Old 04-30-2014, 09:08 AM   #1
B-R-Z
I love peanut butter
B-R-Z's Avatar
Drives: 2013 SWP BRZ Limited
Pro-Kit right height at each wheel
I recently installed pro-kit springs on my BRZ and last weekend put on 18" wheels. When I go around each wheel to check the drop, I can almost perfectly fit 2 fingers in all wheel-to-fender gaps except the drivers side rear--this wheel seems to be slightly lower. Does anyone else have this issue? The passenger side rear also seems a hair lower than the passenger side front.
B-R-Z is offline   Reply With Quote
Old 04-30-2014, 08:02 PM   #2
ericmpena
ericmpena's Avatar
Drives: Subaru BRZ Limited
Best bet would be to take a measuring tape to it. I had the same issues with my Sportlines. My rear passenger side sat considerably lower than the rest of the car. Most Pro-Kits I've seen seem pretty even. Take a measuring tape and see exactly how much of a difference you're talking about here.
ericmpena is offline   Reply With Quote
Old 04-30-2014, 08:05 PM   #3
bee_are_zee
bee_are_zee's Avatar
Drives: GBS BRZ
Just throwing this out there. Did you make sure that the spring was sitting in the rubber piece the same way the old spring was. If it wasn't in that pocket where the spring ended I could see them initially sitting a bit higher making the others look lower.
bee_are_zee is offline   Reply With Quote
Old 04-30-2014, 08:13 PM   #4
B-R-Z
B-R-Z's Avatar
Yes, and I can't see 3 accidentally slipping out and only one staying in the right spot. If I had one higher than the three others then that could be possible.
SEAT HEIGHT ZOMFGAARON Cosmetic Modification (Interior/Exterior/Lighting) 22 01-06-2014 08:41 AM
Wheel gap - from suspension height or tire diameter? CaptainSlow Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 01-27-2013 12:48 PM
car height problems? industrial86 Scion FR-S / Toyota 86 GT86 General Forum 12 10-03-2012 07:43 PM
what height are you running Im_SPEED Tracking / Autocross / HPDE / Drifting 0 09-27-2012 11:29 PM
BRZ/FR-S Trunk Height? ngabdala Scion FR-S / Toyota 86 GT86 General Forum 1 05-24-2012 01:41 PM
