the brake: how difficult was it?
Installed Mods:
Old 05-03-2014, 03:55 PM   #4996
raven1231
Originally Posted by Sojhinn View Post
Process to reseting the brake how difficult was it?
literally 5 seconds long. Don't even start the car lol
Old 05-03-2014, 04:46 PM   #4997
shif7i7down
Erected Member
Drives: frs
Wanna share the procedure? Just in case we may need it in the future.👊💦
Old 05-03-2014, 04:52 PM   #4998
Robftss
Drives: VW
Simply...arm 'on' when the car is idling.
If you arm 'on' during WOT or a DR pulse the controller has not had time (2 seconds) to initialize...This may trigger a brake re-programming.
It is old code that I used to adjust brake force on the fly. I have deleted this function on all but the first 5 kits with new firmware.
Good to hear it is solved. Rob.
The Following 2 Users Say Thank You to Robftss For This Useful Post:
Circuit Motorsports - Vortech Supercharger FR-S Build + Full Perrin Exhaust & Extras Circuit Motorsports Member's Car Journals 4 03-21-2013 05:45 PM
Subaru BRZ : Full Throttle, powerslide, hard revving & ride ESBjiujitsu BRZ Photos, Videos, Wallpapers, Gallery Forum 20 05-30-2012 07:43 PM
86 Full Throttle Video + another. Aus86 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 2 04-02-2012 08:07 AM
