Old 05-01-2014, 02:24 PM   #239
poptopclk
Drives: Scion FR-S 10 Series
Just got the FR-S
First off I have read all the posts on this thread and alot of good information.
It appears the Series 10 FR-S has the newer head unit PT546-00140
It looks like the identical one that shows in Mandy's video.
GPS would be nice but I really want the text message feature enabled.
Currently I can make phone calls & listen to Pandora via BluTooth
What part numbers are needed to add the text message functionality ?
GPS functionality?
Also in the big PDF file from the Scion website it shows a this HU being controlled with a steering wheel button panel.
I wonder if there are parts that can be scavenged from other toyotas to get the steering wheel buttons.
BTW nice Forum and I will be making good use of it.
Thanks
poptopclk is offline   Reply With Quote
Old 05-01-2014, 05:19 PM   #240
poptopclk
buttons ???
From the Scion website the 2014 Pioneer HU owner's manual
Old 05-01-2014, 05:36 PM   #241
oldpueblo
oldpueblo's Avatar
Drives: Scion FR-S 10 #853
The head unit is the same across all scions for 2014. You're answer is right there in the middle of the left column.
"Steering switches are not equipped on FR-S."
oldpueblo is offline   Reply With Quote
Old 05-01-2014, 06:52 PM   #242
poptopclk
yes but
I did see that.. Since it referred to the car it would lead me to believe that the Head Unit was designed with the ability to be controlled remotely by steering wheel switches. I suspect some other model cars may use this unit & they might employ this very useful feature. (How could Toyota look at the diagram and think "steering wheel buttons Who would want or expect them in our top model)
Old 05-11-2014, 03:33 PM   #243
MisterJBN
MisterJBN's Avatar
Drives: 2014 Scion FRS Monogram Whiteout AT
Hey guys, I've been searching around but have not found a concrete answer so I hope someone can help me here.
I have a 2014 MG with the BeSpoke premium audio/nav with AHA which is extremely limiting (no Pandora, what on earth). Can I flash the system with this update (http://www.toyotanation.com/forum/32...load-link.html) or is the BeSpoke and Entune two totally different system? (I don't want to brick it haha...
MisterJBN is offline   Reply With Quote
Old 05-11-2014, 03:45 PM   #244
Danklvr
Danklvr's Avatar
Drives: 2014 FR-S 6MT Argento
Send a message via AIM to Danklvr
The system will not allow you to flash engine firmware into a bespoke unit.
How ya gonna keep 'em down on the farm once they've seen Karl Hungus?
Danklvr is offline   Reply With Quote
Old 05-27-2014, 08:00 PM   #245
STV3
Señor Member
STV3's Avatar
Edit: Scratch that... Started to drive and it kicked in and works perfect now lol
So I got the upgraded radio from a friend and I purchased the GPS antenna in the link on the first post and it did not fit properly. I shaved down the plastic a little so it would slide in because the connecter on the inside looks the same and it fit in fine but the GPS isn't working. Any ideas? Did they change the antenna since you bought from that link?
STV3 is offline   Reply With Quote
Old 05-28-2014, 12:29 PM   #246
poptopclk
I can vouch for this thread.. This was Soooo easy to install. You can find the Entune module on Ebay I got mine with the brackets & wiring harness for about $300 and found a Scion GPS antenna for $16 .
Pop off the surround for the head unit, remove cover above the instrument cluster (one screw in center easy), remove 4 bolts, slide out unit, disconnect modular plugs, bolt on Entune module, reconnect plugs, attach GPS antenna.. Reconnect battery cable under hood. Voila.. Gps and internet apps, phone and text messages all in your center console.
YES IT REALLY IS THAT EASY !
Old 05-28-2014, 05:17 PM   #247
skyloran
Honeydew old ID
skyloran's Avatar
Drives: GT86
link please..i dont see $300 on ebay?
Used to owned M3 and Lotus, but love my GT86 the most.
skyloran is offline   Reply With Quote
Old 05-29-2014, 03:21 PM   #248
poptopclk
There were 3 when I got mine at beginning of May
This is all I see currently
http://www.ebay.com/itm/2014-Scion-b...56c208&vxp=mtr
Here is the perfect fit GPS ANTENNA
http://www.ebay.com/itm/TOYOTA-LEXUS...b0b356&vxp=mtr
Old 05-29-2014, 03:41 PM   #249
STV3
Señor Member
STV3's Avatar
Think there is any difference between this one and the one I got that was linked in the OP other then the connector? The OCD side of me wants to order this one just because it will fit in properly even though I got the other one to fit with a little bit of sanding lol
Old 05-29-2014, 03:43 PM   #250
STV3
Señor Member
STV3's Avatar
Also anyone notice that the radio reception is worse with this newer head unit?
Old 05-29-2014, 06:09 PM   #251
poptopclk
All I can say is the one GPS antenna I ordered clicked in and locked in place perfectly. The connector is a square inside a square opening.
Old 05-29-2014, 06:12 PM   #252
poptopclk
Re the reception, make sure you don't connect the USB in the wrong connector. That cable now connects to the module and not the head unit. Also the bluetooth connector from the module connects to the head unit.
New Scion Standard Radio for 2014 NedVargar Electronics | Audio | NAV | Infotainment 45 06-13-2013 10:00 PM
WTB: Pioneer Premium Audio radio/head unit tech4pdx Canada Classifieds 2 04-14-2013 08:31 PM
Sirus Radio on Stock head Unit wtout86 Electronics | Audio | NAV | Infotainment 3 11-20-2012 03:22 PM
Fitting the radio plug into aftermarket head unit GC GTS Aero Kit Electronics | Audio | NAV | Infotainment 1 10-29-2012 06:41 AM
head unit in GTA excited86 Electronics | Audio | NAV | Infotainment 1 06-18-2012 08:42 PM
